Did I just kill my valves? Same as in the allroad forum
I just noticed there is this dedicated 2.7T forum.
15k miles ago I paid to have the timing belt done by a reputable shop on the West Coast... over Christmas the thermostat failed so I had very little heat. Long story, skip to the last paragraph for the actual problem https://www.audiworld.com/forums/ima...lies/smile.gifSo I started the job again myself and got into a bit of a snag. When I removed the timing covers I found they had been wrongly installed and were worn through by the pulleys and sprockets. What I didn't notice is that bits fell and were channeled on the crank sprocket. When I then turned the crank to align the marks, the cams were slightly ahead of the crank, another turn made it worst, then third turn and I realised something was amiss. (I had not removed the old belt at that point). I checked and found that the bits were lodged in the teeth of the crank sprocket. I suppose that those bits were making the sprocket take more belt than it should and advancing the valve timing. So the picture with a picture of the crank pulley shows how far in advance I went. That picture was taken with the bar in place so the cams are where they should but the crank is not.Question is, do you think I went far enough to have busted a valve?(or a few) I felt resistance but I was only using a 1/2in ratchet, no extension bar so it was hard to say if it was compression resistance or mechanical.Thanks for the help! https://cimg9.ibsrv.net/gimg/www.aud...d57359851b.jpg https://cimg0.ibsrv.net/gimg/www.aud...10ca337e08.jpgthe timing bar is in at that time. Big circle is where the pulley mark is and small oval where the timing mark on the cover is. https://cimg2.ibsrv.net/gimg/www.aud...8e2098ed14.jpg |
well I should update!
I timed it right and did a compression check. 150 across the board!! that was without charging the battery and with a cold engine that hadn't run in a week so I guess I'm good to go! Time to celebrate, I will put it back together tomorrow! Cheers David |
