Audi A6 3.0T C7 2009 - MMI DEAD and Trip Tronic issue
Hi Everyone!
This is my first post and I am looking for some help for my Audi A6 2.0T C7 2009.
The problems are with the Trip Tronic not working and the MMI Screen and controls completely dead!
The fuse for the communication module keeps blowing as soon as one is fitted.
If any one can help to let me know where to start from would be great!
Here is a copy of the log from VAGCOM:
Thursday,06,September,2012,23:40:32:63106
VCDS Version: Release 11.11.4
Data version: 20120807
Chassis Type: 4F0
Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 5F
62 6C 72 76
VIN: WAUDG64F19N021872 Mileage: 66260km/41172miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine (CAJ) Labels: None
Part No SW: 4F1 910 551 B HW: 4F1 907 551 B
Component: 3.0l V6 TFSI 0020
Revision: --H01--- Serial number:
Coding: 01050010190F0160
Shop #: WSC 02325 785 00200
VCID: 2241904DFD397308171
1 Fault Found:
005386 - Engine Off Timer Performance
P150A - 000 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 1
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:22:34
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 343.4 mg/str
Temperature: 99.0°C
Idle
Voltage: 10.20 V
Speed: 0.0 km/h
Readiness: 0000 0100
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 K HW: 09L 927 156 C
Component: AG6 09L 3,0TFSI RdW 0040
Revision: --H04--- Serial number: 4495154
Coding: 0000001
Shop #: WSC 02145 785 00200
VCID: 2C5D7E758FFDB578ADD
4 Faults Found:
006291 - Signal Line for Gear Display on Selector Lever
P1893 - 000 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 05:44:26
006288 - Signal Line for Tiptronic
P1890 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 138
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 05:45:02
006289 - Signal Line for Tiptronic
P1891 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 110
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.02
Time: 02:04:20
009984 - Transmission Friction Element / Clutch A
P2700 - 000 - Apply Time Implausible - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 65832 km
Time Indication: 0
Date: 2008.05.31
Time: 13:39:57
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BA
Component: ESP8 quattro H01 0060
Revision: 00000000 Serial number: 00000000000000
Coding: 0020921
VCID: 6ED9B47D79618768C39
4 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 71
Reset counter: 225
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:29
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x42A0
Hex Value: 0x0024
Hex Value: 0x019E
Hex Value: 0x00FF
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 222
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.18
Time: 23:00:13
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4280
Hex Value: 0x0013
Hex Value: 0x16A7
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 32
Reset counter: 210
Mileage: 66259 km
Time Indication: 0
Date: 2008.06.22
Time: 19:47:23
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x40A2
Hex Value: 0x002D
Hex Value: 0x05A1
Hex Value: 0x00FF
00493 - ESP-Sensor Unit (G419)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 38
Reset counter: 249
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 04:07:20
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4280
Hex Value: 0x0038
Hex Value: 0x0196
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601227738
Coding: 0000007
VCID: 254B8B51EC178430723
Part No: 4F0 910 132 C
Component: FBSAUDIC6 EZS H03 0020
Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Part No: 4F0 910 220 F
Component: FBSAUDIC6 IDG H01 0040
6 Faults Found:
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:33
02764 - Access/Start Authorization Switch (E408)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 212
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:33
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:02
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 215
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 04:48:49
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 06:03:56
01176 - Key
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 66258 km
Time Indication: 0
Date: 2008.06.21
Time: 13:27:30
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 B HW: 4F1 820 043 AK
Component: KLIMABETAETIGUNGH30 0070
Revision: 00000073 Serial number: 00000000581035
Coding: 0532518
VCID: 1D3BA3B1C4474CF02A3
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:39
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 222
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:40
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:07
Freeze Frame:
ON
00256 - A/C Pressure/Temperature Sensor (G395)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 214
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:43
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 215
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 06:21:36
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Revision: 00000000 Serial number: 4F0907279
Coding: 0033101
Shop #: WSC 02335 785 00200
VCID: 346D661557CDEDB8F5D
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02335
5 Faults Found:
02748 - Solenoid for Bi-Xenon Shutter; Left
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.04
Time: 00:16:00
02747 - Solenoid for Bi-Xenon Shutter; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 05:56:00
01800 - Light Switch (E1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 230
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 04:49:00
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00111010
Fault Priority: 2
Fault Frequency: 40
Reset counter: 250
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.01
Time: 03:18:00
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 248
Mileage: 65844 km
Time Indication: 0
Date: 2008.06.01
Time: 00:56:00
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
Part No SW: 4F0 910 655 Q HW: 4F0 959 655 G
Component: Airbag AU1042 H06 0140
Revision: -------- Serial number: 003F90018JCO
Coding: 30314236303630303031554A304C34463053
Shop #: WSC 02323 785 00200
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 356B5B1194B7F4B0C23
Crash sensor for side airbag; driver side:
Serial number: 3574SRB40000818C6AAF
Crash sensor for side airbag; passenger side:
Serial number: 3584SRB4000081B062C1
Crash sensor for side airbag; rear driver side:
Serial number: 35152RB402L7TCMB34IF
Crash sensor for side airbag; rear passenger side:
Serial number: 35252RB402L7TCMB6489
Crash sensor for front airbag; driver side:
Serial number: 3554NRB4000047AB6966
Crash sensor for front airbag; passenger side:
Serial number: 3564NRB4000047B1BFEH
4 Faults Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [136] - Resistance Too High
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 66115 km
Date: 2008.06.03
Time: 01:54:38
9437467 - Igniter 2 for Driver's Airbag
B1001 1B [136] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 66115 km
Date: 2008.06.03
Time: 01:54:39
12583424 - Powertrain Databus
U0002 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
13697280 - Component Protection
U1101 00 [137] - Active
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 65812 km
Date: 2008.06.02
Time: 06:40:56
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90025082860125
Coding: 0002141
VCID: 27578159961B962040F
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
3 Faults Found:
01426 - Controls in Steering Wheel (E221)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 29
Reset counter: 245
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:24:39
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 2
Reset counter: 225
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 07:38:49
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 230
Mileage: 0 km
Time Indication: 0
Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
Part No SW: 4F0 920 933 K HW: 4F0 920 933 K
Component: KOMBIINSTR. H06 0133
Revision: 00200000 Serial number: 9FY08VVA8
Coding: 4F560A050A000008010600
Shop #: WSC 02391 823 56573
VCID: 2F6769797EEBCE6088F
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 222
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:38
01771 - Control Module for Headlight Range (J431)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 23
Reset counter: 217
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:41
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:38
00779 - Outside Air Temp Sensor (G17)
Freeze Frame:
Fault Status: 00101010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 214
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:42
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 04:35:44
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0024
Revision: 4LA70021 Serial number: 2100L08A260230
Coding: 000303
VCID: 3261600D6DD9E388E71
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0100
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 210
Mileage: 66262 km
Time Indication: 0
Date: 2008.06.24
Time: 01:21:25
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.20 V
Count: 11
Bin. Bits: 0000
Time: 0.00 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 210
Mileage: 66262 km
Time Indication: 0
Date: 2008.06.24
Time: 01:21:25
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.20 V
Count: 11
Bin. Bits: 0000
Time: 0.00 s
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 210
Mileage: 66262 km
Time Indication: 0
Date: 2008.06.24
Time: 01:21:31
Freeze Frame:
Bin. Bits: 01111
Voltage: 13.00 V
Count: 7
Text: FFFFFFFF70746C20FFFFFF823100
Angle: -2.320°
(no units): 49.0
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 210
Mileage: 66262 km
Time Indication: 0
Date: 2008.06.24
Time: 01:21:32
Freeze Frame:
Bin. Bits: 01111
Voltage: 13.50 V
Count: 7
Bin. Bits: 0000
Time: 0.00 s
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 210
Mileage: 66262 km
Time Indication: 0
Date: 2008.06.24
Time: 01:21:38
Freeze Frame:
Bin. Bits: 01111
Voltage: 13.60 V
Count: 7
Bin. Bits: 0000
Time: 0.00 s
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100424370
Coding: 011F56205040410001
VCID: 46892CDDF1516F285B9
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 182
Mileage: 65813 km
Time Indication: 0
Date: 2008.06.22
Time: 18:45:29
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H28 0240
Revision: 02400028 Serial number: 01156489080000
Coding: 0402565
VCID: 356B5B115CB7F4B0C23
10 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 254
Reset counter: 210
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:01
Freeze Frame:
Fault Priority: 5
Reset counter: 210
Mileage: 65813 km
Time Indication: 0
Date: 2011.11.02
Time: 14:54:35
01565 - Luggage Compartment Light (W3)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 196
Reset counter: 248
Mileage: 66259 km
Time Indication: 0
Date: 2008.06.22
Time: 20:03:18
02935 - Control Circuit for Tail-Light; Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 220
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.16
Time: 07:41:14
03598 - Control Circuit for Left Brake Light 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 52
Reset counter: 220
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:31
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 220
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.16
Time: 07:47:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 215
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 04:48:48
01501 - Bulb for Blinkers; Rear Left (M6)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 223
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 04:36:50
01697 - Footwell Lighting; Rear Right (W46)
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 45
Reset counter: 225
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 05:54:47
02934 - Control Circuit for Tail-Light; Left
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 220
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 05:55:45
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000251823
Coding: 0001014
VCID: DEB964BD09C197E8F39
4 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 230
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Voltage: 12.700 V
Temperature: 77.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 214
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:00
Freeze Frame:
Voltage: 10.900 V
Temperature: 45.0°C
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 218
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:00
Freeze Frame:
Voltage: 12.000 V
Not Recogn.
02752 - Glovebox Unlocking Motor (V327)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 220
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 03:55:00
Freeze Frame:
Voltage: 11.900 V
Temperature: 77.0°C
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100427396
VCID: 458B2BD1CC576430523
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 203
Mileage: 66212 km
Time Indication: 0
Date: 2008.06.08
Time: 13:45:20
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:07
01336 - Data Bus for Comfort System
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 243
Mileage: 1048575 km
Time Indication: 0
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 243
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 243
Mileage: 1048575 km
Time Indication: 0
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000221
VCID: 21439F41F83F68100EB
5 Faults Found:
01487 - System Function Test
Freeze Frame:
Fault Priority: 4
Fault Frequency: 26
Reset counter: 250
Mileage: 65808 km
Time Indication: 0
Date: 2008.06.22
Time: 20:23:13
Freeze Frame:
Voltage: 11.18 V
Count: 118
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 11
Reset counter: 221
Mileage: 65808 km
Time Indication: 0
Date: 2008.06.04
Time: 00:43:54
Freeze Frame:
Voltage: 12.73 V
Count: 236
02434 - Supply Voltage for Control Module for Left Channel
009 - Open or Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11101001
Fault Priority: 2
Fault Frequency: 204
Reset counter: 178
Mileage: 65808 km
Time Indication: 0
Date: 2008.06.07
Time: 04:42:07
Freeze Frame:
Voltage: 8.90 V
Count: 112
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 65808 km
Time Indication: 0
Date: 2008.06.24
Time: 18:16:54
Freeze Frame:
Voltage: 11.18 V
Count: 92
02443 - Control Head
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 2
Reset counter: 248
Mileage: 65808 km
Time Indication: 0
Date: 2008.05.29
Time: 00:03:55
Freeze Frame:
Voltage: 8.90 V
Count: 40
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000255
VCID: E9D34761C08FE05016B
Part No: -----------
Component: AFS-Modul links
Component: AFS-Modul rechts
7 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 1048575 km
Time Indication: 0
02233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:43
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 1048575 km
Time Indication: 0
02234 - Right Headlight Power Output Stage (J668)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00111110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:47
02628 - Sensor for Swivel Module Position; Right
Freeze Frame:
Fault Status: 00111000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:14:37
00496 - Sensor for Vehicle Leveling; Front
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 174
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 07:39:07
Address 56: Radio
Cannot be reached
Address 5F: Information Electr.
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 6C: Back-up Cam.
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 R HW: 4F0 919 283 R
Component: Parkhilfe 8-Kan H12 0300
Revision: 00H12000 Serial number: 11630830303827
Coding: 0221006
VCID: 336F650952C3EA80EC7
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:37
End ---------------------------------------------------------------------
Chassis Type: 4F0
62 6C 72 76
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:22:34
Freeze Frame:
RPM: 672 /min
Temperature: 99.0°C
Idle
Voltage: 10.20 V
Speed: 0.0 km/h
Coding: 0000001
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 05:44:26
Freeze Frame:
Fault Priority: 0
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 05:45:02
Freeze Frame:
Fault Priority: 0
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.02
Time: 02:04:20
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 65832 km
Time Indication: 0
Date: 2008.05.31
Time: 13:39:57
Coding: 0020921
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 71
Reset counter: 225
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:29
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x42A0
Hex Value: 0x0024
Hex Value: 0x019E
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 222
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.18
Time: 23:00:13
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4280
Hex Value: 0x0013
Hex Value: 0x16A7
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 32
Reset counter: 210
Mileage: 66259 km
Time Indication: 0
Date: 2008.06.22
Time: 19:47:23
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x40A2
Hex Value: 0x002D
Hex Value: 0x05A1
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 38
Reset counter: 249
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 04:07:20
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4280
Hex Value: 0x0038
Hex Value: 0x0196
Hex Value: 0x00FF
Coding: 0000007
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 212
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 215
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 04:48:49
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 06:03:56
01176 - Key
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 66258 km
Time Indication: 0
Date: 2008.06.21
Time: 13:27:30
Coding: 0532518
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:39
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 222
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:40
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:07
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 214
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:43
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 215
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 06:21:36
Freeze Frame:
ON
Coding: 0033101
Coding: 00056595
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.04
Time: 00:16:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 05:56:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 230
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 04:49:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 250
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.01
Time: 03:18:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 248
Mileage: 65844 km
Time Indication: 0
Date: 2008.06.01
Time: 00:56:00
Cannot be reached
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 66115 km
Date: 2008.06.03
Time: 01:54:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 66115 km
Date: 2008.06.03
Time: 01:54:39
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 65812 km
Date: 2008.06.02
Time: 06:40:56
Coding: 0002141
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 29
Reset counter: 245
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:24:39
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 225
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 07:38:49
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 230
Mileage: 0 km
Time Indication: 0
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 222
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 23
Reset counter: 217
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:41
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:38
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 214
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:42
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 04:35:44
Coding: 000303
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 210
Mileage: 66262 km
Time Indication: 0
Date: 2008.06.24
Time: 01:21:25
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.20 V
Count: 11
Bin. Bits: 0000
Time: 0.00 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 210
Mileage: 66262 km
Time Indication: 0
Date: 2008.06.24
Time: 01:21:25
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.20 V
Count: 11
Bin. Bits: 0000
Time: 0.00 s
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 210
Mileage: 66262 km
Time Indication: 0
Date: 2008.06.24
Time: 01:21:31
Freeze Frame:
Bin. Bits: 01111
Voltage: 13.00 V
Count: 7
Angle: -2.320°
(no units): 49.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 210
Mileage: 66262 km
Time Indication: 0
Date: 2008.06.24
Time: 01:21:32
Freeze Frame:
Bin. Bits: 01111
Voltage: 13.50 V
Count: 7
Bin. Bits: 0000
Time: 0.00 s
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 210
Mileage: 66262 km
Time Indication: 0
Date: 2008.06.24
Time: 01:21:38
Freeze Frame:
Bin. Bits: 01111
Voltage: 13.60 V
Count: 7
Bin. Bits: 0000
Time: 0.00 s
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 182
Mileage: 65813 km
Time Indication: 0
Date: 2008.06.22
Time: 18:45:29
Coding: 0402565
10 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 210
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:01
Freeze Frame:
Fault Priority: 5
Reset counter: 210
Mileage: 65813 km
Time Indication: 0
Date: 2011.11.02
Time: 14:54:35
Freeze Frame:
Fault Priority: 3
Reset counter: 248
Mileage: 66259 km
Time Indication: 0
Date: 2008.06.22
Time: 20:03:18
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 220
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.16
Time: 07:41:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 52
Reset counter: 220
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:31
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 220
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.16
Time: 07:47:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 215
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 04:48:48
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 223
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 04:36:50
Freeze Frame:
Fault Priority: 3
Fault Frequency: 45
Reset counter: 225
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 05:54:47
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 220
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 05:55:45
Cannot be reached
Coding: 0001014
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 230
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Voltage: 12.700 V
Temperature: 77.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 214
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:00
Freeze Frame:
Voltage: 10.900 V
Temperature: 45.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 218
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:00
Freeze Frame:
Voltage: 12.000 V
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 220
Mileage: 65812 km
Time Indication: 0
Date: 2008.06.07
Time: 03:55:00
Freeze Frame:
Voltage: 11.900 V
Temperature: 77.0°C
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 203
Mileage: 66212 km
Time Indication: 0
Date: 2008.06.08
Time: 13:45:20
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:00:07
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 243
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 243
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 243
Mileage: 1048575 km
Time Indication: 0
Revision: --H05---
Coding: 0000221
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 26
Reset counter: 250
Mileage: 65808 km
Time Indication: 0
Date: 2008.06.22
Time: 20:23:13
Freeze Frame:
Voltage: 11.18 V
Count: 118
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 221
Mileage: 65808 km
Time Indication: 0
Date: 2008.06.04
Time: 00:43:54
Freeze Frame:
Voltage: 12.73 V
Count: 236
Freeze Frame:
Fault Priority: 2
Reset counter: 178
Mileage: 65808 km
Time Indication: 0
Date: 2008.06.07
Time: 04:42:07
Freeze Frame:
Voltage: 8.90 V
Count: 112
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 65808 km
Time Indication: 0
Date: 2008.06.24
Time: 18:16:54
Freeze Frame:
Voltage: 11.18 V
Count: 92
Freeze Frame:
Fault Priority: 2
Reset counter: 248
Mileage: 65808 km
Time Indication: 0
Date: 2008.05.29
Time: 00:03:55
Freeze Frame:
Voltage: 8.90 V
Count: 40
Coding: 0000255
7 Faults Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:43
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:11:47
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.29
Time: 00:14:37
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 174
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.31
Time: 07:39:07
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0221006
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 65812 km
Time Indication: 0
Date: 2008.05.30
Time: 14:54:37
Hassan2869
01-23-2017 02:28 PM
captain_video
11-16-2016 09:34 AM
