01A6Turbo |
11-22-2009 04:41 AM |
Hey Cavan, I'm having trouble with my '01 2.7 as well. Last friday she was running (& starting) strong. Drove her 35 mies to work (hwy), 35 miles home, parked her in the driveway for the night and everything was fine. Come out last Saturday afternoon as I had to go somewhere and *BOOM* completely dead. Wouldn't start for the life of me. So I try to jump her - not helping. Check my plugs and coil packs - all new and perfect. Like you said, she was cranking but wouldn't start - as if not getting fuel. So after doing a lot of research on here and AF.com - I came to the conclusion it was the fuel pump (FP). Ripped apart the entire driver side dash, ripped out the back seat to access the fuel pump, etc. Under the dash I checked the FP's relay - was working perfect. So then I checked the FP fuse - perfect. Then with the help of my dad, I turned the key to ON to see if the FP was clicking - it was. I was STUMPED. Then my dad got the bright idea to grab his 12 voltometer and start checking everything! lol I mean, we checked EVERYthing. Finally, we tested the power supply to the FP itself - DEAD. The whole problem was the FP wasn't getting any power so therefore, not turning over -> not pushing fuel into manifold/engine -> no car start. So we got a red wire we had laying around (this was about an hour or so later after we traced the power wire from the FP up to the dash to find out which wire it was supplying the power -> so we connect the red wire into where the supply wire is connected, and connect the other end to the (+) end of the relay (just to get 12v power to test). Sure as ****, car starts right up!!!
Well, I knew I couldn't leave the red wire connected and depend on the relay for a constant power supply so I thought "****...now what am I going to do?" Miraculously after d/c'ing the red wire, the car started starting on its on - as if the green/yellow supply wire was lose or something inside its power supply and we either jumped it to life w/ the red wire or moved it back in place. However, now that's it's been over a week - the car will still start - but I'm still noticing problems. Like sometimes I have to turn the key twice to get it to start - other times it will start on the 1st try but doesn't sound like a "healthy" start...
I don't know what to do! How am I supposed to fix this electrical problem? I see it being a real b1tch. But Cavan, grab a voltometer and test your fuel pump power supply to see if that might be the problem...
