Help with valve cover leak....
I had the valve cover gaskets replaced to fix a rather obnoxious leak. The replacement fix most of the leak but now it is leaking from the front driver's side corner. I had the mechanic redo it and it did not fix the problem. I know the 2.8L is notorious for valve cover leaks. Is the front corner typical for this problem. Is there a "trick" to remedy this? Is it possible the cover itself is slightly warped causing the leak?
Any help would be appreciated. |
Its not the cover, its the chain tensioner in front of it leaking down to the corner.
