One more question
What is the difference with the S4 wheel liners? Why are they a desired mod? How much and how easy to install? Thanks again.
I really don't know, you must search the tech section...
...and look at some pics.
that's a "Body look" mod, I don't want to modify my A4 body |
it let the hot air in around your turbo..
to excape in the shortest route
also to induce air flow so the IC cools better |
It doesnt modify the "body look." The S4 liners are vented to allow more air in.
Re: it let the hot air in around your turbo..
I was looking into this mod myself. Is the main reason for the intercooler? Are both sides needed for the A4? I figured that since the S4 is twins that maybe only the drivers side was truly needed for the A4. (Given my 4-day old knowledge of the car, it looks like that is the intercooler that sits in front of the drivers front wheel well?)
it's a fender liner. sits inside the wheel well. it has vents to release hot...
air from around the intercooler. i did mine about a month ago. took about 10 mintues total time. it's cake. do it!
mike frazer '97 a4 1.8tqms cactus green |
you only need the driver's side. the intercooler sits in front of...
the left front wheel. it's $32 from clair parts.
actually, it does nothing to relieve hot air around your turbo...
i guess it might do that a bit should you replace the passenger side liner, but the main purpose is to help cool the air around the intercooler.
mike frazer '97 a4 1.8qms cactus green |
s4 fender liner...lines passenger side...doesnt do much, just allows more air to come in the engine.
right below the turbo...which will add some cooling effect i believe.
2001 1.8tqm autothority chip. k&n filter. greddy exhaust. s4 fender liner. omp strut bar. eibach prokit. kamei front grill. |
