The lights are on but nobody is home.
Came to fire up the car the evening... unlocks as normal, turn key everything seems normal, headlights come on, no MIL... turn key to fire up engine... Nothing.
Nothing happens. Any ideas? I got VCDS output below... Thanks guys : ( Monday,14,January,2019,20:07:18:12060 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4437.4 Data version: 20180927 DS296.0 Ross-Tech: Home Mileage: 207610km-129002mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53 55 56 61 62 72 77 Mileage: 207610km-129002miles 00-Steering Angle Sensor -- Status: Cannot be reached 1100 01-Engine -- Status: Cannot be reached 1100 02-Auto Trans -- Status: Cannot be reached 1100 03-ABS Brakes -- Status: Cannot be reached 1100 05-Acc/Start Auth. -- Status: Malfunction 0010 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: Cannot be reached 1100 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Cannot be reached 1100 55-Headlight Range -- Status: Cannot be reached 1100 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Cannot be reached ------------------------------------------------------------------------------- Address 02: Auto Trans Cannot be reached ------------------------------------------------------------------------------- Address 03: ABS Brakes Cannot be reached ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H30 0160 Revision: 27100401 Serial number: 10600300110622 Coding: 0000011 Shop #: WSC 30807 001 1048576 VCID: 6393ACC9875749DFE37-8036 Subsystem 1 - Part No: 4F0 910 131 J Component: FBSAUDIC6 EZS H43 0070 Subsystem 2 - Part No: 4F0 910 220 A Component: FBSAUDIC6 IDG H36 0040 1 Fault Found: 00288 - Steering Column Lock Actuator (N360) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 1 Fault Frequency: 1 Reset counter: 121 Mileage: 207615 km Time Indication: 0 Date: 2019.01.14 Time: 19:59:49 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb Part No SW: 4F0 910 730 E HW: 4E0 035 729 Component: Interfacebox H43 1070 Revision: 00000000 Serial number: 360BT057518749 Coding: 0000003 Shop #: WSC 02335 785 00200 VCID: 2313ECC9C7D709DFA37-8076 Subsystem 1 - Part No: 4F0 910 609 B Component: Bedienteil MMIC6H07 0010 Subsystem 2 - Serial number: 00000000101308 Subsystem 3 - Serial number: 0124.01.050000000100010290˙ Subsystem 4 - Serial number: 010290˙ 1 Fault Found: 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 158 Mileage: 207536 km Time Indication: 0 Date: 2018.12.28 Time: 19:21:49 Freeze Frame: Bin. Bits: 10 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.clb Part No SW: 4F0 910 043 HW: 4F1 820 043 J Component: KLIMABETAETIGUNGH11 0150 Revision: 00000025 Serial number: 00000000107970 Coding: 0524326 Shop #: WSC 02327 785 00200 VCID: 5BE39429BF27711FAB7-800E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 HW: 4F0 907 279 Component: ILM Fahrer H14 0080 Revision: 00000000 Serial number: 4F0907279 Coding: 0013123 Shop #: WSC 02335 785 00200 VCID: 6695B5DD74653CF7049-8032 Subsystem 1 - Component: Fehler Lin-Slave 01 Subsystem 2 - Component: Fehler Lin-Slave 02 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 E HW: 4E0 035 111 A Component: CD-Changer H44 0430 Revision: 00000000 Serial number: AUZ5ZBE7116913 Shop #: WSC 00000 000 00000 VCID: 1B63D429FFA7311F6B7-804E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Cannot be reached ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90026050280247 Coding: 0002041 Shop #: WSC 02323 785 00200 VCID: 6695B5DD74653CF7049-8032 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H06 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 A HW: 4F0 920 950 M Component: KOMBIINSTR. M73 H10 0570 Revision: 00200000 Serial number: 4R871NT15 Coding: 2113263 Shop #: WSC 53735 001 1048576 VCID: 1E65DD3DECB524378C9-804A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4F0-910-468.clb Part No SW: 4F0 910 468 A HW: 4F0 907 468 B Component: Gateway H09 0030 Revision: 09 Serial number: 08008051280029 Coding: 6CFE73CC1B3104 Shop #: WSC 26887 003 1048576 VCID: 270BF8D9B3EFE5FFFFF-8072 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4F0 959 760 Component: Sitzmemory FS H04 0050 Revision: 00000000 Serial number: 00000000896400 Coding: 0082946 Shop #: WSC 02327 785 00200 VCID: 619FA6C19D4B5BCFF1B-8034 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 F HW: 4E0 919 887 C Component: MNS US H44 0990 Revision: 00000000 Serial number: 378C.057519539 Shop #: WSC 02327 785 00200 VCID: 313F16818D2BAB4F21B-8064 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Cannot be reached ------------------------------------------------------------------------------- Address 46: Central Conv. Cannot be reached ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-BO.lbl Part No SW: 4F5 910 223 D HW: 4F5 035 223 E Component: DSP-High C6 H14 0310 Revision: PROD_01 Serial number: 00000000024457 Coding: 0000016 Shop #: WSC 02327 785 00200 VCID: 2411EFD5C2D90EE7DAD-8070 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 A Component: ILM Beifahrer H09 0050 Revision: Serial number: 00000000061112 Coding: 0001114 Shop #: WSC 02323 785 00200 VCID: 5EE59D3DAC356437CC9-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Cannot be reached ------------------------------------------------------------------------------- Address 53: Parking Brake Cannot be reached ------------------------------------------------------------------------------- Address 55: Headlight Range Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 F HW: 4F0 035 541 B Component: TUNER EU/US/RDW H42 0480 Revision: 00000000 Serial number: 394AQ057513529 Coding: 0000002 Shop #: WSC 02327 785 00200 VCID: 2313ECC9C7D709DFA37-8076 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: ENERGIEMANAGER H12 0490 Revision: 00000000 Serial number: 00000000008931 Shop #: WSC 08902 444 84621 VCID: 2313ECC9C7D709DFA37-8076 Subsystem 1 - Part No: 4F0 915 105 C Component: von VA0 00915105DK Coding: 34463039313531303543205641303030393135313035444B Shop #: WSC 53731 001 1048576 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Cannot be reached ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 A HW: 4E0 862 335 Component: Handyvorb2 H10 0120 Revision: 00000000 Serial number: 00000007513257 Coding: 0010900 Shop #: WSC 02335 785 00200 VCID: 211FE6C1DDCB1BCFB1B-8074 No fault code found. End----(Elapsed Time: 01:21, VBatt start/end: 12.0V/11.9V. VIgn 0.7V)------ |
Time to get one of those "xtool vag401".
From your readout, it would appear that the Immobilizer module on the steering column has failed. The official VAG fix for that module failure is to replace the complete steering column assembly ($1,7000 part at discounted price). There is a company that can repair that module (Welcome to SpeedoSolutions) for a much lower cost. You can also clear that DTC so you can start your car. However, it may work a few days or weeks until the module fails and issues a DTC.
Yikes.
So it happened right after I plugged in my VCDS tool. However I plugged it in before I had booted up the laptop. Usually, all other times I have had the laptop powered on before connecting the cable. Do you think there is anyway this could have fritzed out the car to cause this? |
Connecting your laptop, either power off or power on, to the OBD-II port will not damage any electrical component in the car. Since you have VCDS, have your checked the Acc/Start module (Address 5) to clear the DTC and see if the car will start? If it does, then your immobilizer module is defective.
Originally Posted by A6Gary
(Post 25261941)
Yep I reset the codes with VCDS and it went back to normal right away. Wow yours was replaced twice? At least it was under warranty. Dropping 2k every random so many thousand miles/years to replace the column is not ideal is it... |
The bad news is that both times they tried the re-set first. It worked for a few weeks and then the problem returned. Good luck! |
I should have listened to A6Gary and KevinGary and gotten the steering column module replaced...
The problem struck again, only this time, I was 205 miles from home, and without my laptop and VCDS cable... I was hoping my Carista stashed in glovebox would save me, but unfortunately it did not fire up. I guess that with the car in that immobilized state, that the bluetooth operation of the car was not yet operational, and therefore, the Carista had no chance. My only option? A tow to the nearest Auto Repair shop (who, luckily, claimed to be Audi/BMW/Merc specialists). The wallet damage? $190 for the tow. $375 labor to replace the steering column module. $225 to program it to the car. $950 for the steering column module itself. Unfortunately they could not source me a brand new module, and instead used a reclaimed unit from a 2012 A6. Not ideal, but there we have it. Also unfortunately, I found after leaving the shop right after they closed for the day - the steering wheel was not put on quite straight. So it's back to my regular local Audi place next week to get that sorted... What an episode. It just goes to show; never ignore these problems and hope they will go away. They will come back. And at the most inconvenient time & place... |
