Stuck on Audi Infotainment System A4 B8 2012
Hello there,
Looking for a bit of a help here. So recently I just spilled water on the heated seat and basically ruined it. Took it to a shop and they replaced it with a genuine part and all is working except this thing. Usually after the car started up, it would start with the Audio Infotainment System then would just continue to the radio - or the last mode it was on. But now it is stuck on this screen! I can then click on the radio or the power on/off button and everything will work fine. The other issue it caused is that the home coming/ leaving light is no longer work too even though all the setting is there. Also the key memory seat is not working as well - as is the key 1 and key 2. the seat memory is still there if I click the button on the driver's side panel. Let me know if anyone have any idea what could be the problem! I have vagcom so i can check few things. Thank you! The technician said that we can try to re-flash the radio, but it'll cost $160! Anyone know how to re-flash the radio??? https://cimg4.ibsrv.net/gimg/www.aud...ea7622ac53.jpg |
