:: ECS Tuning :: NEW!! B7 A4 2.0T ECS Baffled Oil Catch Can
http://www.ecstuning.com/sales/ecs600header.jpg
Introducing ECS Tuning's newest release, the Performance Baffled Oil Catch Can System, engineered in-house and manufactured in the USA. Our system was designed with the consumer in mind to provide effortless installation with no necessary modifications to be a perfect fit for your 2.0T. With no required modification, this performance system is also fully reversible and even fits beneath the factory engine cover! Today's direct fuel injection systems have taken engine performance to a whole new level, but there is a drawback. Without fuel vapor to help clean the intake valves, the oil particles that are drawn into the intake from the PCV system will deposit themselves onto the valves and intake ports. Over time this will result in increased levels of carbon buildup which can hinder performance and fuel economy. Key benefits of the ECS Baffled Oil Catch Can System: Highly Efficient Oil Separator (Catch Can)
Billet machined FSI Adapter Plate
Most catch cans replace of the factory PCV (positive crankcase ventilation) system, however the ECS Tuning Performance Baffled Oil Catch Can System utilizes key components of the OEM PCV system to expand on it's efficiency by retaining ultra-fine oil vapor that has already passed through the factory fine oil separator. This also provides the benefit of not having to empty the oil can catch as often as other systems on the market, since the oil vapor will be filtered through two components before reaching the intake tract. Although the OEM PCV system performs well and meets emissions standards, installing ECS Tuning's Performance Baffled Oil Catch Can System will increase efficiency of the PCV system and keep the ultra-fine oil vapor contained in the blow-by gases from entering your intake system and causing excessive power loss and carbon buildup. Each system includes the following:
Nice Catch! Click HERE to order or for more information http://www.ecstuning.com/marketing/A...atchCan_01.jpg Fits: Audi B7 A4 2.0T (2005.5–2008) Be sure to check out our -----> Installation PDF |
