Anyone try clutch-less shifting on the A4? Wondering about technique/uses.
I'm curious, why would you even ask the question?
i wouldnt wonder about this...period...
sure... you will also get a chance to try a new clutch and tranny.
That's a good idea......
I do it all the time!
but then again... I have a tiptronic!
heehee ;-) |
You do clutch pedal-less shifting... not clutchless...
Actually, IIRC, the ZF tranny has no clutch plates at all.
I have...
I drove a Golf and the clutch got stuck - stuck as in permanently engaged.
That's what I did: I turned the motor off and put in the first gear. I turned the ignition key and the car started moving (it wasn't pretty). At about 1000 RPM I got off the gas and shifted (without clutch!) into neutral. I got off the gas and pulled the stick back towards second gear. When engine and transmission RPM were the same, the second gear engaged. With that method I got the car also into third gear. But I couldn't go faster than 30 mph or so, and it was a tad unsettling. :-P |
Re: I did it yesterday ...no biggie
