Muting the navigation
How do I mute the navigation voice while driving?
Should be simple - but I can't figure it out. |
While the navigation is"speaking", just roll the RH thumb wheel on the steering wheel down and it will lower the sound setting of the nav system.
Originally Posted by looking@audi
(Post 24368953)
Should be simple - but I can't figure it out. then say "Voice Guidance Off" voila!! |
There is also a setting within the nav screen in the MMI. I beleive there are three levels of detail. 1 for everything, 1 is for abbreviated version, and 1 for off.
Originally Posted by Jatmobil
(Post 24368973)
Click the Voice Control Button on the steering wheel and wait for the system to prompt you for a voice command....
Originally Posted by last911
(Post 24368965)
If you don't have the cold weather package, there is a button on the steering wheel with a "*", you can program that to mute/unmute voice navigation.
Originally Posted by dht34
(Post 24369006)
As was pointed out by BlackZ above. You can use the MMI when in nave mode, use the MMI to to change it to voice guidance off. If you do it via this method it will not come on and interupt your music.
(Post 24368973)
then say "Voice Guidance Off" voila!! However, I do with Audi would integrate the mute button on the steering wheel for the navigation voice. You can use the scroll wheel on the steering wheel to control the navigation volume, why not allow it to be muted?:confused: |
