How do I realign my throttle body using a VAG?
I think you misunderstood them...slightly...
Running the throttle adaptation will clear some values stored in memory in the ECU...so there is probably a good reason they asked you to do this.
Additionally, I would also go to the engine section, and hit "clear fault codes"...even if no codes are present. That should give you a fresh start.
I had to send my ECU to them to fix something. They said they cleared all the codes except this one
b/c they needed the actual car to be able to fix it. Told me to go to a mechanic and tell them to do it w/ a VAG. But then again, I don't believe a lot of what they say anyway.
Thanks for the info!
See this page:
<ul><li><a href="http://www.ross-tech.com/vag-com/cars/throttlebody.html">http://www.ross-tech.com/vag-com/cars/throttlebody.html</a</li></ul>
Andy
Andy
Dan McBoost
09-07-2006 06:42 PM
silversleeper
10-30-2001 07:02 AM
letS4nicate
06-22-2001 01:00 PM
