Limp Mode - TCU issue?
My 2001 c5a6, 2.7t is in "limp mode", tiptronic not working at all, not displaying any gear info on the center screen, ABS and ESP lit up. VAGCOM codes are below. I pulled up the passenger footwell carpet to check for water damage, but the TCU box and unit are bone dry. Next I unplugged the MAF as I read that could be an issue as well, and the car ran the same with it unplugged. FWIW I already knew that my secondary air pump was shot, which are the first two codes... Has anyone had these symptoms?
Scan results: VCDS-Lite Version: Release 1.2 Wednesday, 08 May 2013, 12:51:46. Chassis Type: 4B - Audi A6 C5 Scan: 01,02,03,06,08,15,16,17,18,22,34,35,36,37,45,55,56 ,57,65,67,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 078-907-551-AZA.LBL Controller: 4B0 907 551 T Component: 2.7l V6/5VT G 0001 Coding: 06752 Shop #: WSC 02325 VCID: 351DA2D71C59 WAUED64B11N076885 AUZ7Z0Y1629862 5 Faults Found: 17831 - Secondary Air Injection System; Bank 1: Insufficient Flow P1423 - 35-00 - - 17819 - Shareware Version. To Decode all DTCs P1411 - 35-00 - Please Register/Activate 17862 - Shareware Version. To Decode all DTCs P1454 - 35-00 - Please Register/Activate 16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold P0421 - 35-10 - - - Intermittent 18034 - Shareware Version. To Decode all DTCs P1626 - 35-10 - Please Register/Activate - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01V-927-156.LBL Controller: 4B0 927 156 BD Component: AG5 01V 2.7l5VT USA 3131 Coding: 00002 Shop #: WSC 00000 VCID: 6AA741AB0567 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.LBL Controller: 8D0 907 389 E Component: ABS/ESP allrad D56 Coding: 06397 Shop #: WSC 02325 VCID: 351DA2D71C59 1 Fault Found: 18034 - Powertrain Data Bus: Missing Message from TCU P1626 - 35-10 - - - Intermittent |
So this morning I went out, turned the car on, and it was out of limp mode. Drove around the block, but before I could get back it banged a shift and went back into limp. Does anyone think I could need to change the AutoTrans Fluid? I thought it was for the life of the vehicle and you didn't change it, but I am seeing on other threads that people do, and since the car has 202k miles, whatever is in there could be getting pretty nasty...
