New chipped ECU need help
got it today
put in it , turned key in on for 3-5 min then start CEL light is on leave it run for around 5 min shut off still on Help me ps. does this sound rght for a neuspeed 1 bar before chip 7psi spike down to 5psi neuspeed 13psi spike down to 10psi |
Boost about right. Did you recode ECU?
recode why? came out of a 1.8TQM and thats what I have
you shouldn't have gone cheap, my only advice
Me thinks tis better to have a local tuner who can trouble shoot than to save money and be SOL all alone.
What year is yours and what is the new one from?
Do both ECU part #'s match?
ECU codes matched perfect but mine is 97 his 99
Better get a vag by someone dont think the codes are the same.
what sort of thing am I looking to change if I can borrow a VAG?
Some have posted that the other ndbw ecu's did not work in their 97.
You ought to throttle adapt it using a vag. I had the same thing with an apr chip...
once I throttle adapted it with a vag, it was just fine. I believe that you adapt with block 98.
