ECU swap gone wrong 2011 S5 - Got a automatic ECU
Team,
So first my sob story, was supposed to move to texas on the 3rd, car died the night prior. Litterally had just parked the car and shut her down, got out walked 10 feet realized I couldnt park in that spot, got back in and lit up like a xmas tree. My buddy/neighbor tried jumping with his GTI and nothing. Hooked it up to vcds....
Spoiler
Sunday,02,June,2019,21:54:07:58285
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4 Data version: 20190529 DS308.0 www.Ross-Tech.com Chassis Type: 8T0 Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F 6C Mileage: 192610km-119682miles 01-Engine -- Status: Sporadic communication error 1000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: VCID: 55F7828FEC0F6C7FC97-FFFE Note: Excessive Comm Errors ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ Component: ESP8 quattro H04 0050 Revision: -------- Serial number: -------------- Coding: 110D18 Shop #: WSC 06325 000 00000 VCID: 025D89D344012BC7DC5-8056 4 Faults Found: 02214 - Tire Pressure Warning 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 113 Mileage: 192217 km Time Indication: 0 Date: 2010.08.10 Time: 19:43:54 Freeze Frame: Hex Value: 0x7A00 Hex Value: 0x4006 Hex Value: 0x1237 Hex Value: 0x1FB2 Hex Value: 0x00FF 01314 - Engine Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 6 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:54:08 Freeze Frame: Hex Value: 0x0080 Hex Value: 0x0722 Hex Value: 0x122B Hex Value: 0xB998 Hex Value: 0x00FF 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:54:09 Freeze Frame: Hex Value: 0x0080 Hex Value: 0x2722 Hex Value: 0x1232 Hex Value: 0x0298 Hex Value: 0x00FF 01314 - Engine Control Module 008 - Implausible Signal Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 6 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:54:08 Freeze Frame: Hex Value: 0x0080 Hex Value: 0x0722 Hex Value: 0x122B Hex Value: 0xB998 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG Component: BCM2 2.0 H04 0430 Revision: 00002001 Coding: 0F0000 Shop #: WSC 06325 000 00000 VCID: 77ABE8071FC37E6FFBB-8022 Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 0210000112900006 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 2 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:55:09 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb Part No SW: 8T0 959 760 C HW: 8T0 959 760 C Component: MEM-BFS H10 0074 Revision: AA000000 Serial number: 00001010182726 Coding: 00017025002C00000000 Shop #: WSC 06325 000 00000 VCID: 43D34CD71B9BE2CF973-8016 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component: KLIMA 3 ZONEN H08 0180 Revision: C1000000 Serial number: 01240620100280 Coding: 48122000 Shop #: WSC 06325 000 00000 VCID: 005983DB4A0D39D7CA1-8054 2 Faults Found: 03269 - Functionality Linited due to Energy Management 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 21:52:05 01314 - Engine Control Module 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:54:08 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H29 0392 Revision: 10029001 Serial number: 00000000576354 Coding: 26001091063CAF010000080300003D3D0F1C13880201016100 0000 Shop #: WSC 06325 000 00000 VCID: 3C21372B66659D37D69-8068 Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB Component: WWS 260610 H14 0070 Serial number: SWF10060265537 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10963949 Coding: 02532C Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN Component: E1 - LDS H08 0090 Serial number: 00000000001606101989 3 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:55:00 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 63 Mileage: 192027 km Time Indication: 0 Date: 2010.08.01 Time: 14:44:00 02258 - Door Opener Transmitter 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 63 Mileage: 192027 km Time Indication: 0 Date: 2010.08.01 Time: 14:44:00 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 Q HW: 8K0 919 475 Component: PARKHILFE 4K H06 0070 Revision: 11001001 Serial number: 51241018214386 Coding: 200002 Shop #: WSC 06325 000 00000 VCID: 47CB58C72FA3CEEF4BB-8012 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 K HW: 8K0 959 655 K Component: AirbagVW-AU10 H41 0610 Serial number: 003GLD0G89YY Coding: 303338334330303030304A55304C38543053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 45D752CF152FDCFFB97-8010 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A Component: BF-Gewichtss. H02 0060 Serial number: 5810000R1000000EEE Crash sensor for side airbag: driver side: Serial number: 6334MSME550266748 Crash sensor for side airbag: front passenger side: Serial number: 6344MSME55326646B Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME3F59513CU Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME42532B049 Crash sensor for front airbag: driver side: Serial number: 63732SME13624304M Crash sensor for front airbag: front passenger side: Serial number: 63832SME61654820W No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8R0 953 568 K HW: 8R0 953 568 K Component: Lenks.Modul H06 0156 Revision: 00000000 Serial number: 20100702000181 Coding: 000016 Shop #: WSC 06325 000 00000 VCID: 49CF5EFF39B7389F5DF-801C Component: E221 - MFL H02 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8T0 920 983 D HW: 8T0 920 983 D Component: KOMBIINSTR. H38 0258 Revision: 00000000 Serial number: EI118ZU5A Coding: 8B1501000300D705020000 Shop #: WSC 06325 000 00000 VCID: 3FDB40277773862FF3B-806A 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 21 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:54:09 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0117 Revision: EC000056 Serial number: 5600E1061400B5 Coding: 00C303 Shop #: WSC 06325 000 00000 VCID: 03538CD75B1B22CFD73-8056 Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H07 0170 Serial number: 10020AEB180610 3 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 5 Reset counter: 129 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:54:38 Freeze Frame: Bin. Bits: 10000 Voltage: 12.20 V Count: 7 Bin. Bits: 10011 Time: 0.40 s 01312 - Powertrain Data Bus 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 5 Reset counter: 129 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:54:39 Freeze Frame: Bin. Bits: 10000 Voltage: 12.20 V Count: 7 Bin. Bits: 10011 02252 - Generator 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 21:51:45 Freeze Frame: Bin. Bits: 10111 Voltage: 11.30 V Count: 6 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8T0 959 760 C HW: 8T0 959 760 C Component: MEM-FS H10 0074 Revision: AA000000 Serial number: 00001010182838 Coding: 00197B25002C00000000 Shop #: WSC 06325 000 00000 VCID: 43D34CD71B9BE2CF973-8016 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8T0 959 793 M HW: 8T0 959 793 D Component: TSG FA H08 1401 Revision: -------- Serial number: -------------- Coding: 011C13224E00120102 Shop #: WSC 06325 000 00000 VCID: 53F37C97EBFB724F273-8006 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG Component: BCM2 2.0 H04 0430 Revision: 00002001 Serial number: 0132032189 Coding: 0106029A00FA444580B0003200000000 Shop #: WSC 06325 000 00000 VCID: 77ABE8071FC37E6FFBB-8022 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J245EE20SKB13 H02 0220 Serial number: 0123456789ABCDEFGHIJ 2 Faults Found: 03233 - Controls for Garage Door Opener (E284) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 63 Mileage: 192027 km Time Indication: 0 Date: 2010.08.01 Time: 14:44:47 01314 - Engine Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 2 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:55:09 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK Component: DSP Prem H10 0190 Revision: 00010001 Serial number: 34882003220401 VCID: 7AADF1332CD16307845-802E No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8T0 959 792 M HW: 8T0 959 792 D Component: TSG BF H08 1401 Revision: -------- Serial number: -------------- Coding: 011C13224E00120102 Shop #: WSC 06325 000 00000 VCID: 52FD7993D4E17B472C5-8006 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 00000000677599 Shop #: WSC 00000 000 00000 VCID: 34311F0B4E3555771E9-8060 2 Faults Found: 01314 - Engine Control Module 013 - Check DTC Memory - MIL ON Freeze Frame: Fault Status: 11101101 Fault Priority: 4 Fault Frequency: 7 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:54:09 Freeze Frame: Voltage: 12.30 V Count: 58 Speed: 0.0 km/h Hex Value: 0x0270 Hex Value: 0x0001 Hex Value: 0x0202 01314 - Engine Control Module 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 4 Fault Frequency: 11 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:54:09 Freeze Frame: Voltage: 12.20 V Count: 64 Speed: 0.0 km/h Hex Value: 0x0260 Hex Value: 0x0001 Hex Value: 0x0202 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 B Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000002 Shop #: WSC 06325 000 00000 VCID: 392F2E3F6557A81FCDF-806C 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 89 Mileage: 192619 km Time Indication: 0 Date: 2010.08.27 Time: 20:54:08 ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 HW: 4G0 035 082 Component: Radio U SIRIU H51 0052 Revision: AB001007 Serial number: 471FO0A7512510 Coding: 020007010000000001 Shop #: WSC 06325 000 00000 VCID: 5DE79AAF9D3FB43F817-8008 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8T1 035 664 C HW: 8T1 035 664 B Component: H-BN-NA H49 0116 Revision: -------- Serial number: 490G%0A7573636 Coding: 010200020206A1EF41000B0E000000030000 Shop #: WSC 06325 000 00000 VCID: 38292B3B525DB117321-806C Subsystem 1 - Part No: 8R0 060 884 P Component: NAR 2010 0407 Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604 Component: DU7 High H42 0094 Serial number: 9466GR0A0031771 Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G Component: E0380 Bedient H08 0100 Serial number: 00000000574669 Subsystem 4 - Part No: 8R0 060 961 Component: CD-Database 1886 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H04--- Serial number: 525PA8-J0491XW Coding: 1000008 Shop #: WSC 06325 000 00000 VCID: 38292B3B5E5DB117321-806C No fault code found. End----(Elapsed Time: 01:58, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
Spoiler
Friday,14,June,2019,17:25:32:58285
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4 Data version: 20190529 DS308.0 www.Ross-Tech.com VIN: WAU3VAFRXBA009762 License Plate: Chassis Type: FR-AU48 (8T0) Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F 6C VIN: WAU3VAFRXBA009762 Mileage: 192610km-119682miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAUB) Labels:. 079-907-560-CAU.clb Part No SW: 8T0 907 560 AD HW: 8T0 907 560 Component: 4.2l V8/4V H22 0001 Revision: 76H22--- Coding: 01140009190F0120 Shop #: WSC 06325 000 00000 VCID: 7CA1F72B26E55D37969-8028 1 Fault Found: 049409 - No Communication with Transmission Control Module U0101 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:53 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 24.0°C Temperature: 39.0°C Absolute Pres.: 980.0 mbar Voltage: 11.811 V Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ Component: ESP8 quattro H04 0050 Revision: -------- Serial number: -------------- Coding: 110D18 Shop #: WSC 46268 003 1048576 VCID: 025D89D344012BC7DC5-8056 2 Faults Found: 02757 - Learning Tire Pressures 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:53 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0282 Hex Value: 0x0037 Hex Value: 0x3993 Hex Value: 0x00FF 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:55 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0782 Hex Value: 0x0032 Hex Value: 0x0293 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG Component: BCM2 2.0 H04 0430 Revision: 00002001 Coding: 0F0000 Shop #: WSC 06325 000 00000 VCID: 77ABE8071FC37E6FFBB-8022 Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 0210000112900006 No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb Part No SW: 8T0 959 760 C HW: 8T0 959 760 C Component: MEM-BFS H10 0074 Revision: AA000000 Serial number: 00001010182726 Coding: 00017025002C00000000 Shop #: WSC 46268 003 1048576 VCID: 43D34CD71B9BE2CF973-8016 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component: KLIMA 3 ZONEN H08 0180 Revision: C1000000 Serial number: 01240620100280 Coding: 48122000 Shop #: WSC 06325 000 00000 VCID: 005983DB4A0D39D7CA1-8054 1 Fault Found: 01206 - Signal for Duration of Ignition Off Time 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:52 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H29 0392 Revision: 10029001 Serial number: 00000000576354 Coding: 26001091063CAF010000080300003D3D0F1C13880201016100 0000 Shop #: WSC 46268 003 1048576 VCID: 3C21372B66659D37D69-8068 Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB Component: WWS 260610 H14 0070 Serial number: SWF10060265537 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10963949 Coding: 02532C Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN Component: E1 - LDS H08 0090 Serial number: 00000000001606101989 2 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:00 02258 - Door Opener Transmitter 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:00 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 Q HW: 8K0 919 475 Component: PARKHILFE 4K H06 0070 Revision: 11001001 Serial number: 51241018214386 Coding: 200002 Shop #: WSC 46268 003 1048576 VCID: 47CB58C72FA3CEEF4BB-8012 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 K HW: 8K0 959 655 K Component: AirbagVW-AU10 H41 0610 Serial number: 003GLD0G89YY Coding: 303338334330303030304A55304C38543053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 45D752CF152FDCFFB97-8010 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A Component: BF-Gewichtss. H02 0060 Serial number: 5810000R1000000EEE Crash sensor for side airbag: driver side: Serial number: 6334MSME550266748 Crash sensor for side airbag: front passenger side: Serial number: 6344MSME55326646B Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME3F59513CU Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME42532B049 Crash sensor for front airbag: driver side: Serial number: 63732SME13624304M Crash sensor for front airbag: front passenger side: Serial number: 63832SME61654820W No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8R0 953 568 K HW: 8R0 953 568 K Component: Lenks.Modul H06 0156 Revision: 00000000 Serial number: 20100702000181 Coding: 000016 Shop #: WSC 46268 003 1048576 VCID: 49CF5EFF39B7389F5DF-801C Component: E221 - MFL H02 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8T0 920 983 D HW: 8T0 920 983 D Component: KOMBIINSTR. H38 0258 Revision: 00000000 Serial number: EI118ZU5A Coding: 8B1501000300D705020000 Shop #: WSC 46268 003 1048576 VCID: 3FDB40277773862FF3B-806A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0117 Revision: EC000056 Serial number: 5600E1061400B5 Coding: 00C303 Shop #: WSC 06325 000 00000 VCID: 03538CD75B1B22CFD73-8056 Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H07 0170 Serial number: 10020AEB180610 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8T0 959 760 C HW: 8T0 959 760 C Component: MEM-FS H10 0074 Revision: AA000000 Serial number: 00001010182838 Coding: 00197B25002C00000000 Shop #: WSC 46268 003 1048576 VCID: 43D34CD71B9BE2CF973-8016 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8T0 959 793 M HW: 8T0 959 793 D Component: TSG FA H08 1401 Revision: -------- Serial number: -------------- Coding: 011C13224E00120102 Shop #: WSC 46268 003 1048576 VCID: 53F37C97EBFB724F273-8006 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG Component: BCM2 2.0 H04 0430 Revision: 00002001 Serial number: 0132032189 Coding: 0106029A00FA444580B0003200000000 Shop #: WSC 06325 000 00000 VCID: 77ABE8071FC37E6FFBB-8022 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J245EE20SKB13 H02 0220 Serial number: 0123456789ABCDEFGHIJ 1 Fault Found: 03233 - Controls for Garage Door Opener (E284) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:56 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK Component: DSP Prem H10 0190 Revision: 00010001 Serial number: 34882003220401 VCID: 7AADF1332CD16307845-802E No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8T0 959 792 M HW: 8T0 959 792 D Component: TSG BF H08 1401 Revision: -------- Serial number: -------------- Coding: 011C13224E00120102 Shop #: WSC 46268 003 1048576 VCID: 52FD7993D4E17B472C5-8006 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 00000000677599 Shop #: WSC 00000 000 00000 VCID: 34311F0B4E3555771E9-8060 1 Fault Found: 01315 - Transmission Control Module 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:52 Freeze Frame: Voltage: 11.80 V Count: 66 Speed: 0.0 km/h Hex Value: 0x0270 Hex Value: 0x0001 Hex Value: 0x0101 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 B Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000002 Shop #: WSC 06325 000 00000 VCID: 392F2E3F6557A81FCDF-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 HW: 4G0 035 082 Component: Radio U SIRIU H51 0052 Revision: AB001007 Serial number: 471FO0A7512510 Coding: 020007010000000001 Shop #: WSC 06325 000 00000 VCID: 5DE79AAF9D3FB43F817-8008 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8T1 035 664 C HW: 8T1 035 664 B Component: H-BN-NA H49 0116 Revision: -------- Serial number: 490G%0A7573636 Coding: 010200020206A1EF41000B0E000000030000 Shop #: WSC 06325 000 00000 VCID: 38292B3B525DB117321-806C Subsystem 1 - Part No: 8R0 060 884 P Component: NAR 2010 0407 Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604 Component: DU7 High H42 0094 Serial number: 9466GR0A0031771 Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G Component: E0380 Bedient H08 0100 Serial number: 00000000574669 Subsystem 4 - Part No: 8R0 060 961 Component: CD-Database 1886 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H04--- Serial number: 525PA8-J0491XW Coding: 1000008 Shop #: WSC 06325 000 00000 VCID: 38292B3B5E5DB117321-806C No fault code found. End----(Elapsed Time: 01:31, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)----- So I tried changing the engine settings from 01140009190F0120 to 01140009180F0120 and it kept spitting out an error.
Spoiler
Friday,14,June,2019,17:27:13:58285
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4 Data version: 20190529 DS308.0 www.Ross-Tech.com VIN: WAU3VAFRXBA009762 License Plate: NEW_ECU Mileage: 192610km-119682mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FR-AU48 (8T0) Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F 6C VIN: WAU3VAFRXBA009762 Mileage: 192610km-119682miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAUB) Labels:. 079-907-560-CAU.clb Part No SW: 8T0 907 560 AD HW: 8T0 907 560 Component: 4.2l V8/4V H22 0001 Revision: 76H22--- Coding: 01140009190F0120 Shop #: WSC 06325 000 00000 VCID: 7CA1F72B26E55D37969-8028 1 Fault Found: 049409 - No Communication with Transmission Control Module U0101 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:53 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 24.0°C Temperature: 39.0°C Absolute Pres.: 980.0 mbar Voltage: 11.811 V Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ Component: ESP8 quattro H04 0050 Revision: -------- Serial number: -------------- Coding: 110D18 Shop #: WSC 46268 003 1048576 VCID: 025D89D344012BC7DC5-8056 2 Faults Found: 02757 - Learning Tire Pressures 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:53 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0282 Hex Value: 0x0037 Hex Value: 0x3993 Hex Value: 0x00FF 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:55 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0782 Hex Value: 0x0032 Hex Value: 0x0293 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG Component: BCM2 2.0 H04 0430 Revision: 00002001 Coding: 0F0000 Shop #: WSC 06325 000 00000 VCID: 77ABE8071FC37E6FFBB-8022 Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 0210000112900006 No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb Part No SW: 8T0 959 760 C HW: 8T0 959 760 C Component: MEM-BFS H10 0074 Revision: AA000000 Serial number: 00001010182726 Coding: 00017025002C00000000 Shop #: WSC 46268 003 1048576 VCID: 43D34CD71B9BE2CF973-8016 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component: KLIMA 3 ZONEN H08 0180 Revision: C1000000 Serial number: 01240620100280 Coding: 48122000 Shop #: WSC 06325 000 00000 VCID: 005983DB4A0D39D7CA1-8054 1 Fault Found: 01206 - Signal for Duration of Ignition Off Time 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:52 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H29 0392 Revision: 10029001 Serial number: 00000000576354 Coding: 26001091063CAF010000080300003D3D0F1C13880201016100 0000 Shop #: WSC 46268 003 1048576 VCID: 3C21372B66659D37D69-8068 Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB Component: WWS 260610 H14 0070 Serial number: SWF10060265537 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10963949 Coding: 02532C Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN Component: E1 - LDS H08 0090 Serial number: 00000000001606101989 2 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:00 02258 - Door Opener Transmitter 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:00 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 Q HW: 8K0 919 475 Component: PARKHILFE 4K H06 0070 Revision: 11001001 Serial number: 51241018214386 Coding: 200002 Shop #: WSC 46268 003 1048576 VCID: 47CB58C72FA3CEEF4BB-8012 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 K HW: 8K0 959 655 K Component: AirbagVW-AU10 H41 0610 Serial number: 003GLD0G89YY Coding: 303338334330303030304A55304C38543053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 45D752CF152FDCFFB97-8010 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A Component: BF-Gewichtss. H02 0060 Serial number: 5810000R1000000EEE Crash sensor for side airbag: driver side: Serial number: 6334MSME550266748 Crash sensor for side airbag: front passenger side: Serial number: 6344MSME55326646B Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME3F59513CU Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME42532B049 Crash sensor for front airbag: driver side: Serial number: 63732SME13624304M Crash sensor for front airbag: front passenger side: Serial number: 63832SME61654820W No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8R0 953 568 K HW: 8R0 953 568 K Component: Lenks.Modul H06 0156 Revision: 00000000 Serial number: 20100702000181 Coding: 000016 Shop #: WSC 46268 003 1048576 VCID: 49CF5EFF39B7389F5DF-801C Component: E221 - MFL H02 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8T0 920 983 D HW: 8T0 920 983 D Component: KOMBIINSTR. H38 0258 Revision: 00000000 Serial number: EI118ZU5A Coding: 8B1501000300D705020000 Shop #: WSC 46268 003 1048576 VCID: 3FDB40277773862FF3B-806A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0117 Revision: EC000056 Serial number: 5600E1061400B5 Coding: 00C303 Shop #: WSC 06325 000 00000 VCID: 03538CD75B1B22CFD73-8056 Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H07 0170 Serial number: 10020AEB180610 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8T0 959 760 C HW: 8T0 959 760 C Component: MEM-FS H10 0074 Revision: AA000000 Serial number: 00001010182838 Coding: 00197B25002C00000000 Shop #: WSC 46268 003 1048576 VCID: 43D34CD71B9BE2CF973-8016 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8T0 959 793 M HW: 8T0 959 793 D Component: TSG FA H08 1401 Revision: -------- Serial number: -------------- Coding: 011C13224E00120102 Shop #: WSC 46268 003 1048576 VCID: 53F37C97EBFB724F273-8006 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG Component: BCM2 2.0 H04 0430 Revision: 00002001 Serial number: 0132032189 Coding: 0106029A00FA444580B0003200000000 Shop #: WSC 06325 000 00000 VCID: 77ABE8071FC37E6FFBB-8022 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J245EE20SKB13 H02 0220 Serial number: 0123456789ABCDEFGHIJ 1 Fault Found: 03233 - Controls for Garage Door Opener (E284) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:56 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK Component: DSP Prem H10 0190 Revision: 00010001 Serial number: 34882003220401 VCID: 7AADF1332CD16307845-802E No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8T0 959 792 M HW: 8T0 959 792 D Component: TSG BF H08 1401 Revision: -------- Serial number: -------------- Coding: 011C13224E00120102 Shop #: WSC 46268 003 1048576 VCID: 52FD7993D4E17B472C5-8006 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 00000000677599 Shop #: WSC 00000 000 00000 VCID: 34311F0B4E3555771E9-8060 1 Fault Found: 01315 - Transmission Control Module 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:52 Freeze Frame: Voltage: 11.80 V Count: 66 Speed: 0.0 km/h Hex Value: 0x0270 Hex Value: 0x0001 Hex Value: 0x0101 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 B Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000002 Shop #: WSC 06325 000 00000 VCID: 392F2E3F6557A81FCDF-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 HW: 4G0 035 082 Component: Radio U SIRIU H51 0052 Revision: AB001007 Serial number: 471FO0A7512510 Coding: 020007010000000001 Shop #: WSC 06325 000 00000 VCID: 5DE79AAF9D3FB43F817-8008 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8T1 035 664 C HW: 8T1 035 664 B Component: H-BN-NA H49 0116 Revision: -------- Serial number: 490G%0A7573636 Coding: 010200020206A1EF41000B0E000000030000 Shop #: WSC 06325 000 00000 VCID: 38292B3B525DB117321-806C Subsystem 1 - Part No: 8R0 060 884 P Component: NAR 2010 0407 Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604 Component: DU7 High H42 0094 Serial number: 9466GR0A0031771 Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G Component: E0380 Bedient H08 0100 Serial number: 00000000574669 Subsystem 4 - Part No: 8R0 060 961 Component: CD-Database 1886 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H04--- Serial number: 525PA8-J0491XW Coding: 1000008 Shop #: WSC 06325 000 00000 VCID: 38292B3B5E5DB117321-806C No fault code found. End----(Elapsed Time: 01:31, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)----- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 079-907-560-CAU.clb Control Module Part Number: 8T0 907 560 AD HW: 8T0 907 560 Component and/or Version: 4.2l V8/4V H22 0001 Software Coding: 01140009190F0120 Work Shop Code: WSC 06325 000 00000 VCID: 7CA1F72B26E55D37969-8028 1 Fault Found: 049409 - No Communication with Transmission Control Module U0101 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:53 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 24.0°C Temperature: 39.0°C Absolute Pres.: 980.0 mbar Voltage: 11.811 V Readiness: 0110 1101 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Control Module Part Number: 8T0 907 560 AD Component and/or Version: 4.2l V8/4V H22 0001 Software Coding: 01140009190F0120 Work Shop Code: WSC 06325 VCID: 7CA1F72B26E55D37969-8028 Advanced Identification Identification: BPG-810 Revision: 76H22--- Date: 23.11.10 Manufacturer number: 1480 Test stand number: 0512 Flash Status Programming Attempts(application): 0 Successful Attempts(application): 0 Programming Status: 00000000 Flash Tool Code: 00000 000 00000 Misc. Hardware number: 8T0 907 560 Workshop System Name: J623 Car Info Chassis Number: WAU3VAFRXBA009762 Engine code: CAUB VCDS Info: VCID: 7CA1F72B26E55D37969-8028 Labels: 079-907-560-CAU.clb Readiness: 079-907-560-CAU.crd -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Control Module Part Number: 8T0 907 560 AD Component and/or Version: 4.2l V8/4V H22 0001 Software Coding: 01140009190F0120 Work Shop Code: WSC 06325 VCID: 7CA1F72B26E55D37969-8028 Advanced Identification Identification: BPG-810 Revision: 76H22--- Date: 23.11.10 Manufacturer number: 1480 Test stand number: 0512 Flash Status Programming Attempts(application): 0 Successful Attempts(application): 0 Programming Status: 00000000 Flash Tool Code: 00000 000 00000 Misc. Hardware number: 8T0 907 560 Workshop System Name: J623 Car Info Chassis Number: WAU3VAFRXBA009762 Engine code: CAUB VCDS Info: VCID: 7CA1F72B26E55D37969-8028 Labels: 079-907-560-CAU.clb Readiness: 079-907-560-CAU.crd -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 079-907-560-CAU.clb Control Module Part Number: 8T0 907 560 AD HW: 8T0 907 560 Component and/or Version: 4.2l V8/4V H22 0001 Software Coding: 01140009190F0120 Work Shop Code: WSC 06325 000 00000 VCID: 7CA1F72B26E55D37969-8028 1 Fault Found: 049409 - No Communication with Transmission Control Module U0101 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:53 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 24.0°C Temperature: 39.0°C Absolute Pres.: 980.0 mbar Voltage: 11.811 V Readiness: 0110 1101 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Control Module Part Number: 8T0 907 560 AD Component and/or Version: 4.2l V8/4V H22 0001 Software Coding: 01140009190F0120 Work Shop Code: WSC 06325 VCID: 7CA1F72B26E55D37969-8028 Advanced Identification Identification: BPG-810 Revision: 76H22--- Date: 23.11.10 Manufacturer number: 1480 Test stand number: 0512 Flash Status Programming Attempts(application): 0 Successful Attempts(application): 0 Programming Status: 00000000 Flash Tool Code: 00000 000 00000 Misc. Hardware number: 8T0 907 560 Workshop System Name: J623 Car Info Chassis Number: WAU3VAFRXBA009762 Engine code: CAUB VCDS Info: VCID: 7CA1F72B26E55D37969-8028 Labels: 079-907-560-CAU.clb Readiness: 079-907-560-CAU.crd -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FR-AU48 (8T0) Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F 6C VIN: WAU3VAFRXBA009762 Mileage: 192610km-119682miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAUB) Labels:. 079-907-560-CAU.clb Part No SW: 8T0 907 560 AD HW: 8T0 907 560 Component: 4.2l V8/4V H22 0001 Revision: 76H22--- Coding: 01140009190F0120 Shop #: WSC 06325 000 00000 VCID: 7CA1F72B26E55D37969-8028 1 Fault Found: 049409 - No Communication with Transmission Control Module U0101 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 04:50:03 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 23.0°C Temperature: 32.0°C Absolute Pres.: 980.0 mbar Voltage: 11.811 V Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ Component: ESP8 quattro H04 0050 Revision: -------- Serial number: -------------- Coding: 110D18 Shop #: WSC 46268 003 1048576 VCID: 025D89D344012BC7DC5-8056 2 Faults Found: 02757 - Learning Tire Pressures 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:53 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0282 Hex Value: 0x0037 Hex Value: 0x3993 Hex Value: 0x00FF 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:55 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0782 Hex Value: 0x0032 Hex Value: 0x0293 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG Component: BCM2 2.0 H04 0430 Revision: 00002001 Coding: 0F0000 Shop #: WSC 06325 000 00000 VCID: 77ABE8071FC37E6FFBB-8022 Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 0210000112900006 No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb Part No SW: 8T0 959 760 C HW: 8T0 959 760 C Component: MEM-BFS H10 0074 Revision: AA000000 Serial number: 00001010182726 Coding: 00017025002C00000000 Shop #: WSC 46268 003 1048576 VCID: 43D34CD71B9BE2CF973-8016 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component: KLIMA 3 ZONEN H08 0180 Revision: C1000000 Serial number: 01240620100280 Coding: 48122000 Shop #: WSC 06325 000 00000 VCID: 005983DB4A0D39D7CA1-8054 1 Fault Found: 01206 - Signal for Duration of Ignition Off Time 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:52 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H29 0392 Revision: 10029001 Serial number: 00000000576354 Coding: 26001091063CAF010000080300003D3D0F1C13880201016100 0000 Shop #: WSC 46268 003 1048576 VCID: 3C21372B66659D37D69-8068 Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB Component: WWS 260610 H14 0070 Serial number: SWF10060265537 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10963949 Coding: 02532C Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN Component: E1 - LDS H08 0090 Serial number: 00000000001606101989 2 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:00 02258 - Door Opener Transmitter 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:00 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 Q HW: 8K0 919 475 Component: PARKHILFE 4K H06 0070 Revision: 11001001 Serial number: 51241018214386 Coding: 200002 Shop #: WSC 46268 003 1048576 VCID: 47CB58C72FA3CEEF4BB-8012 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 K HW: 8K0 959 655 K Component: AirbagVW-AU10 H41 0610 Serial number: 003GLD0G89YY Coding: 303338334330303030304A55304C38543053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 45D752CF152FDCFFB97-8010 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A Component: BF-Gewichtss. H02 0060 Serial number: 5810000R1000000EEE Crash sensor for side airbag: driver side: Serial number: 6334MSME550266748 Crash sensor for side airbag: front passenger side: Serial number: 6344MSME55326646B Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME3F59513CU Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME42532B049 Crash sensor for front airbag: driver side: Serial number: 63732SME13624304M Crash sensor for front airbag: front passenger side: Serial number: 63832SME61654820W No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8R0 953 568 K HW: 8R0 953 568 K Component: Lenks.Modul H06 0156 Revision: 00000000 Serial number: 20100702000181 Coding: 000016 Shop #: WSC 46268 003 1048576 VCID: 49CF5EFF39B7389F5DF-801C Component: E221 - MFL H02 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8T0 920 983 D HW: 8T0 920 983 D Component: KOMBIINSTR. H38 0258 Revision: 00000000 Serial number: EI118ZU5A Coding: 8B1501000300D705020000 Shop #: WSC 46268 003 1048576 VCID: 3FDB40277773862FF3B-806A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0117 Revision: EC000056 Serial number: 5600E1061400B5 Coding: 00C303 Shop #: WSC 06325 000 00000 VCID: 03538CD75B1B22CFD73-8056 Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H07 0170 Serial number: 10020AEB180610 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8T0 959 760 C HW: 8T0 959 760 C Component: MEM-FS H10 0074 Revision: AA000000 Serial number: 00001010182838 Coding: 00197B25002C00000000 Shop #: WSC 46268 003 1048576 VCID: 43D34CD71B9BE2CF973-8016 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8T0 959 793 M HW: 8T0 959 793 D Component: TSG FA H08 1401 Revision: -------- Serial number: -------------- Coding: 011C13224E00120102 Shop #: WSC 46268 003 1048576 VCID: 53F37C97EBFB724F273-8006 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG Component: BCM2 2.0 H04 0430 Revision: 00002001 Serial number: 0132032189 Coding: 0106029A00FA444580B0003200000000 Shop #: WSC 06325 000 00000 VCID: 77ABE8071FC37E6FFBB-8022 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J245EE20SKB13 H02 0220 Serial number: 0123456789ABCDEFGHIJ 1 Fault Found: 03233 - Controls for Garage Door Opener (E284) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:56 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK Component: DSP Prem H10 0190 Revision: 00010001 Serial number: 34882003220401 VCID: 7AADF1332CD16307845-802E No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8T0 959 792 M HW: 8T0 959 792 D Component: TSG BF H08 1401 Revision: -------- Serial number: -------------- Coding: 011C13224E00120102 Shop #: WSC 46268 003 1048576 VCID: 52FD7993D4E17B472C5-8006 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 00000000677599 Shop #: WSC 00000 000 00000 VCID: 34311F0B4E3555771E9-8060 1 Fault Found: 01315 - Transmission Control Module 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 89 Mileage: 192618 km Time Indication: 0 Date: 2010.02.02 Time: 01:59:52 Freeze Frame: Voltage: 11.80 V Count: 66 Speed: 0.0 km/h Hex Value: 0x0270 Hex Value: 0x0001 Hex Value: 0x0101 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 B Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000002 Shop #: WSC 06325 000 00000 VCID: 392F2E3F6557A81FCDF-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 HW: 4G0 035 082 Component: Radio U SIRIU H51 0052 Revision: AB001007 Serial number: 471FO0A7512510 Coding: 020007010000000001 Shop #: WSC 06325 000 00000 VCID: 5DE79AAF9D3FB43F817-8008 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8T1 035 664 C HW: 8T1 035 664 B Component: H-BN-NA H49 0116 Revision: -------- Serial number: 490G%0A7573636 Coding: 010200020206A1EF41000B0E000000030000 Shop #: WSC 06325 000 00000 VCID: 38292B3B525DB117321-806C Subsystem 1 - Part No: 8R0 060 884 P Component: NAR 2010 0407 Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604 Component: DU7 High H42 0094 Serial number: 9466GR0A0031771 Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G Component: E0380 Bedient H08 0100 Serial number: 00000000574669 Subsystem 4 - Part No: 8R0 060 961 Component: CD-Database 1886 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H04--- Serial number: 525PA8-J0491XW Coding: 1000008 Shop #: WSC 06325 000 00000 VCID: 38292B3B5E5DB117321-806C No fault code found. End----(Elapsed Time: 01:25, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)----- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/000/00000), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/000/00000), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140109180F0120, (06325/123/12345), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140109180F0120, (06325/123/12345), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140109180F0120, (06325/0/00000), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140109180F0120, (06325/0/000000), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/000/00000), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/000/00000), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/0/00000), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/0/000000), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/97/997), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/000/00000), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/000/00000), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009190F0120, (06325/123/12345), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/123/12345), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009000F0120, (06325/123/12345), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009200F0120, (06325/123/12345), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009170F0120, (06325/123/12345), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009190F0120, (06325/123/12345), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009980F0120, (06325/123/12345), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19: CAN Gateway Control Module Part Number: 8T0 907 468 AD Component and/or Version: GW-BEM 4CAN-M H09 0117 Software Coding: 00C303 Work Shop Code: WSC 06325 VCID: 03538CD75B1B22CFD73-8056 History Data Record 1/16: No-load voltage underranging 2019-02-18-07:55*16.7*02*08050*** 2019-02-17-07:55*24.0*02** 2019-02-16-07:55*24.0*02** 2019-02-15-07:55*24.0*02** 2019-02-14-07:55*24.0*02** 2019-02-13-07:55*24.0*02** 2019-02-12-07:55*24.0*02** 2018-11-11-11:55*13.3*02*00468*** 2018-11-10-11:55*24.0*02** 2018-11-09-11:55*24.0*02** 2018-11-08-11:55*24.0*02** 2018-11-07-11:55*24.0*02** 2018-11-06-11:55*24.0*02** 2018-11-05-11:55*24.0*02** 2018-10-27-16:49*00.0*02*00000*** 2018-10-23-14:48*00.0*02** 2000-01-01-00:00*00.0*00** 2000-01-01-00:00*00.0*00** 2000-01-01-00:00*00.0*00** 2000-01-01-00:00*00.0*00** 2000-01-01-00:00*00.0*00** Record 2/16: No-load current overranging 2010-02-04-23:34*0004*052*-00.25*0-0-0-0-0-0*0*02*00004** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** Record 3/16: Shut-off stage history 2010-07-31-13:13*1*0*026*005*-10.56*0-0-0-0-0-0*0*0*00.0*00.0** 2010-07-31-07:23*1*0*026*004*-10.22*0-0-0-0-0-0*0*0*00.0*00.1** 2010-07-31-07:20*1*0*027*004*-10.80*0-0-0-0-0-0*0*0*00.0*00.0** 2010-07-31-07:16*1*0*027*005*-11.95*0-0-1-0-0-0*0*0*00.0*00.0** 2018-10-27-16:58*3*0*009*000*-06.64*0-0-0-0-0-0*0*0*00.0*00.3** 2018-10-27-16:57*1*0*011*000*-06.86*0-0-0-0-0-0*0*0*00.0*00.2** 2018-10-27-16:51*3*0*012*000*-07.03*0-0-0-0-0-0*0*0*00.0*00.2** 2018-10-27-16:51*1*0*013*000*-07.26*0-0-0-0-0-0*0*0*00.0*00.2** 2018-10-26-21:29*3*0*010*000*-06.60*0-0-0-0-0-0*0*0*00.0*00.2** 2018-10-26-21:28*1*0*011*000*-07.35*0-0-0-0-0-0*0*0*00.0*00.2** 2018-10-24-08:37*3*0*015*000*-04.56*0-0-0-0-0-0*0*0*00.0*00.1** 2018-10-24-08:36*1*0*015*000*-07.20*0-0-0-0-0-0*0*0*00.0*00.1** 2018-10-24-08:33*1*0*016*000*-06.55*0-0-0-0-0-0*0*0*00.0*00.1** 2018-10-24-08:21*3*0*021*000*-05.68*0-0-0-0-0-0*0*0*00.0*00.0** 2018-10-24-08:20*1*0*021*000*-07.24*0-0-0-0-0-0*0*0*00.0*00.0** Record 4/16: Battery change history 2010-01-22-00:07*02*000915105DL*VAO*331121L2GD*09891*09168*00 00*0000*0000** 2010-07-07-02:37*01*8K0915105F *VA0*300629T0QG*10004*05649*0000*0000*0000** 2000-01-01-00:00*00*-----------*XXX*----------*09999*00000*0000*0000*0000** 2000-01-01-00:00*00*-----------*XXX*----------*00000*00000*0000*0000*0000** 2000-01-01-00:00*00*-----------*XXX*----------*00000*00000*0000*0000*0000** Record 5/16: Energy-critical vehicle states 2018-10-23-13:54*+00.00*-11.81*-69.17*10.12*000*09*+00.0*08143*09980* 187719*0-0-0-0-0-0*0*00.0*00.0*000.0*00*01*01** 2013-05-05-21:02*-00.23*-00.52*-03.20*11.73*000*09*-15.2*03905*09945* 040914*0-0-0-0-0-0*0*00.0*00.6*029.1*43*00*01** 2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*0000 0*00000* 000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00** 2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*0000 0*00000* 000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00** 2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*0000 0*00000* 000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00** Record 6/16: Energy balances (last 20 trips) 2010-01-29-03:50*038*+32*-005.9*00.08** 2010-01-24-05:48*066*+27*-000.3*00.00** 2010-01-23-00:29*041*+23*-004.9*00.06** 2010-01-22-21:57*052*+18*-001.8*00.02** 2010-01-22-00:47*100*+23*+000.0*00.01** 2010-01-22-00:34*100*+22*-000.1*00.00** 2010-01-22-00:04*100*+22*-002.4*00.03** 2010-01-22-00:00*100*+26*-000.1*00.00** 2010-08-28-12:29*004*+20*-001.3*00.02** 2010-08-28-12:26*004*+20*-002.1*00.03** 2010-08-28-09:13*005*+17*-004.8*00.07** 2010-08-27-22:03*017*+23*-001.4*00.02** 2010-08-27-21:50*017*+23*-016.7*00.21** 2010-08-27-21:12*047*+21*-000.1*00.00** 2010-08-27-21:05*049*+21*-000.1*00.00** 2010-08-27-20:55*044*+21*-000.2*00.00** 2010-08-27-20:54*047*+21*-000.1*00.00** 2010-08-27-20:50*051*+21*+001.5*00.04** 2010-08-27-12:39*058*+17*+000.2*00.04** 2010-08-25-02:00*065*+27*+004.4*00.65** Record 7/16: Energy balances (last 20 standing times) 2010-02-02-04:53*027*-001.9*000.1*00.1*00.1** 2010-02-02-04:23*027*-004.6*000.4*00.3*00.3** 2010-02-02-04:20*032*-000.4*000.0*00.0*00.0** 2010-02-02-02:01*034*-001.1*002.2*00.0*00.0** 2010-02-02-01:55*036*-001.2*000.1*00.1*00.1** 2010-02-02-01:38*037*-003.2*000.2*00.2*00.2** 2010-02-02-01:37*040*-000.1*000.0*00.0*00.0** 2010-02-02-01:35*040*-000.4*000.0*00.0*00.0** 2010-02-02-01:23*041*-002.2*000.1*00.1*00.1** 2010-02-01-23:50*043*-002.3*001.4*00.1*00.0** 2010-01-29-03:55*046*-002.4*091.4*00.0*00.0** 2010-01-24-05:49*060*-006.7*117.4*00.1*00.0** 2010-01-24-05:15*071*-004.3*000.5*00.5*00.1** 2010-01-23-04:15*075*-006.6*024.7*00.6*00.5** 2010-01-23-00:33*086*+018.5*003.6*00.2*00.2** 2010-01-22-21:59*044*-010.2*002.4*00.4*00.1** 2010-01-22-06:12*076*-000.8*015.6*00.0*00.0** 2010-01-22-04:54*100*+003.9*001.2*00.0*00.0** 2010-01-22-04:35*100*-000.5*000.2*00.0*00.0** 2010-01-22-02:35*100*+002.2*001.9*00.3*00.3** Record 8/16: Battery manipulation (e.g. charging) 2010-01-23-04:15*1*36*27*00*09*2000-01-01-00:00*02** 2010-01-23-04:15*1*35*27*00*09*2000-01-01-00:00*02** 2010-01-23-02:39*1*34*27*00*09*2000-01-01-00:00*02** 2010-01-23-02:24*1*33*27*00*09*2000-01-01-00:00*02** 2010-01-22-06:12*1*32*27*00*09*2000-01-01-00:00*02** Record 9/16: Battery aging 2018-10-17-22:07*053*077*071*051*08102*12.40*+23*02** 2018-10-03-21:22*053*077*069*050*08050*12.40*+24*02** 2018-09-20-08:48*053*075*070*049*07995*12.40*+21*02** 2018-09-06-01:23*053*077*079*062*07936*12.50*+26*02** 2018-08-21-22:06*053*075*080*066*07863*12.50*+31*02** 2018-08-07-21:31*053*076*077*067*07805*12.50*+38*02** 2018-07-24-08:50*053*076*081*068*07749*12.50*+31*02** 2018-07-10-07:07*053*082*076*062*07669*12.40*+29*02** 2018-06-27-02:20*053*076*080*063*07595*12.50*+26*02** 2018-03-26-09:41*053*078*072*038*07432*12.40*+09*02** 2018-03-05-08:28*053*073*056*018*07388*12.20*+05*02** 2018-01-20-16:21*053*072*081*047*07316*12.50*+11*02** Record 10/16: Dynamic energy management 2010-01-29-03:55*1*001.0*1*003.3*00.08** 2010-01-23-00:33*1*001.0*1*002.5*00.06** 2010-01-22-21:59*1*001.0*1*000.1*00.02** 2010-01-22-00:48*1*000.1*0*000.0*00.01** 2010-01-22-00:06*1*001.0*1*000.6*00.03** ; 2010-08-27-22:03*1*0*0*00.21** 2000-01-01-00:00*0*0*0*00.00** 2000-01-01-00:00*0*0*0*00.00** 2000-01-01-00:00*0*0*0*00.00** 2000-01-01-00:00*0*0*0*00.00** ; 2010-01-29-03:55*2*004.3*00.08** 2010-01-23-00:33*2*003.4*00.06** 2010-01-22-21:59*2*001.1*00.02** 2010-01-22-00:48*2*000.1*00.01** 2010-01-22-00:06*2*001.6*00.03** Record 11/16: Recuperation 2014-12-10-17:34*000*000*057*000*0249*071*00.1*00.6*090*076*0 90*077*02*00342*00379*00027*00739*01601** 2014-12-10-17:11*000*000*007*000*0008*064*00.0*00.0*090*076*0 90*076*02** 2014-12-08-15:05*000*000*000*000*0000*000*00.0*00.0*090*076*0 90*074*01** 2014-12-08-10:45*000*000*005*040*0063*047*00.0*01.1*090*074*0 91*076*01** 2014-12-08-08:46*000*000*022*000*0149*029*00.0*01.1*090*073*0 91*075*01** 2014-12-08-08:11*000*000*000*007*0014*008*00.0*00.4*090*072*0 90*073*01** 2014-12-08-07:49*000*000*001*009*0002*010*00.0*00.3*090*073*0 90*073*01** 2014-12-07-20:29*000*000*016*000*0052*017*00.0*00.8*095*076*0 96*079*01** 2014-12-07-19:15*000*000*022*000*0068*023*00.0*01.0*095*075*0 96*079*01** 2014-12-07-18:49*000*000*021*000*0090*023*00.0*01.2*095*075*0 96*079*01** Record 12/16: Start-Stop 2000-01-01-00:00*0-0-0-0-0-0-0-0** 2000-01-01-00:00*0-0-0-0-0-0-0-0** 2000-01-01-00:00*0-0-0-0-0-0-0-0** 2000-01-01-00:00*0-0-0-0-0-0-0-0** 2000-01-01-00:00*0-0-0-0-0-0-0-0** 00000*00000*00000*00000*00000*00000*00000*00000** ; 2000-01-01-00:00*0-0-0-0-0-0-0-0** 2000-01-01-00:00*0-0-0-0-0-0-0-0** 2000-01-01-00:00*0-0-0-0-0-0-0-0** 2000-01-01-00:00*0-0-0-0-0-0-0-0** 2000-01-01-00:00*0-0-0-0-0-0-0-0** 00000*00000*00000*00000*00000*00000*00000*00000** ; 2010-02-02-05:06*1*042*027*+23*04*-030*-21.11*11.7*0** 2010-02-02-05:05*1*042*027*+23*04*-030*-22.24*11.6*0** 2010-02-02-05:05*1*042*027*+23*04*-030*-11.82*11.7*0** 2010-02-02-04:53*1*044*027*+23*04*-030*-11.71*11.8*0** 2010-02-02-04:53*1*044*027*+23*04*-030*-13.04*11.7*0** 09218*00000*00000** Record 13/16: Sporadic alternator faults 2014-07-08-16:52*1-0-1-0-1*000.0*00007** 2014-07-08-16:52*1-0-1-0-0*000.0** 2014-07-08-16:52*0-0-1-0-0*000.0** 2014-05-02-13:47*1-0-1-0-1*000.8** 2014-05-02-13:21*1-0-1-0-1*000.4** Record 15/16: Local activ. 2010-07-18-13:32*05f*44*00*000*00*00*000*00*00** 2010-07-07-23:04*05f*43*00*000*00*00*000*00*00** 2010-02-03-17:12*05f*42*00*000*00*00*000*00*00** 2018-10-27-16:58*05f*41*00*000*00*00*000*00*00** 2018-10-27-16:51*05f*40*00*000*00*00*000*00*00** 2018-10-10-06:35*05f*39*00*000*00*00*000*00*00** 2010-03-17-07:54*05f*38*00*000*00*00*000*00*00** 2010-02-15-04:22*05f*37*00*000*00*00*000*00*00** 2017-12-10-16:25*05f*36*00*000*00*00*000*00*00** 2017-11-28-02:23*05f*35*00*000*00*00*000*00*00** Record 16/16: Vehicle energy balance 192618** 08453*05019*01649*00174*00058** 14983*00150*00047*00014** 21842*18010*00283*00000** 02718*04335*03627*04012** 06964*05926*01802** 00000*00000*00000*00000** 18513*00889*00218*00011** 05775*00047*00007** 00000*00000*00000** 00032*00000*00001** 00000*00000*00000*00000*00000*00000*00000*00000*00 000*00000** -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- VCDS Release 19.6.0: SRI Reset Control Module Part Number: 8T0 920 983 D Labels: .8T0-920-xxx-17.clb Component:KOMBIINSTR. H38 0258, Coding:8B1501000300D705020000 Operation: Please select an operation ************************************************** ************************************************** ******************** Channel Description Unit Current val. New val. 02 Service Reminder Status 2 --- 40 Distance since Service km x100 82 --- 41 Time since Service Days 365 --- 42 Minimum Distance to Service km x100 150 --- 43 Maximum Distance to Service km x100 150 --- 44 Maximum Time to Service Days 365 --- 45 Oil Quality 1 --- 47 Soot Quantity DIST x100 17 --- 48 Thermal Load DIST x100 187 --- 49 Minimum Time to Service Days 365 --- 50 Basic Distance Value for Oil Change km x100 160 --- 51 Basic Time Value for Oil Change Days 0 --- 52 Basic Distance Value for Inspection km x100 160 --- 53 Distance since Inspection km x100 87 --- 54 Basic Time Value for Inspection Days 365 --- 55 Time since Inspection Days 395 --- 56 Day Counter Days 3239 --- ************************************************** ************************************************** ******************** -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/123/12345), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19,8T0 907 468 AD,channel 1,adapted from,0,to,1, -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Activating transport mode...Done. -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 19,8T0 907 468 AD,channel 1,adapted from,1,to,0, -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- De-activating transport mode...Done. Does anyone know how to get the security access key? What version of immoilibzer was used on these batch of s5's? |
