Need Help! Who has an ENERTEC Battery?
Hello Guys,
It seems that Audi in Canada only has ENERTEC batteries in stock! the problem is I can't find the ENERTEC vendor code and I can't code it. It also doesn't have a BEM code. If someone has an ENERTEC battery that is the original battery or was done by the dealer (coded properly). Can you please do a scan to see what your code is and post a picture of your QR bar code. Thank you! http://img560.imageshack.us/img560/3976/backfjm.jpg This can be found here VCDS (screen 19-CAN@gateway _> Long Adaptation -> Channel 4 -> Battery identification) http://img545.imageshack.us/img545/2...yaftersave.jpg The only thing i need is the middle code for battery Vendor. it is NOT EMC as the car won't accept that. https://dl.dropboxusercontent.com/u/...2011.33.27.jpg THANK YOU! |
Enertec is part of Johnson Controls.
The QR code label is typical of JCI batteries. JCI also owns Varta automotive. Try the Varta code VA0 (V-A-Zero) and the serial number on the QR (10 digits)label. Good Luck. |
Originally Posted by Moviela
(Post 24545060)
The QR code label is typical of JCI batteries. JCI also owns Varta automotive. Try the Varta code VA0 (V-A-Zero) and the serial number on the QR (10 digits)label. Good Luck. If it's Johnson Control wouldn't it be JCB? Decoding the QR Code I got 205# 000 915 105 DH #0803800 #588119201#27081134*205 EMC318R25U/*= 99{40@85m |
Your part number is 13 digits 8K0915105DH. The QR shows 000 instead of 8K0 because the battery goes in other car lines of the VW group. You can use VA0 for Varta, or JCB for Johnson Controls International. The Serial is EMC318R25U (ten places.)
Your software might be hard coded to accept only certain known to Ross-Tech, where the workshop VAG system could have been updated to accept parts sold in Canada. I'd give Ross-Tech a call if you are still having problems, and refer them to this thread. |
One more please.
http://img560.imageshack.us/img560/3976/backfjm.jpg Decoding the QR Code I got 205# 000 915 105 DH #0803800 #588119201#27081134*205 EMC318R25U/*= 99{40@85m What should I put in VCDS? it is an Enertec Battery |
Hi there sdf1. I know you posted this about 9yrs ago about you having an issue with coding the vendor EMC that doesnt work, did you ever get a fix for this? I am from Canada as well and came across the same issue, just wondering if you ever got a fix for it, thanks
