2012 A7 Multiple warnings/lights - car won't start
Just yesterday, my wife was driving my car three blocks to her work, and said that the dash lit up with multiple warnings, lights, a gearbox malfunction message, and didn't want to shift. Once I showed up, I seen the multiple messages, and the car wouldn't try to start. It kept stating that the car must be in P or N to start, which it already was. Since that's all that the car's been driven the past few months, I figured the problem was just a low battery. I had the car towed home, and when I put it on the charger, the charger registered the battery at 12.0V and 50% capacity. This morning, it was up to 13.2V and 95% capacity. I connected the car to VCDS to try to clear the codes, and as soon as I did, the codes immediately came back, and just like yesterday - it refuses to start.
Here's what the scan in VCDS came up with: (This is long)...
Tuesday,19,July,2022,03:57:37:52516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64) HEX-NET CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WAUSGAFC7CN001498 License Plate: HISAUDI
Mileage: 285336km-177299mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 3B 3C 42 44 46 52 53
55 56 5F 62 6C 6D 72 8F 90
VIN: WAUSGAFC7CN001498 Mileage: 285336km-177299miles
01-Engine -- Status: Malfunction 0110
02-Auto Trans -- Status: Malfunction 0110
03-ABS Brakes -- Status: Malfunction 0110
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 0100
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0110
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 HW: 4G0 907 379
Component: ESP PREMIUM H08 0190
Revision: -------- Serial number: --------------
Coding: 44A70F0222E5F0405B00
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod (VIN: N/A)
VCID: 6E90099BB15A21FF2D-803A
20 Faults Found:
0004 - Brake Switch (F)
P0571 00 [129] - Implausible Signal
MIL ON - Not Confirmed - Tested Since Memory Clear
0044 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Airbag_01_Timeout]
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.19
Time: 03:53:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: B3
Uz: 9F
0051 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_EPB_01_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
VzRef: 00
Bit Info 1: 80
Bit Info 2: 40
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: BC
Uz: A7
0058 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Getriebe_01_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 20:40:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: C4
Uz: 9A
0060 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Getriebe_03_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
VzRef: 00
Bit Info 1: 80
Bit Info 2: 40
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: C7
Uz: A7
0067 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_LWI_01_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.19
Time: 03:53:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: DF
Uz: 9C
0069 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
[ComScl_PDU_Motor_01_Timeout]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 20:40:06
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: E7
Uz: 99
0071 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
[ComScl_PDU_Motor_02_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.19
Time: 03:53:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: F4
Uz: 9F
0073 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
[ComScl_PDU_Motor_03_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 20:40:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: F9
Uz: 9A
0075 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Motor_10_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 20:40:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: FC
Uz: 9A
0077 - Function Restricted due to Missing Message(s)
U1111 00 [129] - -
[ComScl_PDU_Motor_Code_01_Timeout]
0091 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_TSK_05_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 20:40:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 01
F-Type: 10
Uz: 9A
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Ldm_ApbFailureState]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 02
F-Type: 06
Uz: A5
0557 - Powertrain Databus
U0001 00 [137] - Unspecified Malfunction
[NET_BusOffNetwork0]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 18:54:15
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: 71
Uz: A5
0722 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
[SCL_MO_Drehzahl_01_Invalid]
0725 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
[SCL_MO_Fahrpedalrohwert_01_Invalid]
0838 - Function Restriction due to Faults in Other Modules
U1113 00 [129] - -
[SCL_MO_Mom_Begrenzung_Invalid]
0727 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
[SCL_MO_Mom_Fahrerwunsch_Invalid]
0729 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
[SCL_MO_Mom_Verlust_Invalid]
0731 - Function Restriction due to Implausible Message(s)
U1112 00 [129] - -
[SCL_MO_Mom_m_ex_Invalid]
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AR HW: 4H0 907 064 AR
Component: BCM2 2.0 H24 0217
Revision: 00002001
Coding: 098A3000000000000000
VCID: 79BA2AC7F014764788-802C
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2310000102613006
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 22
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:10
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 N HW: 4G0 820 043 N
Component: KLIMA 2 ZONEN H10 0055
Serial number: 19011100040272
Coding: 6603201808
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AirCondiBasisUDS 002031
ROD: EV_AirCondiBasisUDS_002.rod (VIN: N/A)
VCID: 2A18C58B4D320DDFB1-807E
2 Faults Found:
0260 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuerger‰t f¸r Airbag: kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 28
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:47
Voltage terminal 30: 13.82 V
Terminal 15 status: Terminal 15 on
Outside temperature: 33.5 ∞C
0331 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Motorsteuerger‰t: kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 59
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:54
Voltage terminal 30: 13.88 V
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000000771020
Coding: 06002015023C9FE08100088380003928CF9CD208A209012100 0004402000
VCID: 2C14C3934FC613EF43-8078
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 110130 H32 0051
Serial number: 110131115120
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11247671
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 26 01 2011 00000095
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R09JP06
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: 57380E55000000000001
6 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 05:41:00
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 12
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:00
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:00
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:00
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:00
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:00
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 A HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0470
Revision: 00000006
VCID: 2B16C08F4AC814D74A-807E
No fault code found.
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 H HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0030
Revision: 11001001 Serial number: 55901102002123
Coding: 300103
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod (VIN: N/A)
VCID: 373EECFF8E80A0373E-8062
2 Faults Found:
12658704 - Databus
U1121 00 [009] - Missing Message
[Steuerger‰t f¸r elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 35
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
12648720 - Databus
[Getriebesteuerger‰t - Getriebe_03 - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20110202000126
Coding: 000014
VCID: 302CD7E363EE770F7F-8064
Subsystem 1 - Part No SW: 4G0 951 528 B HW: 4G0 951 528 B
Component: E221 - MFL H07 0009
6 Faults Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 30
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:22
01312 - Powertrain Data Bus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:23
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 117
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:59
02085 - Incorrect Control Module Installed
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.19
Time: 03:53:56
Freeze Frame:
Voltage: 12.30 V
Hex Value: 0x0000
Speed: 0.0 km/h
Steering Angle: -29.27∞
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.19
Time: 03:54:32
Freeze Frame:
Voltage: 12.20 V
Hex Value: 0x0000
Speed: 0.0 km/h
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 981 E HW: 4G8 920 981 E
Component: TBenUsa H34 0309
Revision: 18100069 Serial number: 658240111593024
Coding: 0BE701060B03D705020100
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod (VIN: N/A)
VCID: 3522E6F7948C52272C-8060
4 Faults Found:
16776962 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Airbag_01 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 38
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:28
16776967 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[EPB_02 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 35
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
16776971 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Motor_03 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 46
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:52
16777209 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
[WBA_02 unplausibles Signal CHK]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 20:48:52
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000089792
Coding: 00C1033000
GVL: FDE1E80CDE63600D00
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod (VIN: N/A)
VCID: 302CD7E36BEE770F7F-8064
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650444302
5 Faults Found:
4226 - No Communication with Transmission Control Module
U0101 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 63
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
Voltage terminal 30: 12.8 V
Voltage terminal 15: 12.8 V
Control Module temperature: 22 ∞C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
4356 - No Communications with Parking Brake Control Module
U0128 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 62
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
4228 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 63
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
0256 - Powertrain Databus
U0001 00 [008] - Unspecified Malfunction
[High Speed CAN Communication]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 254
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:57
Voltage terminal 30: 13.7 V
Voltage terminal 15: 13.7 V
Control Module temperature: 46 ∞C
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
0264 - Powertrain Databus (VAG Single-Wire Mode) (SAE L Shorted H)
U0009 00 [008] - -
[Datenbus Antrieb Eindraht]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 32
Reset counter: 63
Mileage: 285332 km
Date: 2022.07.17
Time: 01:40:52
Voltage terminal 15: 12.9 V
Control Module temperature: 24 ∞C
IN ESP_standstill flag: no standstill detected
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00001002230042
Coding: 0058130000002001000001010101102030303232203232
VCID: 77BE2CFFC6006037FE-8022
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 40
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:29
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200AX440
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod (VIN: N/A)
VCID: 2D12CE977CDC1AE754-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 H HW: 4G0 907 566
Component: J769 SWA MasterH01 0010
Revision: 00H01000 Serial number: 6PZ 010 287-02
Coding: 0000003
VCID: 3424DBF357F64B2F1B-8060
Subsystem 1 - Part No: 4G0 907 568 H
Component: J770 SWA Slave H01 0010
Subsystem 2 - Serial number: 6PZ 010 287-22
Subsystem 3 - Serial number: 5F20.01.1100H010003C720426ˇ
Subsystem 4 - Serial number: 720426ˇ
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 C HW: 4G8 959 793 A
Component: TSG FA H04 0210
Coding: 011F47225E00628002000002
Shop #: WSC 02312 785 00200
VCID: 40CC8723D34EE78F8F-8014
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:58
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 F
Component: RCEPS H32 0010
Revision: 00001000 Serial number: 0014031213
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod (VIN: N/A)
VCID: 3228DDEB65E2451F09-8066
6 Faults Found:
3158274 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Ausfall Botschaft "PDU_Motor_03"]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 73
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:53
Write only channel
3158276 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Ausfall Botschaft "PDU_LWI_01"]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 126
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:57
Write only channel
4205828 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.19
Time: 03:54:32
Write only channel
4208000 - Steering Angle Sensor
B1168 F1 [008] - Synchronization Failed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 63
Reset counter: 70
Mileage: 285336 km
Date: 2022.07.18
Time: 18:44:06
Write only channel
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
[Lenkungsendanschl‰ge nicht angelernt]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.19
Time: 03:54:32
Write only channel
15888 - Terminal 15
U1405 00 [008] - Implausible signal
[Unplausibles Klemme 15 (Z¸ndungssignal)]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 20:39:51
Write only channel
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0142700354
Coding: 0126063A20FAF48480B00A0002010000000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000020427
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO1111272W
Coding: 001F00
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
Serial number: WA100924000000184481
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 88
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:10
Freeze Frame:
Fault Priority: 6
Fault Frequency: 47
Reset counter: 63
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:14
Freeze Frame:
Fault Priority: 6
Fault Frequency: 31
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:42
Freeze Frame:
Fault Priority: 6
Fault Frequency: 39
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:54
Freeze Frame:
Fault Priority: 6
Fault Frequency: 46
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:42:02
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
VCID: 3FCE84DFAEB09877F6-806A
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:58
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000029338
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
4 Faults Found:
13641472 - Powertrain Databus
[FC_CAN_BUSOFF]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:40
Voltage terminal 30: 14.0 V
Internal Fault ID: 59
Vehicle speed: 510 km/h
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: Emergency running mode
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
329728 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FC_GETRIEBE_03_MESSAGE_TIMEOUT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 63
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:55
Voltage terminal 30: 13.6 V
Internal Fault ID: 94
Vehicle speed: 42 km/h
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Internal Parking Brake state: Dynamic
329984 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FC_GETRIEBE_04_MESSAGE_TIMEOUT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
Voltage terminal 30: 13.1 V
Internal Fault ID: 95
Vehicle speed: 0 km/h
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Internal Parking Brake state: static
396544 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
[FC_ESP_01_MESSAGE_COUNTER]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 62
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:13
Voltage terminal 30: 13.2 V
Internal Fault ID: 114
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0012
Serial number: 110128-0004-051
Coding: 1223A6101002A400
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 2C14C39347C613EF43-8078
1 Fault Found:
336388 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Timeout CAN-Message Motor_03 (0x105)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 48
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:53
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 A HW: 4G0 035 082
Component: Radio U SIRIU H51 0068
Revision: AB001007 Serial number: 156AJ0B7500313
Coding: 020007020100000001
VCID: 1E70195B097AF17FDD-804A
6 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 285319 km
Time Indication: 0
Date: 2022.07.06
Time: 17:26:12
Freeze Frame:
Voltage: 11.60 V
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 285319 km
Time Indication: 0
Date: 2022.07.06
Time: 17:26:12
Freeze Frame:
Voltage: 11.60 V
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 285319 km
Time Indication: 0
Date: 2022.07.06
Time: 17:26:12
Freeze Frame:
Voltage: 11.60 V
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 285319 km
Time Indication: 0
Date: 2022.07.06
Time: 17:26:12
Freeze Frame:
Voltage: 11.60 V
03029 - Subwoofer (R157)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 285319 km
Time Indication: 0
Date: 2022.07.06
Time: 17:26:12
Freeze Frame:
Voltage: 11.60 V
03278 - Functionality Limited due to Missing Messages
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 12
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 20:56:25
Freeze Frame:
Bin. Bits: 00000000 00001000
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 HW: 4G0 035 746
Component: H-BNT-NA H48 0294
Revision: -------- Serial number: 031AM0B7501629
Coding: 090200040003E0EF55128B2E000000031000010000000000
VCID: 64846BB367969BAF4B-8030
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB13008MZ$
Subsystem 3 - Part No SW: 4G1 919 612 L HW: 4G1 919 612 L
Component: E380 BDT C7 H08 0120
Serial number: 90349KAQ0008K
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 20:56:31
Freeze Frame:
Bin. Bits: 00010000 00000000
Bin. Bits: 00000000 00010000
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F07224000628002000002
VCID: 42C88D2BDD42F59F99-8016
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J11F0S5
Coding: 1020013
Shop #: WSC 07924 002 1048576
VCID: 250236B7EC2C22A79C-8070
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 36
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:42:00
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 E HW: 4G8 959 107 A
Component: HDSG-Modul H12 0036
Revision: 12012001 Serial number: 009100273
Coding: 0A3205C100
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0210
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FAE149FB65028F726-803A
8 Faults Found:
12583681 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 41
Reset counter: 63
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:29
12583682 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:43
12583690 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 102
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:57
12583691 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 51
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:53
12583692 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 43
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:51
12583961 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:55
12583964 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:52
12584197 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Function limitation due to received error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.19
Time: 03:54:32
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70AC17E3AB6E370F3F-8024
8 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 41
Reset counter: 63
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:29
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:43
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:57
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 51
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:53
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 43
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:51
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:55
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:52
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.19
Time: 03:54:32
End----------(Elapsed Time: 02:45, VBatt start/end: 12.2V/12.2V)-----------
What should I be looking for next, since the battery isn't the issue? I see common problems are the Gateway Module, and the coolant control valve. I can check both tomorrow, but I'm not sure where the Gateway module is located. I'm assuming it's behind the glovebox somewhere... Has anyone had a problem like this, and had success fixing it; or should I just save myself some time and have it towed to the dealer?
www.Ross-Tech.com
Address 01: Engine
Cannot be reached
Cannot be reached
20 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.19
Time: 03:53:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: B3
Uz: 9F
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
VzRef: 00
Bit Info 1: 80
Bit Info 2: 40
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: BC
Uz: A7
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 20:40:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: C4
Uz: 9A
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
VzRef: 00
Bit Info 1: 80
Bit Info 2: 40
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: C7
Uz: A7
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.19
Time: 03:53:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: DF
Uz: 9C
U1111 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 20:40:06
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: E7
Uz: 99
U1111 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.19
Time: 03:53:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: F4
Uz: 9F
U1111 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 20:40:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: F9
Uz: 9A
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 20:40:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: FC
Uz: 9A
U1111 00 [129] - -
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 20:40:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 01
F-Type: 10
Uz: 9A
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 02
F-Type: 06
Uz: A5
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 18:54:15
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 00
F-Type: 71
Uz: A5
U1112 00 [129] - -
U1112 00 [129] - -
U1113 00 [129] - -
U1112 00 [129] - -
U1112 00 [129] - -
U1112 00 [129] - -
Revision: 00002001
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 22
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:10
Coding: 6603201808
2 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 28
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:47
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 59
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:54
Coding: 0045F7
Coding: 02562B
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 05:41:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:00
Revision: 00000006
Coding: 300103
2 Faults Found:
12658704 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 35
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
12648720 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
Address 15: Airbags
Cannot be reached
Coding: 000014
6 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 30
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:23
Freeze Frame:
Fault Priority: 2
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:59
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.19
Time: 03:53:56
Freeze Frame:
Voltage: 12.30 V
Hex Value: 0x0000
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.19
Time: 03:54:32
Freeze Frame:
Voltage: 12.20 V
Hex Value: 0x0000
Speed: 0.0 km/h
4 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 38
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:28
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 35
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 46
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:52
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 20:48:52
Coding: 00C1033000
5 Faults Found:
U0101 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 63
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
U0128 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 62
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
U0121 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 63
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Freeze Frame:
Fault Priority: 1
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:57
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
U0009 00 [008] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 32
Reset counter: 63
Mileage: 285332 km
Date: 2022.07.17
Time: 01:40:52
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 40
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:29
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 23
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:58
6 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 73
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:53
Write only channel
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:57
Write only channel
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.19
Time: 03:54:32
Write only channel
Freeze Frame:
Fault Priority: 2
Fault Frequency: 63
Reset counter: 70
Mileage: 285336 km
Date: 2022.07.18
Time: 18:44:06
Write only channel
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 285336 km
Date: 2022.07.19
Time: 03:54:32
Write only channel
15888 - Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 20:39:51
Write only channel
Coding: 001F00
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 88
Reset counter: 23
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:10
Freeze Frame:
Fault Priority: 6
Fault Frequency: 47
Reset counter: 63
Mileage: 285335 km
Time Indication: 0
Date: 2022.07.18
Time: 05:37:14
Freeze Frame:
Fault Priority: 6
Fault Frequency: 31
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:42
Freeze Frame:
Fault Priority: 6
Fault Frequency: 39
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:54
Freeze Frame:
Fault Priority: 6
Fault Frequency: 46
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:42:02
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:41:58
4 Faults Found:
[FC_CAN_BUSOFF]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:40
RWU: not active
DSD: not active
HTR: not active
ECD: not active
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 63
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:55
RWU: not active
DSD: not active
HTR: not active
ECD: not active
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 23
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:09
RWU: not active
DSD: not active
HTR: not active
ECD: not active
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 62
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:13
RWU: not active
DSD: not active
HTR: not active
ECD: not active
1 Fault Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 48
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:53
6 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 285319 km
Time Indication: 0
Date: 2022.07.06
Time: 17:26:12
Freeze Frame:
Voltage: 11.60 V
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 285319 km
Time Indication: 0
Date: 2022.07.06
Time: 17:26:12
Freeze Frame:
Voltage: 11.60 V
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 285319 km
Time Indication: 0
Date: 2022.07.06
Time: 17:26:12
Freeze Frame:
Voltage: 11.60 V
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 285319 km
Time Indication: 0
Date: 2022.07.06
Time: 17:26:12
Freeze Frame:
Voltage: 11.60 V
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 285319 km
Time Indication: 0
Date: 2022.07.06
Time: 17:26:12
Freeze Frame:
Voltage: 11.60 V
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 20:56:25
Freeze Frame:
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 20:56:31
Freeze Frame:
Coding: 1020013
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 36
Reset counter: 63
Mileage: 285336 km
Time Indication: 0
Date: 2022.07.18
Time: 18:42:00
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Coding: 0A3205C100
ROD: EV_RGS_L.rod
8 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 41
Reset counter: 63
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:29
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:43
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:57
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 51
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:53
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 43
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:51
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:55
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:52
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.19
Time: 03:54:32
ROD: EV_RGS_R.rod
8 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 41
Reset counter: 63
Mileage: 285335 km
Date: 2022.07.18
Time: 05:37:29
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 37
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:43
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:57
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 51
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:53
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 43
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:51
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:55
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.18
Time: 18:41:52
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 285336 km
Date: 2022.07.19
Time: 03:54:32
My mechanic found fluid in the transmission connector of the wiring harness, which shorted out the electronics in the transmission. He installed a used transmission, replaced the corroded connector, and replaced the coolant control valve which is notorious for going bad and allowing coolant to seep into the wiring harness. $4,500 later, the car was back on the road.
Hobbes29
05-12-2022 03:13 PM
