How do I realign my throttle body using a VAG?
I don't have a VAG, but I am goign to borrow one soon.
just put your key in the ignition... turn to the accessory position
and wait two minutes. No need for a vag
I've been doing that, but a tuning company said it needs to be done w/ a VAG b/c it threw a code.
I believe it's "Basic Settings"...enter "060"...click "go".
I think you misunderstood them...slightly...
Running the throttle adaptation will clear some values stored in memory in the ECU...so there is probably a good reason they asked you to do this.
Additionally, I would also go to the engine section, and hit "clear fault codes"...even if no codes are present. That should give you a fresh start. |
I had to send my ECU to them to fix something. They said they cleared all the codes except this one
b/c they needed the actual car to be able to fix it. Told me to go to a mechanic and tell them to do it w/ a VAG. But then again, I don't believe a lot of what they say anyway.
Thanks for the info! |
Go to measuring block 060, switch to basic setting and let it run, then switch back.
See this page:
<ul><li><a href="http://www.ross-tech.com/vag-com/cars/throttlebody.html">http://www.ross-tech.com/vag-com/cars/throttlebody.html</a</li></ul>
