Found Oil Around Spark PLUGS ???
While checking the spark plugs on a Audi A4 B5 1999 1.8 20V petrol i found oil around the holes of the spark plugs is that a problem or should i lokk further into it any help thanks???
Leaking valve cover gaskets. Very common, DD.
Thank you very much for the reply :D
*sold my '82 Coupe GT w/ 225k miles
next owner added ~50k miles miss the GT |
From experience, the leakage is often caused by overpressure under the valve covers and this is related to clogged breather tubes. The culprit is often the valve referred to as a suction pump. It's a cheap ($14) part that should be replaced when you do the valve cover and cam gaskets. There are myriad writeups regarding this service on the site.
