Brushed aluminum dashboard trim
The car was delivered with a bit of a mark/discoloration on the front dashboard trim on a Sport Plus manual. It was a bit yellowish, and I could feel a different texture. No biggie, I figured I'd have it looked at. Today, months later, the dealer took adhesive to it. No-go. I tried alcohol. No-go.
I'm going to talk to the service department next week at the first oil change (5,000 miles). I'm guessing it's a fluke, but figured I'd check. Anyone else have any weird goings-on with their trim piece? Is it easily replaced if it continue to drive me nuts? |
Originally Posted by ptmdsharp
(Post 25121867)
Oops, those photos are ginormous. Anyway, the stain started off with a yellowish tint, and I could rub my finger on it and get a reaction. So it felt like there was a film of some sort. The dealer applied adhesive remover, which had no effect other than to remove the yellowing. It almost appears as if the finish is gone, making it shiny.
Yeah they no basically removed any protective layer it had. It will look crappy and dull in the near future. Make sure to keep all your documentation and tell them that you want it replaced. If they can't do it locally, ask them if they would please go through Audi USA. If not, just do it yourself and explain the situation. I would also point out that your local audi dealer was unwilling to help you out in this matter if it comes to that.
Yes, take it back to the dealer and request that the trim be replaced. This is a flaw that should be repaired via the warranty.
(Post 25121867)
Actually, I didn't want aluminum ... I wanted dark walnut wood. But the car my dealership found met all of my requirements -- except the wood. https://cimg7.ibsrv.net/gimg/www.aud...64aaec8978.jpg . . . |
It's covered in diagonal scratches, and much of the horizontal machine brushing in the affected area appears to have been rubbed out. The dealer, presumably, has done more than just apply adhesive remover. Unless they did so with a steel wool pad, and very badly at that. It would need to be re-brushed and re-sealed by an expert (meaning not the dealer). Would be cheaper, and a better match, for them just to replace the trim piece. Hopefully the dealer will not start baulking at making it right, and they really should have already volunteered to replace the piece rather than return the car to you looking like this. This is potentially one of those areas where the dealer and Audi could argue over the origin of the discolouration, the correction of which seems to have resulted in further damage. The cost of the trim piece and labour shouldn't be that high anyway. Good luck.
Good news: My dealer service department didn't bat an eye and agreed to replace the piece.
I'm really not sure what happened to cause the damage, but it must've happened after it left the factory. The car had several hundred miles on it at delivery. Oh well, there appears to be a happy ending. |
Good to hear the dealer is responding as they should. Not sure how a new car can rack up several hundred miles before delivery though? |
