SPARK PLUG CHANGE NEED SUG.
whats up everyone i have a 2005 a6 3.2v6 and its time for new spark plugs and air filter cuz i get a small shake in the morning cold starts any sug. on what kind plugs and filter to buy. thanx
cold start may not be related to spark plug issue..
I got OEM spark plugs and filter. |
Originally Posted by C6AUDIA6
(Post 23849747)
The "morning" shakes during the few seconds of a cold start are systematic ...
of the FSI engine. When I took my '06 A6 in check against a TSB for rough idle during cold startup, the SA informed me that that is the reason for slight rough idle. Once my idle drops back to normal RPM, its smooth as silk. Just ensure that the ECM software has been updated per Audi Technical Service Bulletin (TSB) #24–08–23, which states that ECM software version is at least 0020 or higher.
Originally Posted by r1racer
(Post 23849792)
I just did my 55k service and it still gets the morning shakes for about 20 seconds and then it disappears. It's not the plugs or the filter.
P.S. THE JOB WAS FAIRLY EASY WITH THE RIGHT TOOLS JUST NEEDED TO TAKE OFF THE AIR BOX AND COOLANT TANK FOR WORKING SPACE. I'M GOING TO BUY THE K&N AIR FILTER NEXT.(B.T.W THE DEALER WANTED $280 FOR PARTS AND LABOR I PAID $50 DO IT YOUR SELF.) IF ANY QUESTIONS ON CHANGING YOURS LET ME KNOW I'LL WALK YOU THROUGH IT. 1 MORE QUESTION THOUGH... Does anyone know where the cabin air filter is located at ? thanks |
The cabin air filter is behind the center stack between the climate controls and the firewall. You have to take the glove box off (the whole thing, not just the door) and then you can access it.
What brand and type are the OEM plugs for the 06 FSI 3.2.
Also..since I never knowingly use the recirulation air, one would think the filter would be virtually unused? hmmm |
Check the sticky at the top of the page re: 55k DIY service.
I think he changed the cabin air filter without pulling the glove box apart. |
(Post 23853234)
HEY WHATS UP GUYS I JUST PUT IN NEW SPARK PLUGS IN TODAY AND IT SAT FOR ABOUT 6HRS AT WORK WITHOUT START AND NO MORE SHAKE AT IDLE, THE OLD PLUGS HAVEN'T BEEN CHANGED SINCE THE CAR WAS BOUGHT THEY WERE KINDA RUFF LOOKING LOL. WELL THANKS FOR THE HELP.
The oem spark plugs are the NGK on easy to find online for about $12-$13 per plug the dealer wanted $108 for 6 do the math, yeah i just found out the cabin air filter can be changed without removing the door just a plastic cover under(passanger side) where the light is for your feet.
