Audi A6 3.0T C7 2009 - MMI DEAD and Trip Tronic issue
Hi Everyone!
This is my first post and I am looking for some help for my Audi A6 2.0T C7 2009. The problems are with the Trip Tronic not working and the MMI Screen and controls completely dead! The fuse for the communication module keeps blowing as soon as one is fitted. If any one can help to let me know where to start from would be great! Here is a copy of the log from VAGCOM: Thursday,06,September,2012,23:40:32:63106 VCDS Version: Release 11.11.4 Data version: 20120807 Chassis Type: 4F0 Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 5F 62 6C 72 76 VIN: WAUDG64F19N021872 Mileage: 66260km/41172miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: Cannot be reached 1100 6C-Back-up Cam. -- Status: Cannot be reached 1100 72-Door, Rear Right -- Status: Cannot be reached 1100 76-Park Assist -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (CAJ) Labels: None Part No SW: 4F1 910 551 B HW: 4F1 907 551 B Component: 3.0l V6 TFSI 0020 Revision: --H01--- Serial number: Coding: 01050010190F0160 Shop #: WSC 02325 785 00200 VCID: 2241904DFD397308171 1 Fault Found: 005386 - Engine Off Timer Performance P150A - 000 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 1 Fault Frequency: 1 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:22:34 Freeze Frame: RPM: 672 /min Mass Air / Rev.: 343.4 mg/str Temperature: 99.0°C Idle Voltage: 10.20 V Speed: 0.0 km/h Readiness: 0000 0100 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 K HW: 09L 927 156 C Component: AG6 09L 3,0TFSI RdW 0040 Revision: --H04--- Serial number: 4495154 Coding: 0000001 Shop #: WSC 02145 785 00200 VCID: 2C5D7E758FFDB578ADD 4 Faults Found: 006291 - Signal Line for Gear Display on Selector Lever P1893 - 000 - Electrical Malfunction Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Mileage: 65812 km Time Indication: 0 Date: 2008.05.31 Time: 05:44:26 006288 - Signal Line for Tiptronic P1890 - 000 - Electrical Malfunction - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 138 Mileage: 65812 km Time Indication: 0 Date: 2008.05.31 Time: 05:45:02 006289 - Signal Line for Tiptronic P1891 - 000 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 110 Mileage: 65812 km Time Indication: 0 Date: 2008.06.02 Time: 02:04:20 009984 - Transmission Friction Element / Clutch A P2700 - 000 - Apply Time Implausible - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 0 Fault Frequency: 1 Mileage: 65832 km Time Indication: 0 Date: 2008.05.31 Time: 13:39:57 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BA Component: ESP8 quattro H01 0060 Revision: 00000000 Serial number: 00000000000000 Coding: 0020921 Shop #: WSC 02145 785 00200 VCID: 6ED9B47D79618768C39 4 Faults Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 71 Reset counter: 225 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:11:29 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x42A0 Hex Value: 0x0024 Hex Value: 0x019E Hex Value: 0x00FF 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 222 Mileage: 65812 km Time Indication: 0 Date: 2008.06.18 Time: 23:00:13 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4280 Hex Value: 0x0013 Hex Value: 0x16A7 Hex Value: 0x00FF 00473 - Control Module for Elect. Park/Hand Brake (J540) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 32 Reset counter: 210 Mileage: 66259 km Time Indication: 0 Date: 2008.06.22 Time: 19:47:23 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x40A2 Hex Value: 0x002D Hex Value: 0x05A1 Hex Value: 0x00FF 00493 - ESP-Sensor Unit (G419) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 38 Reset counter: 249 Mileage: 65812 km Time Indication: 0 Date: 2008.06.07 Time: 04:07:20 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4280 Hex Value: 0x0038 Hex Value: 0x0196 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 B HW: 4F0 905 852 D Component: FBSAUDIC6 ELV H05 0100 Revision: 00H05000 Serial number: 10602601227738 Coding: 0000007 Shop #: WSC 02145 785 00200 VCID: 254B8B51EC178430723 Part No: 4F0 910 132 C Component: FBSAUDIC6 EZS H03 0020 Part No: 4F0 910 335 B Component: FBSAUDIC6 KSG H03 0020 Part No: 4F0 910 220 F Component: FBSAUDIC6 IDG H01 0040 6 Faults Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:11:33 02764 - Access/Start Authorization Switch (E408) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 6 Reset counter: 212 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:11:33 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:00:02 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 215 Mileage: 65812 km Time Indication: 0 Date: 2008.05.31 Time: 04:48:49 00183 - Interior Access/Start Authorization Antenna 1 (R138) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00111011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 219 Mileage: 65812 km Time Indication: 0 Date: 2008.06.07 Time: 06:03:56 01176 - Key 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 246 Mileage: 66258 km Time Indication: 0 Date: 2008.06.21 Time: 13:27:30 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 B HW: 4F1 820 043 AK Component: KLIMABETAETIGUNGH30 0070 Revision: 00000073 Serial number: 00000000581035 Coding: 0532518 Shop #: WSC 02145 785 00200 VCID: 1D3BA3B1C4474CF02A3 5 Faults Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 166 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:11:39 Freeze Frame: ON 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 222 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:11:40 Freeze Frame: ON 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 166 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:00:07 Freeze Frame: ON 00256 - A/C Pressure/Temperature Sensor (G395) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 214 Mileage: 65812 km Time Indication: 0 Date: 2008.05.30 Time: 14:54:43 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 215 Mileage: 65812 km Time Indication: 0 Date: 2008.05.31 Time: 06:21:36 Freeze Frame: ON ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 N HW: 4F0 907 279 Component: ILM Fahrer H22 0320 Revision: 00000000 Serial number: 4F0907279 Coding: 0033101 Shop #: WSC 02335 785 00200 VCID: 346D661557CDEDB8F5D Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB Component: Wischer AudiC6 H10 0040 Coding: 00056595 Shop #: WSC 02335 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0003 Coding: 00146221 Shop #: WSC 02335 5 Faults Found: 02748 - Solenoid for Bi-Xenon Shutter; Left 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00111011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 217 Mileage: 65812 km Time Indication: 0 Date: 2008.06.04 Time: 00:16:00 02747 - Solenoid for Bi-Xenon Shutter; Right 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00111011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 218 Mileage: 65812 km Time Indication: 0 Date: 2008.06.07 Time: 05:56:00 01800 - Light Switch (E1) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 230 Mileage: 65812 km Time Indication: 0 Date: 2008.06.07 Time: 04:49:00 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00111010 Fault Priority: 2 Fault Frequency: 40 Reset counter: 250 Mileage: 65812 km Time Indication: 0 Date: 2008.06.01 Time: 03:18:00 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00111010 Fault Priority: 2 Fault Frequency: 10 Reset counter: 248 Mileage: 65844 km Time Indication: 0 Date: 2008.06.01 Time: 00:56:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb Part No SW: 4F0 910 655 Q HW: 4F0 959 655 G Component: Airbag AU1042 H06 0140 Revision: -------- Serial number: 003F90018JCO Coding: 30314236303630303031554A304C34463053 Shop #: WSC 02323 785 00200 ASAM Dataset: EV_Airba10AURB4 001001 ROD: EV_Airba10AURB4.rod VCID: 356B5B1194B7F4B0C23 Crash sensor for side airbag; driver side: Serial number: 3574SRB40000818C6AAF Crash sensor for side airbag; passenger side: Serial number: 3584SRB4000081B062C1 Crash sensor for side airbag; rear driver side: Serial number: 35152RB402L7TCMB34IF Crash sensor for side airbag; rear passenger side: Serial number: 35252RB402L7TCMB6489 Crash sensor for front airbag; driver side: Serial number: 3554NRB4000047AB6966 Crash sensor for front airbag; passenger side: Serial number: 3564NRB4000047B1BFEH 4 Faults Found: 9437211 - Igniter for Driver's Airbag B1000 1B [136] - Resistance Too High MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 66115 km Date: 2008.06.03 Time: 01:54:38 9437467 - Igniter 2 for Driver's Airbag B1001 1B [136] - Resistance Too High MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 66115 km Date: 2008.06.03 Time: 01:54:39 12583424 - Powertrain Databus U0002 00 [008] - No Communications Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 13697280 - Component Protection U1101 00 [137] - Active MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 65812 km Date: 2008.06.02 Time: 06:40:56 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 A HW: 4F0 953 549 D Component: J0527 0410 Revision: 00H03000 Serial number: 90025082860125 Coding: 0002141 Shop #: WSC 02145 785 00200 VCID: 27578159961B962040F Part No: XXXXXXXXXXX Component: E0221 H02 0030 3 Faults Found: 01426 - Controls in Steering Wheel (E221) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 29 Reset counter: 245 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:24:39 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 6 Fault Frequency: 2 Reset counter: 225 Mileage: 65812 km Time Indication: 0 Date: 2008.05.31 Time: 07:38:49 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 230 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb Part No SW: 4F0 920 933 K HW: 4F0 920 933 K Component: KOMBIINSTR. H06 0133 Revision: 00200000 Serial number: 9FY08VVA8 Coding: 4F560A050A000008010600 Shop #: WSC 02391 823 56573 VCID: 2F6769797EEBCE6088F 5 Faults Found: 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 7 Reset counter: 222 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:11:38 01771 - Control Module for Headlight Range (J431) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 23 Reset counter: 217 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:11:41 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 65812 km Time Indication: 0 Date: 2008.05.30 Time: 14:54:38 00779 - Outside Air Temp Sensor (G17) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 214 Mileage: 65812 km Time Indication: 0 Date: 2008.05.30 Time: 14:54:42 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 217 Mileage: 65812 km Time Indication: 0 Date: 2008.06.07 Time: 04:35:44 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb Part No SW: 4F0 907 468 F HW: 4F0 907 468 F Component: GW-BEM 4CAN-M H06 0024 Revision: 4LA70021 Serial number: 2100L08A260230 Coding: 000303 Shop #: WSC 02391 823 56573 VCID: 3261600D6DD9E388E71 Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C Component: J367-BDM H07 0100 5 Faults Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 210 Mileage: 66262 km Time Indication: 0 Date: 2008.06.24 Time: 01:21:25 Freeze Frame: Bin. Bits: 00000 Voltage: 12.20 V Count: 11 Bin. Bits: 0000 Time: 0.00 s 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 210 Mileage: 66262 km Time Indication: 0 Date: 2008.06.24 Time: 01:21:25 Freeze Frame: Bin. Bits: 00000 Voltage: 12.20 V Count: 11 Bin. Bits: 0000 Time: 0.00 s 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 210 Mileage: 66262 km Time Indication: 0 Date: 2008.06.24 Time: 01:21:31 Freeze Frame: Bin. Bits: 01111 Voltage: 13.00 V Count: 7 Text: FFFFFFFF70746C20FFFFFF823100 Text: FFFFFFFF70746C20FFFFFF823100 Angle: -2.320° (no units): 49.0 02873 - Control Module for Back-Up Camera (J772) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 210 Mileage: 66262 km Time Indication: 0 Date: 2008.06.24 Time: 01:21:32 Freeze Frame: Bin. Bits: 01111 Voltage: 13.50 V Count: 7 Bin. Bits: 0000 Time: 0.00 s 00384 - Optical Databus 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 210 Mileage: 66262 km Time Indication: 0 Date: 2008.06.24 Time: 01:21:38 Freeze Frame: Bin. Bits: 01111 Voltage: 13.60 V Count: 7 Bin. Bits: 0000 Time: 0.00 s ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb Part No SW: 4F0 959 793 R HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000100424370 Coding: 011F56205040410001 Shop #: WSC 02391 823 56573 VCID: 46892CDDF1516F285B9 2 Faults Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 166 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:11:38 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 182 Mileage: 65813 km Time Indication: 0 Date: 2008.06.22 Time: 18:45:29 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 N HW: 4F0 907 289 N Component: Komfortgeraet H28 0240 Revision: 02400028 Serial number: 01156489080000 Coding: 0402565 Shop #: WSC 02335 785 00200 VCID: 356B5B115CB7F4B0C23 10 Faults Found: 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 254 Reset counter: 210 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:00:01 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 254 Reset counter: 210 Mileage: 65813 km Time Indication: 0 Date: 2011.11.02 Time: 14:54:35 01565 - Luggage Compartment Light (W3) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 196 Reset counter: 248 Mileage: 66259 km Time Indication: 0 Date: 2008.06.22 Time: 20:03:18 02935 - Control Circuit for Tail-Light; Right 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 5 Reset counter: 220 Mileage: 65812 km Time Indication: 0 Date: 2008.06.16 Time: 07:41:14 03598 - Control Circuit for Left Brake Light 2 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 52 Reset counter: 220 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:00:31 01504 - Bulb for License-Plate Light (X) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 220 Mileage: 65812 km Time Indication: 0 Date: 2008.06.16 Time: 07:47:01 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 3 Reset counter: 215 Mileage: 65812 km Time Indication: 0 Date: 2008.05.31 Time: 04:48:48 01501 - Bulb for Blinkers; Rear Left (M6) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 25 Reset counter: 223 Mileage: 65812 km Time Indication: 0 Date: 2008.06.07 Time: 04:36:50 01697 - Footwell Lighting; Rear Right (W46) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 45 Reset counter: 225 Mileage: 65812 km Time Indication: 0 Date: 2008.06.07 Time: 05:54:47 02934 - Control Circuit for Tail-Light; Left 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 10 Reset counter: 220 Mileage: 65812 km Time Indication: 0 Date: 2008.06.07 Time: 05:55:45 ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 C Component: ILM Beifahrer H12 0100 Revision: Serial number: 00000000251823 Coding: 0001014 Shop #: WSC 02145 785 00200 VCID: DEB964BD09C197E8F39 4 Faults Found: 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 230 Mileage: 0 km Time Indication: 0 Freeze Frame: Voltage: 12.700 V Temperature: 77.0°C 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 214 Mileage: 65812 km Time Indication: 0 Date: 2008.05.30 Time: 14:54:00 Freeze Frame: Voltage: 10.900 V Temperature: 45.0°C 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 218 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:00:00 Freeze Frame: Voltage: 12.000 V Not Recogn. 02752 - Glovebox Unlocking Motor (V327) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 3 Reset counter: 220 Mileage: 65812 km Time Indication: 0 Date: 2008.06.07 Time: 03:55:00 Freeze Frame: Voltage: 11.900 V Temperature: 77.0°C ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb Part No SW: 4F0 959 792 R HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000100427396 Coding: 011F56205040410001 Shop #: WSC 02391 823 56573 VCID: 458B2BD1CC576430523 5 Faults Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 203 Mileage: 66212 km Time Indication: 0 Date: 2008.06.08 Time: 13:45:20 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 166 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:00:07 01336 - Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 2 Reset counter: 243 Mileage: 1048575 km Time Indication: 0 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 2 Reset counter: 243 Mileage: 1048575 km Time Indication: 0 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 3 Reset counter: 243 Mileage: 1048575 km Time Indication: 0 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.clb Part No SW: 4F0 910 801 D HW: 4F0 907 801 B Component: EPB CEFC0090 H05 0090 Revision: --H05--- Coding: 0000221 Shop #: WSC 02145 785 00200 VCID: 21439F41F83F68100EB 5 Faults Found: 01487 - System Function Test 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 4 Fault Frequency: 26 Reset counter: 250 Mileage: 65808 km Time Indication: 0 Date: 2008.06.22 Time: 20:23:13 Freeze Frame: Voltage: 11.18 V Count: 118 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 11 Reset counter: 221 Mileage: 65808 km Time Indication: 0 Date: 2008.06.04 Time: 00:43:54 Freeze Frame: Voltage: 12.73 V Count: 236 02434 - Supply Voltage for Control Module for Left Channel 009 - Open or Short to Ground - MIL ON Freeze Frame: Fault Status: 11101001 Fault Priority: 2 Fault Frequency: 204 Reset counter: 178 Mileage: 65808 km Time Indication: 0 Date: 2008.06.07 Time: 04:42:07 Freeze Frame: Voltage: 8.90 V Count: 112 02432 - Supply Voltage for Left Parking Brake Motor (V282) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00111011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 225 Mileage: 65808 km Time Indication: 0 Date: 2008.06.24 Time: 18:16:54 Freeze Frame: Voltage: 11.18 V Count: 92 02443 - Control Head 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00111100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 248 Mileage: 65808 km Time Indication: 0 Date: 2008.05.29 Time: 00:03:55 Freeze Frame: Voltage: 8.90 V Count: 40 ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 HW: 4L0 907 357 Component: AFS 1 H01 0040 Revision: 00000001 Serial number: Coding: 0000255 Shop #: WSC 02325 785 00200 VCID: E9D34761C08FE05016B Part No: ----------- Component: AFS-Modul links Part No: ----------- Component: AFS-Modul rechts 7 Faults Found: 01042 - Control Module; Not Coded 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 0 Mileage: 1048575 km Time Indication: 0 02233 - Left Headlight Power Output Stage (J667) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:11:43 01539 - Headlights Not Adjusted 005 - No or Incorrect Basic Setting / Adaptation - MIL ON Freeze Frame: Fault Status: 11100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 0 Mileage: 1048575 km Time Indication: 0 02234 - Right Headlight Power Output Stage (J668) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00111110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:11:47 02628 - Sensor for Swivel Module Position; Right 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00111000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 65812 km Time Indication: 0 Date: 2008.05.29 Time: 00:14:37 00496 - Sensor for Vehicle Leveling; Front 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 174 Mileage: 65812 km Time Indication: 0 Date: 2008.05.30 Time: 14:54:41 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 169 Mileage: 65812 km Time Indication: 0 Date: 2008.05.31 Time: 07:39:07 ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 5F: Information Electr. Cannot be reached ------------------------------------------------------------------------------- Address 62: Door, Rear Left Cannot be reached ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Cannot be reached ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 R HW: 4F0 919 283 R Component: Parkhilfe 8-Kan H12 0300 Revision: 00H12000 Serial number: 11630830303827 Coding: 0221006 Shop #: WSC 02145 785 00200 VCID: 336F650952C3EA80EC7 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 40 Mileage: 65812 km Time Indication: 0 Date: 2008.05.30 Time: 14:54:37 End --------------------------------------------------------------------- |
The 2009 A6 is not a C7, but a C6, I believe.
I would recommend you post there, because you probably won't get much of a response on your vehicle in here. :) |
Originally Posted by Nyuni
(Post 24344748)
