Differential windup/binding on quattro - oil change?
Hi there
Am new here but had my 2003 2.5TDi quattro sport for about 3 years and love it. Anyway from day one its suffered from a small amount of transmission windup (I'm from the UK so for me transmission means the whole drivetrain not just the gearbox) which I took to be normal given its permanent 4wd and has a torsen centre diff. However it is starting to get become more pronounced so I figure that maybe there is something amiss even if it is just it needs the oils changing, as the car only came with partial history I don't know when or even if it has ever been changed - cars dome 172k miles So my question I guess is does a lack of oil changes tend to cause windup/binding issues on these cars or is there possibly something else wrong? And also what oils are recommended for the gearbox and rear diff (may as well do that whilst I'm at it)? thanks |
If by windup you mean what we colonists call backlash, it may have something to do with the dual mass flywheel (if you have a manual transmission). They can develop play and when getting on and off the power, there is a bit of a jerk. It does become worse over a period of time as the rubber in the flywheel deteriorates.
Hi by windup I mean where the different relative speeds of the wheels and the torque biasing nature of the centre diff means that one or more tyres has to slip in order to allow them all to keep turning. Its common with locking differentials, plate/clutch type LSDs and part time 4x4s with no centre differential, I'm just not sure if the torsen type diffs "tighten up" as the oil degrades to give a similar effect.
Transmission Wind-Up |
Not getting into technical terms but, when I turn it feels like the outer wheel(s) to turn do slip or I hear a bit of dirt drag noises under the tire and whole car has slight vibration. But this is when making a tight turn like a sharp u-turn etc.
As far as oils, unfortunately, there is no oil in the market that lasts lifelong as Audi states about automatic transmission fluid (i.e. gearbox). If you define the car's "life" to be 100k, yeah, that makes sense. For all intents and purposes, it is in your best interest to change the transmission fluid at least every 75k miles or earlier and, the differentials could go for 75k easily. I've done it. While there is no "night & day" difference, it made the entire driveline much smoother. Change transmission fluid properly as per procedures and replace the filter as well. Drain and refill differntial fluids to correct levels and you won't have to worry. Mine has Front, Center & Rear! :) |
Wind up is not something I have ever experienced in my 32 years of owning 9 or 10 Audi Quattros and driven them nearly 1,000,000 miles (including family members). I have never even serviced a differential. Nor do I recall reading about Quattro drive issues more than a few times on this forum over the several years of reading nearly every post. The Quattro all wheel drive system is one of the least problematic issues these cars have.
This does not mean it could not be your problem, but I would look elsewhere first. Have you ruled out a binding wheel bearing or CV joint or brake or something tied to a single axle? Or, a drive shaft bearing? |
Originally Posted by clancy
(Post 24944797)
Originally Posted by tester123
(Post 24944795)
For all intents and purposes, it is in your best interest to change the transmission fluid at least every 75k miles or earlier and, the differentials could go for 75k easily. I've done it. While there is no "night & day" difference, it made the entire driveline much smoother. Change transmission fluid properly as per procedures and replace the filter as well. Drain and refill differntial fluids to correct levels and you won't have to worry. Mine has Front, Center & Rear! :) So what are the recommended oil specs and quantities please? Or can someone point me at an online version of the Audi workshop manual, I've always found the relevant forum will have access to manuals in the past and have a collection of them from other vehicles I've owned. |
"Having googled it extensively before registering here it does seem to be a fairly common thing. As a former rally technichian and a more current 4x4 (offroad) enthusiast I am pretty familiar with wind up and how it feels and am sure this is the issue was just after some guidance on the torsen diffs.
Fascinating... I will be most interested in hearing your confirmation and resolution. Too many people come onto this site, post their problem, and never post how they fixed it. Please be sure to clue us in. |
Originally Posted by sptb
(Post 24945001)
...So what are the recommended oil specs and quantities please? Or can someone point me at an online version of the Audi workshop manual, I've always found the relevant forum will have access to manuals in the past and have a collection of them from other vehicles I've owned.
That way I can find the specifications for you. You can also share your VIN. It should decode from that. If you're not comfortable with sharing in public (actually not a big deal but to each their own right...), you can send a PM of your VIN and I can let you know the rest here... |
Hi - been away from the car for a couple of days
VIN - WAUZZZ4BXN012563 Engine BDH transmission EUT FTL thanks |
Check the oil in the center diff.
Most old cars are leaking and as they get low/dry they can bind. |
