Fuel injector pigtail replacement - B6 S4
2 Attachment(s)
When I was replacing the valve cover gaskets on my 2004 S4, I accidentally broke one of the connectors to my fuel injectors on the passenger bank. It gave me a misfire, and I tracked it to cylinder 2, and then found that to be the problem. As I removed the harness to get to it, I broke 2 other plugs, so I need to replace all 4. I bought some at Napa that they had listed for the car, but they are rectangular instead of oval shaped and will not fit.
I am having such a hard time finding replacement plugs/pigtails to buy. The part number on the plug is 06A973733 and 6289-0785, which doesn't yield much in the way of results. I imagine this is a commonly used injector and maybe I can use a universal plug if it matches exactly. I'm going to have to solder it in anyway. Anyone else have this issue? |
