Where to start with these fault codes? Engine starts but stalls immediately. 3.0L V6
Hi Guys,
This is my first post in the forum, Im hoping someone can be of assistance here. Long story short, my 2003 A3 3.0 Quattro will not start. It will turn over and run for about 1 second after which it stalls. I borrowed a code reader which came up with the following 8 fault codes. Any help with respect to which components are typically the cause for this no-start issue and these codes is hugely appreciated. Thanks in advance! 8 Faults Found: 17524 - Oxygen (Lambda) Sensor Heating; B1 S1 P1116 - 004 - Open Circuit - MIL ON 17936 - Camshaft Timing Adj. Bank1 (N205) P1528 - 004 - Open Circuit - Intermittent 17464 - Bank1; Exhaust Cam Adjustment Circuit P1056 - 002 - Short to Ground - Intermittent - MIL ON 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - Intermittent 16685 - Cylinder 1 P0301 - 001 - Misfire Detected - Intermittent 16687 - Cylinder 3 P0303 - 001 - Misfire Detected - Intermittent 16686 - Cylinder 2 P0302 - 001 - Misfire Detected - Intermittent 16705 - Engine Speed Sensor (G28) P0321 - 008 - Implausible Signal Readiness: 0110 1101 |
Correction on my previous post, its an Audi A4, not an A3.
