Help with Thermostat issues!!! New Member
I have an 01 A4 1.8T. The thermostat gauge sits at cold, intermittently, and I get heat out of the vents. I was thinking that it could be a sending unit or gauge. I would like to test the senors/sending units but dont know were they are at. Can anyone help me...Thanks.
Hope to be on here more |
Originally Posted by jhawkaudi
(Post 23926446)
Hope to be on here more In another thread, I shared pictures since mine was the originial from a 98 A4 2.8. .now the temp sensor seems very accurate and moves right on up! |
were is it at in on the tech side. I looked for it and could not find it.
(Post 23927070)
AutohausAZ has a good price on a new one. http://www.autohausaz.com/search/pro...ender%20Switch |
(Post 23926446)
Hope to be on here more Some people mentioned getting a replacement clip, make sure you remove the old o-ring and replace it also. It could also be your thermostat, you will still get warm air if it's stuck open. The heater should be HOT at normal temp, OEM thermostats tend to fail open, aftermarket fail closed. If if it is the thermostat don't leave it too long as it will cause the car to run rich. |
Here are the tech write ups for him on replacing the two sensors https://www.audiworld.com/tech/eng66.shtml
https://www.audiworld.com/tech/eng54.shtml |
