2012 A7 Multiple warnings/lights - car won't start
Just yesterday, my wife was driving my car three blocks to her work, and said that the dash lit up with multiple warnings, lights, a gearbox malfunction message, and didn't want to shift. Once I showed up, I seen the multiple messages, and the car wouldn't try to start. It kept stating that the car must be in P or N to start, which it already was. Since that's all that the car's been driven the past few months, I figured the problem was just a low battery. I had the car towed home, and when I put it on the charger, the charger registered the battery at 12.0V and 50% capacity. This morning, it was up to 13.2V and 95% capacity. I connected the car to VCDS to try to clear the codes, and as soon as I did, the codes immediately came back, and just like yesterday - it refuses to start.
Here's what the scan in VCDS came up with: (This is long)... Tuesday,19,July,2022,03:57:37:52516 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.3.1.4 (x64) HEX-NET CB: 0.4615.4 Data version: 20220407 DS337.0 www.Ross-Tech.com VIN: WAUSGAFC7CN001498 License Plate: HISAUDI Mileage: 285336km-177299mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FC-AU57 (4G0) Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 3B 3C 42 44 46 52 53 55 56 5F 62 6C 6D 72 8F 90 VIN: WAUSGAFC7CN001498 Mileage: 285336km-177299miles 01-Engine -- Status: Malfunction 0110 02-Auto Trans -- Status: Malfunction 0110 03-ABS Brakes -- Status: Malfunction 0110 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 15-Airbags -- Status: Cannot be reached 0100 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Malfunction 0010 3B-Sensor Elect. -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0110 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: Malfunction 0010 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 8F-Pretens. Frt Left -- Status: Malfunction 0010 90-Pretens. Frt Right -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Cannot be reached ------------------------------------------------------------------------------- Address 02: Auto Trans Cannot be reached ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb Part No SW: 4G0 907 379 HW: 4G0 907 379 Component: ESP PREMIUM H08 0190 Revision: -------- Serial number: -------------- Coding: 44A70F0222E5F0405B00 Shop #: WSC 02311 785 00200 ASAM Dataset: EV_ESPPremiAU57X 003013 ROD: EV_ESPPremiAU57X_003.rod (VIN: N/A) VCID: 6E90099BB15A21FF2D-803A 20 Faults Found: 0004 - Brake Switch (F) P0571 00 [129] - Implausible Signal MIL ON - Not Confirmed - Tested Since Memory Clear 0044 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [ComScl_PDU_Airbag_01_Timeout] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 23 Mileage: 285336 km Date: 2022.07.19 Time: 03:53:49 VzRef: 00 Bit Info 1: 00 Bit Info 2: 0F Bit Info 3: 20 Bit Info 4: 1F F-Path: 00 F-Type: B3 Uz: 9F 0051 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [ComScl_PDU_EPB_01_Timeout] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 13 Reset counter: 23 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:09 VzRef: 00 Bit Info 1: 80 Bit Info 2: 40 Bit Info 3: 22 Bit Info 4: 1F F-Path: 00 F-Type: BC Uz: A7 0058 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [ComScl_PDU_Getriebe_01_Timeout] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 23 Mileage: 285336 km Date: 2022.07.18 Time: 20:40:49 VzRef: 00 Bit Info 1: 00 Bit Info 2: 0F Bit Info 3: 20 Bit Info 4: 1F F-Path: 00 F-Type: C4 Uz: 9A 0060 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [ComScl_PDU_Getriebe_03_Timeout] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 7 Reset counter: 23 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:09 VzRef: 00 Bit Info 1: 80 Bit Info 2: 40 Bit Info 3: 22 Bit Info 4: 1F F-Path: 00 F-Type: C7 Uz: A7 0067 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [ComScl_PDU_LWI_01_Timeout] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 23 Mileage: 285336 km Date: 2022.07.19 Time: 03:53:49 VzRef: 00 Bit Info 1: 00 Bit Info 2: 0F Bit Info 3: 20 Bit Info 4: 1F F-Path: 00 F-Type: DF Uz: 9C 0069 - Function Restricted due to Missing Message(s) U1111 00 [137] - - [ComScl_PDU_Motor_01_Timeout] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 23 Mileage: 285336 km Date: 2022.07.18 Time: 20:40:06 VzRef: 00 Bit Info 1: 00 Bit Info 2: 0F Bit Info 3: 20 Bit Info 4: 1F F-Path: 00 F-Type: E7 Uz: 99 0071 - Function Restricted due to Missing Message(s) U1111 00 [137] - - [ComScl_PDU_Motor_02_Timeout] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 23 Mileage: 285336 km Date: 2022.07.19 Time: 03:53:49 VzRef: 00 Bit Info 1: 00 Bit Info 2: 0F Bit Info 3: 20 Bit Info 4: 1F F-Path: 00 F-Type: F4 Uz: 9F 0073 - Function Restricted due to Missing Message(s) U1111 00 [137] - - [ComScl_PDU_Motor_03_Timeout] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 23 Mileage: 285336 km Date: 2022.07.18 Time: 20:40:49 VzRef: 00 Bit Info 1: 00 Bit Info 2: 0F Bit Info 3: 20 Bit Info 4: 1F F-Path: 00 F-Type: F9 Uz: 9A 0075 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [ComScl_PDU_Motor_10_Timeout] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 23 Mileage: 285336 km Date: 2022.07.18 Time: 20:40:49 VzRef: 00 Bit Info 1: 00 Bit Info 2: 0F Bit Info 3: 20 Bit Info 4: 1F F-Path: 00 F-Type: FC Uz: 9A 0077 - Function Restricted due to Missing Message(s) U1111 00 [129] - - [ComScl_PDU_Motor_Code_01_Timeout] MIL ON - Not Confirmed - Tested Since Memory Clear 0091 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [ComScl_PDU_TSK_05_Timeout] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 23 Mileage: 285336 km Date: 2022.07.18 Time: 20:40:49 VzRef: 00 Bit Info 1: 00 Bit Info 2: 0F Bit Info 3: 20 Bit Info 4: 1F F-Path: 01 F-Type: 10 Uz: 9A 0486 - Function Restriction due to Faults in Other Modules U1113 00 [009] - - [Ldm_ApbFailureState] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 23 Mileage: 0 km Date: 2000.00.00 Time: 00:00:00 VzRef: 00 Bit Info 1: 00 Bit Info 2: 02 Bit Info 3: 20 Bit Info 4: 1F F-Path: 02 F-Type: 06 Uz: A5 0557 - Powertrain Databus U0001 00 [137] - Unspecified Malfunction [NET_BusOffNetwork0] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 9 Reset counter: 23 Mileage: 285336 km Date: 2022.07.18 Time: 18:54:15 VzRef: 00 Bit Info 1: 00 Bit Info 2: 0F Bit Info 3: 20 Bit Info 4: 1F F-Path: 00 F-Type: 71 Uz: A5 0722 - Function Restriction due to Implausible Message(s) U1112 00 [129] - - [SCL_MO_Drehzahl_01_Invalid] MIL ON - Not Confirmed - Tested Since Memory Clear 0725 - Function Restriction due to Implausible Message(s) U1112 00 [129] - - [SCL_MO_Fahrpedalrohwert_01_Invalid] MIL ON - Not Confirmed - Tested Since Memory Clear 0838 - Function Restriction due to Faults in Other Modules U1113 00 [129] - - [SCL_MO_Mom_Begrenzung_Invalid] MIL ON - Not Confirmed - Tested Since Memory Clear 0727 - Function Restriction due to Implausible Message(s) U1112 00 [129] - - [SCL_MO_Mom_Fahrerwunsch_Invalid] MIL ON - Not Confirmed - Tested Since Memory Clear 0729 - Function Restriction due to Implausible Message(s) U1112 00 [129] - - [SCL_MO_Mom_Verlust_Invalid] MIL ON - Not Confirmed - Tested Since Memory Clear 0731 - Function Restriction due to Implausible Message(s) U1112 00 [129] - - [SCL_MO_Mom_m_ex_Invalid] MIL ON - Not Confirmed - Tested Since Memory Clear ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 4H0 907 064 AR HW: 4H0 907 064 AR Component: BCM2 2.0 H24 0217 Revision: 00002001 Coding: 098A3000000000000000 Shop #: WSC 02311 785 00200 VCID: 79BA2AC7F014764788-802C Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B Component: J764 ELV MLB H38 0044 Serial number: 2310000102613006 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 22 Reset counter: 23 Mileage: 285335 km Time Indication: 0 Date: 2022.07.18 Time: 05:37:10 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb Part No SW: 4G0 820 043 N HW: 4G0 820 043 N Component: KLIMA 2 ZONEN H10 0055 Serial number: 19011100040272 Coding: 6603201808 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiBasisUDS 002031 ROD: EV_AirCondiBasisUDS_002.rod (VIN: N/A) VCID: 2A18C58B4D320DDFB1-807E 2 Faults Found: 0260 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [Steuerger‰t f¸r Airbag: kein Signal/keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 28 Reset counter: 23 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:47 Voltage terminal 30: 13.82 V Terminal 15 status: Terminal 15 on Outside temperature: 33.5 ∞C 0331 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [Motorsteuerger‰t: kein Signal/Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 59 Reset counter: 23 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:54 Voltage terminal 30: 13.88 V Outside temperature: 33.5 ∞C ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb Part No SW: 4H0 907 063 G HW: 4H0 907 063 Component: BCM1 2.0 H12 0092 Revision: 11012002 Serial number: 00000000771020 Coding: 06002015023C9FE08100088380003928CF9CD208A209012100 0004402000 Shop #: WSC 02311 785 00200 VCID: 2C14C3934FC613EF43-8078 Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB Component: WWS57X 110130 H32 0051 Serial number: 110131115120 Coding: 0045F7 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 11247671 Coding: 02562B Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D Component: E1 - LDS H07 0044 Serial number: 26 01 2011 00000095 Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0020 Serial number: 0000001805569R09JP06 Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A Component: Humidity_Sens H02 0002 Serial number: 57380E55000000000001 6 Faults Found: 00978 - Lamp for Low Beam; Left (M29) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 23 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 05:41:00 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 12 Reset counter: 23 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:41:00 01314 - Engine Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 23 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:41:00 01315 - Transmission Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 3 Reset counter: 23 Mileage: 285335 km Time Indication: 0 Date: 2022.07.18 Time: 05:37:00 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 6 Reset counter: 23 Mileage: 285335 km Time Indication: 0 Date: 2022.07.18 Time: 05:37:00 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 2 Reset counter: 63 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:41:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 (R41) Labels: Redir Fail! Part No SW: 8X0 035 110 A HW: 8X0 035 110 Component: CDC-MP3-Pana H41 0470 Revision: 00000006 VCID: 2B16C08F4AC814D74A-807E No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb Part No SW: 4H0 919 475 H HW: 4H0 919 475 C Component: PARKHILFE ACC H07 0030 Revision: 11001001 Serial number: 55901102002123 Coding: 300103 Shop #: WSC 02311 785 00200 ASAM Dataset: EV_EPHVA18AU57X0000 001002 ROD: EV_EPHVA18AU57X0000_001.rod (VIN: N/A) VCID: 373EECFF8E80A0373E-8062 2 Faults Found: 12658704 - Databus U1121 00 [009] - Missing Message [Steuerger‰t f¸r elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 35 Reset counter: 23 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:09 12648720 - Databus U1121 00 [009] - Missing Message [Getriebesteuerger‰t - Getriebe_03 - kein Signal/keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 37 Reset counter: 23 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:09 ------------------------------------------------------------------------------- Address 15: Airbags Cannot be reached ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb Part No SW: 4G0 953 568 A HW: 4G0 953 568 A Component: Lenks.Modul H05 0201 Revision: 00000000 Serial number: 20110202000126 Coding: 000014 Shop #: WSC 02311 785 00200 VCID: 302CD7E363EE770F7F-8064 Subsystem 1 - Part No SW: 4G0 951 528 B HW: 4G0 951 528 B Component: E221 - MFL H07 0009 6 Faults Found: 01316 - ABS Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 30 Reset counter: 23 Mileage: 285335 km Time Indication: 0 Date: 2022.07.18 Time: 05:37:14 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 23 Mileage: 285335 km Time Indication: 0 Date: 2022.07.18 Time: 05:37:22 01312 - Powertrain Data Bus 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 23 Mileage: 285335 km Time Indication: 0 Date: 2022.07.18 Time: 05:37:23 01312 - Powertrain Data Bus 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 2 Fault Frequency: 117 Reset counter: 63 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:41:59 02085 - Incorrect Control Module Installed 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 23 Mileage: 285336 km Time Indication: 0 Date: 2022.07.19 Time: 03:53:56 Freeze Frame: Voltage: 12.30 V Hex Value: 0x0000 Speed: 0.0 km/h Steering Angle: -29.27∞ 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 23 Mileage: 285336 km Time Indication: 0 Date: 2022.07.19 Time: 03:54:32 Freeze Frame: Voltage: 12.20 V Hex Value: 0x0000 Speed: 0.0 km/h Steering Angle: -29.27∞ ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1 Part No SW: 4G8 920 981 E HW: 4G8 920 981 E Component: TBenUsa H34 0309 Revision: 18100069 Serial number: 658240111593024 Coding: 0BE701060B03D705020100 Shop #: WSC 02311 785 00200 ASAM Dataset: EV_RBD4K 004033 ROD: EV_RBD4K_AU57.rod (VIN: N/A) VCID: 3522E6F7948C52272C-8060 4 Faults Found: 16776962 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [Airbag_01 keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 38 Reset counter: 23 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:28 16776967 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [EPB_02 keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 35 Reset counter: 23 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:09 16776971 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [Motor_03 keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 46 Reset counter: 23 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:52 16777209 - Function Restriction due to Implausible Message(s) U1112 00 [008] - - [WBA_02 unplausibles Signal CHK] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 20:48:52 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb Part No SW: 4G0 907 468 C HW: 4G0 907 468 A Component: J533--Gateway H08 0204 Revision: -------- Serial number: 00000000089792 Coding: 00C1033000 Shop #: WSC 02391 785 00200 GVL: FDE1E80CDE63600D00 ASAM Dataset: EV_GatewUDS 001025 ROD: EV_GatewUDS_AU57.rod (VIN: N/A) VCID: 302CD7E36BEE770F7F-8064 Battery Monitoring Control Module: Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181 Component: J367-BDM H07 0140 Serial number: 00000000005650444302 5 Faults Found: 4226 - No Communication with Transmission Control Module U0101 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 11 Reset counter: 63 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:09 Voltage terminal 30: 12.8 V Voltage terminal 15: 12.8 V Control Module temperature: 22 ∞C System status: Terminal 15 on IN ESP_standstill flag: standstill detected Engine running: On IN ZAS_Te_X: On Terminal 15 status via CAN: On Terminal 15 status: On Datenfeld: 0 4356 - No Communications with Parking Brake Control Module U0128 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 6 Reset counter: 62 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:09 Voltage terminal 30: 12.8 V Voltage terminal 15: 12.8 V Control Module temperature: 22 ∞C System status: Terminal 15 on IN ESP_standstill flag: standstill detected Engine running: On IN ZAS_Te_X: On Terminal 15 status via CAN: On Terminal 15 status: On Datenfeld: 0 4228 - No Communication with ABS Brake Control Module U0121 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 20 Reset counter: 63 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:09 Voltage terminal 30: 12.8 V Voltage terminal 15: 12.8 V Control Module temperature: 22 ∞C System status: Terminal 15 on IN ESP_standstill flag: standstill detected Engine running: On IN ZAS_Te_X: On Terminal 15 status via CAN: On Terminal 15 status: On Datenfeld: 0 0256 - Powertrain Databus U0001 00 [008] - Unspecified Malfunction [High Speed CAN Communication] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 254 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:57 Voltage terminal 30: 13.7 V Voltage terminal 15: 13.7 V Control Module temperature: 46 ∞C System status: Terminal 15 on IN ESP_standstill flag: standstill detected Engine running: On IN ZAS_Te_X: On Terminal 15 status via CAN: On Terminal 15 status: On Datenfeld: 0 0264 - Powertrain Databus (VAG Single-Wire Mode) (SAE L Shorted H) U0009 00 [008] - - [Datenbus Antrieb Eindraht] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 32 Reset counter: 63 Mileage: 285332 km Date: 2022.07.17 Time: 01:40:52 Voltage terminal 30: 12.8 V Voltage terminal 15: 12.9 V Control Module temperature: 24 ∞C System status: Terminal 15 on IN ESP_standstill flag: no standstill detected Engine running: On IN ZAS_Te_X: On Terminal 15 status via CAN: On Terminal 15 status: On Datenfeld: 0 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4G8 959 760 HW: 4G8 959 760 Component: MEM-FS H03 0153 Revision: AA000000 Serial number: 00001002230042 Coding: 0058130000002001000001010101102030303232203232 Shop #: WSC 02311 785 00200 VCID: 77BE2CFFC6006037FE-8022 1 Fault Found: 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 40 Reset counter: 23 Mileage: 285335 km Time Indication: 0 Date: 2022.07.18 Time: 05:37:29 ------------------------------------------------------------------------------- Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb Part No SW: 4G0 907 637 B HW: 4G0 907 637 B Component: SARA 6D H02 0004 Revision: -------- Serial number: EJ1BPA4200AX440 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SARA 006014 ROD: EV_SARA_006.rod (VIN: N/A) VCID: 2D12CE977CDC1AE754-8078 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: Redir Fail! Part No SW: 4G0 907 566 H HW: 4G0 907 566 Component: J769 SWA MasterH01 0010 Revision: 00H01000 Serial number: 6PZ 010 287-02 Coding: 0000003 Shop #: WSC 02391 785 00200 VCID: 3424DBF357F64B2F1B-8060 Subsystem 1 - Part No: 4G0 907 568 H Component: J770 SWA Slave H01 0010 Subsystem 2 - Serial number: 6PZ 010 287-22 Subsystem 3 - Serial number: 5F20.01.1100H010003C720426ˇ Subsystem 4 - Serial number: 720426ˇ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb Part No SW: 4G8 959 793 C HW: 4G8 959 793 A Component: TSG FA H04 0210 Revision: -------- Serial number: -------------- Coding: 011F47225E00628002000002 Shop #: WSC 02312 785 00200 VCID: 40CC8723D34EE78F8F-8014 2 Faults Found: 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 19 Reset counter: 23 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:41:46 01314 - Engine Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 37 Reset counter: 23 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:41:58 ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb Part No SW: 4G0 909 144 L HW: 4G0 909 144 F Component: RCEPS H32 0010 Revision: 00001000 Serial number: 0014031213 Coding: 101000010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RCEPS 009008 ROD: EV_RCEPS_009.rod (VIN: N/A) VCID: 3228DDEB65E2451F09-8066 6 Faults Found: 3158274 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [Ausfall Botschaft "PDU_Motor_03"] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 73 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:53 Write only channel 3158276 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [Ausfall Botschaft "PDU_LWI_01"] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 126 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:57 Write only channel 4205828 - Steering angle sensor B1168 54 [137] - Missing Calibration / Basic Setting MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 23 Mileage: 285336 km Date: 2022.07.19 Time: 03:54:32 Write only channel 4208000 - Steering Angle Sensor B1168 F1 [008] - Synchronization Failed Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 63 Reset counter: 70 Mileage: 285336 km Date: 2022.07.18 Time: 18:44:06 Write only channel 5258753 - Steering End Stops Not Learned C10AC F0 [137] - Unknown Error Elaboration [Lenkungsendanschl‰ge nicht angelernt] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 23 Mileage: 285336 km Date: 2022.07.19 Time: 03:54:32 Write only channel 15888 - Terminal 15 U1405 00 [008] - Implausible signal [Unplausibles Klemme 15 (Z¸ndungssignal)] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 8 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 20:39:51 Write only channel ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb Part No SW: 4H0 907 064 AR HW: 4H0 907 064 AR Component: BCM2 2.0 H24 0217 Revision: 00002001 Serial number: 0142700354 Coding: 0126063A20FAF48480B00A0002010000000000000000000000 0000000000 Shop #: WSC 02311 785 00200 VCID: 79BA2AC7F014764788-802C Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719 Component: GTO BF H01 0070 Serial number: 00000000000000020427 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591 Component: J245 PS40.033 H07 0006 Serial number: WOO1111272W Coding: 001F00 Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252 Component: HSP-SG H09 0027 Serial number: WA100924000000184481 5 Faults Found: 01315 - Transmission Control Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 88 Reset counter: 23 Mileage: 285335 km Time Indication: 0 Date: 2022.07.18 Time: 05:37:10 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 47 Reset counter: 63 Mileage: 285335 km Time Indication: 0 Date: 2022.07.18 Time: 05:37:14 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 31 Reset counter: 63 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:41:42 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 39 Reset counter: 63 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:41:54 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 46 Reset counter: 63 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:42:02 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb Part No SW: 4G8 959 792 C HW: 4G8 959 792 A Component: TSG BF H04 0210 Revision: -------- Serial number: -------------- Coding: 011F47225E00628002000002 Shop #: WSC 02312 785 00200 VCID: 3FCE84DFAEB09877F6-806A 2 Faults Found: 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 19 Reset counter: 63 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:41:46 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 37 Reset counter: 63 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:41:58 ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 E HW: 4H0 907 801 A Component: EPB-4 H03 0012 Revision: -------- Serial number: 00000000029338 ASAM Dataset: EV_ParkiBrake 001022 ROD: EV_ParkiBrake_VW51.rod VCID: 2A18C58B4D320DDFB1-807E 4 Faults Found: 13641472 - Powertrain Databus U0001 00 [008] - Unspecified Malfunction [FC_CAN_BUSOFF] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:40 Voltage terminal 30: 14.0 V Internal Fault ID: 59 Vehicle speed: 510 km/h Network management state: normal Function light in parking brake button: OFF Red operating lamp: OFF Red warning lamp: OFF Green operating lamp: OFF Yellow warning lamp: OFF Terminal 15 status: OFF RWU: not active DSD: not active HTR: not active ECD: not active ACC requested apply: not active Auto Adjust: not active General Inspection Function: not active Internal Parking Brake state: Emergency running mode Status of parking brake button: Not operated Status ParkingBrake left: Open Status ParkingBrake right: Open 329728 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [FC_GETRIEBE_03_MESSAGE_TIMEOUT] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 6 Reset counter: 63 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:55 Voltage terminal 30: 13.6 V Internal Fault ID: 94 Vehicle speed: 42 km/h Network management state: normal Function light in parking brake button: OFF Red operating lamp: OFF Red warning lamp: OFF Green operating lamp: OFF Yellow warning lamp: OFF Terminal 15 status: On RWU: not active DSD: not active HTR: not active ECD: not active ACC requested apply: not active Auto Adjust: not active General Inspection Function: not active Internal Parking Brake state: Dynamic Status of parking brake button: Not operated Status ParkingBrake left: Open Status ParkingBrake right: Open 329984 - Function Restricted due to Missing Message(s) U1111 00 [009] - - [FC_GETRIEBE_04_MESSAGE_TIMEOUT] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 23 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:09 Voltage terminal 30: 13.1 V Internal Fault ID: 95 Vehicle speed: 0 km/h Network management state: normal Function light in parking brake button: OFF Red operating lamp: OFF Red warning lamp: OFF Green operating lamp: OFF Yellow warning lamp: OFF Terminal 15 status: On RWU: not active DSD: not active HTR: not active ECD: not active ACC requested apply: not active Auto Adjust: not active General Inspection Function: not active Internal Parking Brake state: static Status of parking brake button: Not operated Status ParkingBrake left: Open Status ParkingBrake right: Open 396544 - Function Restriction due to Implausible Message(s) U1112 00 [008] - - [FC_ESP_01_MESSAGE_COUNTER] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 62 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:13 Voltage terminal 30: 13.2 V Internal Fault ID: 114 Vehicle speed: 510 km/h Network management state: normal Function light in parking brake button: OFF Red operating lamp: OFF Red warning lamp: OFF Green operating lamp: OFF Yellow warning lamp: OFF Terminal 15 status: On RWU: not active DSD: not active HTR: not active ECD: not active ACC requested apply: not active Auto Adjust: not active General Inspection Function: not active Internal Parking Brake state: Emergency running mode Status of parking brake button: Not operated Status ParkingBrake left: Open Status ParkingBrake right: Open ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb Part No SW: 4H0 907 357 A HW: 4H0 907 357 A Component: ....LWR12.... H02 0012 Serial number: 110128-0004-051 Coding: 1223A6101002A400 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_HeadlRegulBasic 005001 ROD: EV_HeadlRegulBasic_AU21.rod VCID: 2C14C39347C613EF43-8078 1 Fault Found: 336388 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [Timeout CAN-Message Motor_03 (0x105)] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 48 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:53 ------------------------------------------------------------------------------- Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb Part No SW: 4G0 035 082 A HW: 4G0 035 082 Component: Radio U SIRIU H51 0068 Revision: AB001007 Serial number: 156AJ0B7500313 Coding: 020007020100000001 Shop #: WSC 02311 785 00200 VCID: 1E70195B097AF17FDD-804A 6 Faults Found: 00870 - Bass Speaker Front Left (R21) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 20 Mileage: 285319 km Time Indication: 0 Date: 2022.07.06 Time: 17:26:12 Freeze Frame: Voltage: 11.60 V 00871 - Bass Speaker Front Right (R23) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 20 Mileage: 285319 km Time Indication: 0 Date: 2022.07.06 Time: 17:26:12 Freeze Frame: Voltage: 11.60 V 02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 20 Mileage: 285319 km Time Indication: 0 Date: 2022.07.06 Time: 17:26:12 Freeze Frame: Voltage: 11.60 V 02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 20 Mileage: 285319 km Time Indication: 0 Date: 2022.07.06 Time: 17:26:12 Freeze Frame: Voltage: 11.60 V 03029 - Subwoofer (R157) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 20 Mileage: 285319 km Time Indication: 0 Date: 2022.07.06 Time: 17:26:12 Freeze Frame: Voltage: 11.60 V 03278 - Functionality Limited due to Missing Messages 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 12 Reset counter: 63 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 20:56:25 Freeze Frame: Bin. Bits: 00000000 00001000 ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4G0 035 746 HW: 4G0 035 746 Component: H-BNT-NA H48 0294 Revision: -------- Serial number: 031AM0B7501629 Coding: 090200040003E0EF55128B2E000000031000010000000000 Shop #: WSC 02311 785 00200 VCID: 64846BB367969BAF4B-8030 Subsystem 1 - Part No: 8R0 060 884 AC Component: NAR 2011 0503 Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A Component: DU8 C7 SV H42 0021 Serial number: AUZ8ZDB13008MZ$ Subsystem 3 - Part No SW: 4G1 919 612 L HW: 4G1 919 612 L Component: E380 BDT C7 H08 0120 Serial number: 90349KAQ0008K Subsystem 4 - Part No: 8R0 060 961 A Component: CD-Database 2712 1 Fault Found: 03278 - Functionality Limited due to Missing Messages 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 5 Reset counter: 63 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 20:56:31 Freeze Frame: Bin. Bits: 00010000 00000000 Bin. Bits: 00000000 00010000 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb Part No SW: 4G8 959 795 C HW: 4G8 959 795 A Component: TSG HL H03 0210 Revision: -------- Serial number: -------------- Coding: 010F07224000628002000002 Shop #: WSC 02312 785 00200 VCID: 42C88D2BDD42F59F99-8016 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4H0-907-441.clb Part No SW: 4G0 907 441 A HW: 4H0 907 441 Component: SG Rueckfahrkamera 0050 Revision: --H04--- Serial number: 525 PA8J11F0S5 Coding: 1020013 Shop #: WSC 07924 002 1048576 VCID: 250236B7EC2C22A79C-8070 1 Fault Found: 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 36 Reset counter: 63 Mileage: 285336 km Time Indication: 0 Date: 2022.07.18 Time: 18:42:00 Freeze Frame: Term 15 On Reverse OFF Count: 3 ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (----) Labels:* Redir Fail! Part No SW: 4G8 959 107 E HW: 4G8 959 107 A Component: HDSG-Modul H12 0036 Revision: 12012001 Serial number: 009100273 Coding: 0A3205C100 Shop #: WSC 02311 785 00200 ASAM Dataset: EV_HDSGAu573 001014 ROD: EV_HDSGAu571.rod VCID: 373EECFF8E80A0373E-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb Part No SW: 4G8 959 795 C HW: 4G8 959 795 A Component: TSG HR H03 0210 Revision: -------- Serial number: -------------- Coding: 010F07224000628002000002 Shop #: WSC 02312 785 00200 VCID: 42C88D2BDD42F59F99-8016 No fault code found. ------------------------------------------------------------------------------- Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 945 HW: 4H0 980 945 Component: RGS-VL H05 0070 Coding: 0006E008031F0300070308014244CA010000 Shop #: WSC 02311 785 00200 ASAM Dataset: EV_RGS_L 002004 ROD: EV_RGS_L.rod VCID: 6FAE149FB65028F726-803A 8 Faults Found: 12583681 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 41 Reset counter: 63 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:29 12583682 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 37 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:43 12583690 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 102 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:57 12583691 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 51 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:53 12583692 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 43 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:51 12583961 - Function Restriction due to Implausible Message(s) U1112 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 10 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:55 12583964 - Function Restriction due to Implausible Message(s) U1112 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:52 12584197 - Function Restriction due to Faults in Other Modules U1113 00 [008] - - [Function limitation due to received error] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 63 Mileage: 285336 km Date: 2022.07.19 Time: 03:54:32 ------------------------------------------------------------------------------- Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 946 HW: 4H0 980 946 Component: RGS-VR H05 0070 Coding: 0006E008031F0300070308014244CA010000 Shop #: WSC 02311 785 00200 ASAM Dataset: EV_RGS_R 002004 ROD: EV_RGS_R.rod VCID: 70AC17E3AB6E370F3F-8024 8 Faults Found: 12583681 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 41 Reset counter: 63 Mileage: 285335 km Date: 2022.07.18 Time: 05:37:29 12583682 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 37 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:43 12583690 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 102 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:57 12583691 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 51 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:53 12583692 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 43 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:51 12583961 - Function Restriction due to Implausible Message(s) U1112 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 9 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:55 12583964 - Function Restriction due to Implausible Message(s) U1112 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 63 Mileage: 285336 km Date: 2022.07.18 Time: 18:41:52 12584197 - Function Restriction due to Faults in Other Modules U1113 00 [008] - - [Function limitation due to received error] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 63 Mileage: 285336 km Date: 2022.07.19 Time: 03:54:32 End----------(Elapsed Time: 02:45, VBatt start/end: 12.2V/12.2V)----------- What should I be looking for next, since the battery isn't the issue? I see common problems are the Gateway Module, and the coolant control valve. I can check both tomorrow, but I'm not sure where the Gateway module is located. I'm assuming it's behind the glovebox somewhere... Has anyone had a problem like this, and had success fixing it; or should I just save myself some time and have it towed to the dealer? |
Do you remember what ended up being the issue? Bad battery ?
My mechanic found fluid in the transmission connector of the wiring harness, which shorted out the electronics in the transmission. He installed a used transmission, replaced the corroded connector, and replaced the coolant control valve which is notorious for going bad and allowing coolant to seep into the wiring harness. $4,500 later, the car was back on the road.
