Help...Power folding mirror issue
I have an 04 a6 2.7t and I have developed an issue with my power folding mirror option. I have done a search here but can't seem to find anyone that has asked this going back to 05. Here is the issue:
When I go to switch the knob to unfold the mirrors and put them in driving position, my drivers side mirror stops at the right spot, but then continues to unfold to the point that the mirror is facing away from the car. What I am hearing is the motor for the drivers mirror run and when the mirror is in the correct place, the motor seems to bog own and push the mirror further. I noticed this problem on a windy day. I parked the car, folded in the mirrors and when I got out the wind took my door and whipped it open. I am not sure if the force was strong enough to fold out my mirror, but is it possible that it did and now the mirror and the gears are not lined up? To the point that the motor pushes the mirror in what it thinks is the right spot, but really it is over extended. I would appreciate any help on this as I love this feature and use it daily. I just don't want to have to roll down the windows to pull the mirror back in the right spot every time it over extends. Just one more thing, when I fold in the mirrors, they both fold in fine to the fold position. Any help or insight to what the problem is would be much appreciated. I am hoping it is something simple I can fix and not pay the dealer to fix. Thanks, |
Originally Posted by NVThs1
(Post 24071686)
When I go to switch the knob to unfold the mirrors and put them in driving position, my drivers side mirror stops at the right spot, but then continues to unfold to the point that the mirror is facing away from the car. What I am hearing is the motor for the drivers mirror run and when the mirror is in the correct place, the motor seems to bog own and push the mirror further. I noticed this problem on a windy day. I parked the car, folded in the mirrors and when I got out the wind took my door and whipped it open. I am not sure if the force was strong enough to fold out my mirror, but is it possible that it did and now the mirror and the gears are not lined up? To the point that the motor pushes the mirror in what it thinks is the right spot, but really it is over extended. I would appreciate any help on this as I love this feature and use it daily. I just don't want to have to roll down the windows to pull the mirror back in the right spot every time it over extends. Just one more thing, when I fold in the mirrors, they both fold in fine to the fold position. Any help or insight to what the problem is would be much appreciated. I am hoping it is something simple I can fix and not pay the dealer to fix. Thanks, Malcolm |
This is a crazy-old thread, but I have the same issue. It's like the computer thinks the proper unfolder position of the mirror is way too far outward, where the mirror itself is facing completely away from the car. Does anyone know how to recalibrate the position or any other way to fix this issue?
Don't know for sure, but there's a lot of info on the web regarding this stuff on other VW products..upshot is fold the mirrors in manually and the controller should reset.
Search/google audi folding mirror reset or some such search string. YMMV. |
I fixed it! I didn't find any info (other that some tutorial where the guy actually took apart the mirror), but I played around with it without taking anything apart and managed to get it fixed. Here's the procedure that worked:
- Turn the switch inside the car to the folded position. The mirrors should fold successfully. - Manually unfold the problematic mirror a little bit. You'll feel it unhook from the mechanism that moves it. - Push it back to fold it. In my case it did NOT snap back into the moving mechanism. This is key. If it does snap in, unfold it again and fold, but not all the way - stop just before it snaps in. - Turn the switch to the unfolded position. The rotating mechanism on the problematic mirror should make noise and move inside the mirror, without actually moving the mirror for some time, then finally hook on (snap into place) and unfold the mirror to the correct position. So there you have it. No need to do any programming or take anything apart. |
Originally Posted by todor
(Post 24576154)
