2014 Audi A7 weird ACC issues
Hi,
We are working on a 2014 Audi A7 with a very weird problem. This car is equipped with adaptive cruise control. Whenever the car started, we are getting an error message stating that "acc and audi braking guard not available" but a second after it, the message disappears completely (No exclamation mark on the cluster) and everything goes back to work properly, including the adaptive cruise. We have scanned the car both with rosstech and ODIS online, I have attached the VCDS scan below. Both ACC modules are throwing many error messages, and it seems like some of the messages core codes, are referring to no communication to the airbag modules (FAULT_CIM_TIMEOUT_Airbag_01) etc. Has anyone ever experienced anything like it? We do not have access to Elsa Pro (Just to ODIS online). Is there an SVM code for update to the ACC modules, or to any other modules that can be related to it? We have tried to do online SVM comparison but there was nothing to change. Thanks!!! Friday,17,August,2018,16:35:52:41975 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4427.4 Data version: 20180518 DS287.1 http://www.Ross-Tech.com Chassis Type: FC-AU57 (4G0) Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3B 3C 42 44 46 47 52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 VIN: WAUWGAFC7ENxxxxxx Mileage: 36551km-22711miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3B-Sensor Elect. -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 85-On Board Cam. -- Status: OK 0000 8B-Adaptive Cruise 2 -- Status: Malfunction 0010 8E-Image Processing -- Status: OK 0000 8F-Pretens. Frt Left -- Status: OK 0000 90-Pretens. Frt Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CTUA) Labels: None Part No SW: 4G0 907 551 J HW: 4G0 907 551 A Component: 3.0l V6 TFSIH07 0004 Revision: --H07--- Coding: 1A2A0032056601060000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ECM30TFS0214G0907551J 001004 ROD: EV_ECM30TFS0214G0907551J.rod VCID: B02C6BD1EB8024C417-80E4 No fault code found. Readiness: 1110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM Component: 0BK 30TFSIUSA H16 1006 Revision: --H16--- Coding: 000002 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002022 ROD: EV_TCMAL551211_002_AU48.rod VCID: AD1272A5FCB2492C3C-80F8 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb Part No SW: 4G0 907 379 M HW: 4G0 907 379 M Component: ESP PREMIUM H09 0450 Revision: -------- Serial number: -------------- Coding: 44A7970322E5E9C05B00 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ESPPremiAU57X 004039 ROD: EV_ESPPremiAU57X_004_AU57.rod VCID: BB364CFD32C6D79CB2-80EE No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 4H0 907 064 ER HW: 4H0 907 064 ER Component: BCM2 2.0 H36 0521 Revision: 00002001 Coding: 0DAA2046000000000000 Shop #: WSC 02391 785 00200 VCID: FDB282E5645219ACCC-80A8 Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C Component: J764 ELV MLB H40 0046 Serial number: 0214000018549006 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:* None Part No SW: 4G0 820 043 AQ HW: 4G0 820 043 AQ Component: KLIMA 2 ZONEN H14 0094 Serial number: 24021400111162 Coding: 668320184D Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiBasisUDS 004002 ROD: EV_AirCondiBasisUDS_004.rod VCID: EE90B5A93134723445-80BA No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb Part No SW: 4H0 907 063 CG HW: 4H0 907 063 Component: BCM1 2.0 H12 0130 Revision: 11012002 Serial number: 00000001846466 Coding: 06002091063C9FE28100088380003928CF9CD208A609022100 0004406000 Shop #: WSC 02391 785 00200 VCID: EFAEA8AD3E3E7B3C4E-80BA Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB Component: WWS57X 140217 H37 0080 Serial number: 140219153029 Coding: 0045F7 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 22300243 Coding: 02006E Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D Component: E1 - LDS H07 0044 Serial number: 12 02 2014 00000328 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Serial number: 0000002274555R2K1J02 Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A Component: Humidity_Sens H03 0002 Serial number: 07B88417000000000001 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG Component: PARKHILFE ACC H01 0083 Revision: 11001001 Serial number: 61061405601389 Coding: A8EB03 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_EPHVA18AU57X0000 004009 ROD: EV_EPHVA18AU57X0000_004.rod VCID: F1AAAED5200A6DCC58-80A4 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb Part No SW: 4G0 907 561 A HW: 4G0 907 561 Component: ACC3 H19 0410 Serial number: 00000000000000 Coding: 7E01010201 Shop #: WSC 00736 003 1048576 ASAM Dataset: EV_AdaptCruisContrAU57X 002010 ROD: EV_AdaptCruisContrAU57X_002.rod VCID: A81C83B1D3506C04CF-80FC 10 Faults Found: 21760 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_APSM] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:57:59 Control Module temperature: 72 °C Voltage terminal 15: 12.459 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: -0.01 m/s² 22016 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_Linie_01] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:57:58 Control Module temperature: 72 °C Voltage terminal 15: 12.029 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: -0.01 m/s² 22272 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_Linie_02] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:57:58 Control Module temperature: 72 °C Voltage terminal 15: 12.029 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: -0.01 m/s² 22528 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_Linie_03] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:57:58 Control Module temperature: 72 °C Voltage terminal 15: 12.029 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: -0.01 m/s² 22784 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_Linie_04] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:57:58 Control Module temperature: 72 °C Voltage terminal 15: 12.029 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: -0.01 m/s² 23040 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_Linie_05] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:57:58 Control Module temperature: 72 °C Voltage terminal 15: 12.029 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: -0.01 m/s² 23296 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_Linie_06] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:57:58 Control Module temperature: 72 °C Voltage terminal 15: 12.029 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: -0.01 m/s² 23552 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_Linie_07] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:57:58 Control Module temperature: 72 °C Voltage terminal 15: 12.029 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: -0.01 m/s² 23808 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_Linie_08] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:57:58 Control Module temperature: 72 °C Voltage terminal 15: 12.029 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: -0.01 m/s² 24064 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_Linie_Master] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:57:58 Control Module temperature: 72 °C Voltage terminal 15: 12.029 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: -0.01 m/s² ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 4H0-959-655.clb Part No SW: 4G0 959 655 A HW: 4G0 959 655 A Component: Airbag10.43 H33 0033 Revision: -------- Serial number: 003D8003WVZ$ Coding: 303145313131303031304A55304C34473853 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirbaAU10BPAAU64X 001014 ROD: EV_AirbaAU10BPAAU64X_VW51.rod VCID: B32664DD1A961FDC6A-80E6 Seat occupied recognition: Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B Component: BF-Gewichtss. H10 0046 Serial number: 6940000Y1400012CYT07 Crash sensor for side airbag: driver side: Serial number: 3575HRB40572BDG0115B Crash sensor for side airbag: front passenger side: Serial number: 3585HRB405T2B8KKB9K0 Crash sensor for side airbag: rear: driver side: Serial number: 3515JRB401C50STULP6H Crash sensor for side airbag: rear: passenger side: Serial number: 3525JRB401A50TT6NH5T Crash sensor for front airbag: driver side: Serial number: 3554VRB400M50SAEH26M Crash sensor for front airbag: front passenger side: Serial number: 3564VRB400M50SAEM9PB No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb Part No SW: 4H0 953 568 H HW: 4H0 953 568 H Component: Lenks.Modul H04 0005 Revision: -------- Serial number: 90372MJA000IB Coding: 0004FC Shop #: WSC 00736 003 1048576 VCID: B83C53F10BF0FC845F-80EC Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E Component: E221 - MFL H08 0010 Serial number: 20 09 2013 D0315133 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1 Part No SW: 4G8 920 984 R HW: 4G8 920 984 R Component: TBenUsaAcc H58 0621 Revision: 29460235 Serial number: 658200214596031 Coding: 0BC601060F53D705020100 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RBD4K 004048 ROD: EV_RBD4K.rod VCID: C5C22A054402916CD4-8090 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC Component: J533--Gateway H13 0050 Revision: -------- Serial number: 00000001284358 Coding: 00CD073000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_GatewPkoUDS 001019 ROD: EV_GatewPkoUDS_001_AU57.rod VCID: F2A8A1D9250C56D4A1-80A6 Battery Monitoring Control Module: Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8041 Serial number: 2022612603 Voltage stabilizer: Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 Component: J532_DCDCStab H23 0021 Serial number: 1312140000000000016A No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4G8 959 760 HW: 4G8 959 760 Component: MEM-FS H03 0157 Revision: AA000000 Serial number: 00000090994484 Coding: 00581B0000006001000001010101102030303232203232 Shop #: WSC 02391 785 00200 VCID: F7BE90CD466E33FC96-80A2 No fault code found. ------------------------------------------------------------------------------- Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb Part No SW: 4G0 907 637 K HW: 4G0 907 637 F Component: SARA 6D H03 0056 Revision: -------- Serial number: EJ1BPA8206CVGQ Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SARA2 005012 ROD: EV_SARA2.rod VCID: B6205DC909E40AF44D-80E2 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: Redir Fail! Part No SW: 4G0 907 566 J HW: 4G0 907 566 Component: J769 SWA MasterH04 0060 Revision: 00H04000 Serial number: 6PZ 010 287-08 Coding: 0000003 Shop #: WSC 02391 785 00200 VCID: B6205DC9C1E40AF44D-80E2 Subsystem 1 - Part No: 4G0 907 568 J Component: J770 SWA Slave H04 0060 Subsystem 2 - Serial number: 6PZ 010 287-28 Subsystem 3 - Serial number: 5F17.02.1400H04000AMS15233ÿ Subsystem 4 - Serial number: S15233ÿ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 4G8 959 793 H HW: 4G8 959 793 F Component: TSG FA H04 0507 Revision: -------- Serial number: -------------- Coding: 011F57025E00628002000413 Shop #: WSC 02391 785 00200 VCID: C5C22A054C02916CD4-8090 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb Part No SW: 4G0 909 144 L HW: 4G0 909 144 G Component: RCEPS H39 0010 Revision: 00001000 Serial number: 0028095518 Coding: 101001010000 Shop #: WSC 00736 003 1048576 ASAM Dataset: EV_RCEPS 009008 ROD: EV_RCEPS_009.rod VCID: B22861D9E58C16D461-80E6 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb Part No SW: 4H0 907 064 ER HW: 4H0 907 064 ER Component: BCM2 2.0 H36 0521 Revision: 00002001 Serial number: 0327928388 Coding: 0126023A20FAF08580B00A0402030D47000000000000000000 0000000000 Shop #: WSC 02391 785 00200 VCID: FDB282E5645219ACCC-80A8 Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719 Component: GTO BF H01 0081 Serial number: 00000000000000206201 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C Component: J245 PS40.039 H01 0008 Serial number: WOO27346714 Coding: 101F00 Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252 Component: HSP-SG H11 0029 Serial number: WA107531000006101122 Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D Component: GEB.F.Heckoef H16 0811 Serial number: 93164907 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4G0 035 223 C HW: 4G0 035 223 A Component: BOSE-G3-C7 H07 0160 Revision: CJ007001 Serial number: 00000000074248 Coding: 010000 Shop #: WSC 02391 785 00200 VCID: 9D72A2658412B9ACAC-80C8 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 4G8 959 792 J HW: 4G8 959 792 G Component: TSG BF H03 0507 Revision: -------- Serial number: -------------- Coding: 011F57025E00628002000402 Shop #: WSC 02391 785 00200 VCID: C6C02D0971049A74DD-8092 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 H HW: 4H0 907 801 A Component: EPB-4 H03 0015 Revision: -------- Serial number: 00000000968348 ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_VW51.rod VCID: AD1272A5FCB2492C3C-80F8 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb Part No SW: 4H0 907 357 B HW: 4H0 907 357 B Component: ....LWR12.... H02 0010 Serial number: 140219-0002-122 Coding: 1223A6101002A500 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_HeadlRegulBasic 005001 ROD: EV_HeadlRegulBasic.rod VCID: AD1272A5FCB2492C3C-80F8 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio ® Labels: Redir Fail! Part No SW: 4G0 035 082 G HW: 4G0 035 082 Component: Radio U SIRIU H60 0133 Revision: AB001007 Serial number: 156B%0E7971860 Coding: 020007010000000001 Shop #: WSC 02391 785 00200 VCID: A4049781A7788864E3-80F0 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4G0 035 746 F HW: 4G0 035 746 E Component: H-BNT-NA H41 0757 Revision: -------- Serial number: 194B20E7602987 Coding: 090200040003E8EF7D12CB1E00000003100001000000000000 Shop #: WSC 02391 785 00200 VCID: AA1879B9C55C5E14D9-80FE Subsystem 1 - Part No: 8R0 060 884 BL Component: NAR 2014 0902 Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C Component: DU8 C7 SV H43 0021 Serial number: AUZ8ZDDD003VD9+ Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C Component: E380 BDT C7 H11 0204 Serial number: 90349NBR00025 Subsystem 4 - Part No: 8R0 060 961 F Component: CD-Database 5571 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 4G8 959 795 J HW: 4G8 959 795 G Component: TSG HL H03 0507 Revision: -------- Serial number: -------------- Coding: 010F17024000628002000002 Shop #: WSC 02391 785 00200 VCID: C9DA2635601A750C30-809C No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4H0 907 428 B HW: 7P6 907 441 D Component: TopView H05 0220 Revision: 11001001 Serial number: 82330JF0133210 Coding: 0205000001010100000102000000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_CamerSysteTopViewAUDI 007026 ROD: EV_CamerSysteTopViewAUDI_007.rod VCID: AC147FA1C7A840242B-80F8 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (----) Labels:* Redir Fail! Part No SW: 4G8 959 107 R HW: 4G8 959 107 G Component: HDSG-Modul H13 0043 Revision: 12013001 Serial number: 038400135 Coding: 0A3305C102 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_HDSGAu573 001022 ROD: EV_HDSGAu571.rod VCID: C4C437014F38A864C3-8090 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 4G8 959 795 J HW: 4G8 959 795 G Component: TSG HR H03 0507 Revision: -------- Serial number: -------------- Coding: 010F17024000628002000002 Shop #: WSC 02391 785 00200 VCID: C9DA2635601A750C30-809C No fault code found. ------------------------------------------------------------------------------- Address 85: On Board Cam. (J852) Labels:* None Part No SW: 4G0 907 217 A HW: 4H0 907 217 A Component: DPC-SG H26 0038 Revision: -------- Serial number: 262130025421000 Coding: 6A060000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_OnBoardCamerDPC 001007 ROD: EV_OnBoardCamerDPC.rod VCID: A6008D89D9447A74FD-80F2 No fault code found. ------------------------------------------------------------------------------- Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb Part No SW: 4G0 907 541 A HW: 4G0 907 541 Component: ACC3 H19 0400 Serial number: 00000000000000 Coding: 7E01010201 Shop #: WSC 00736 003 1048576 ASAM Dataset: EV_AdaptCruisContr2AU57X 002008 ROD: EV_AdaptCruisContr2AU57X_002.rod VCID: A6008D89D9447A74FD-80F2 10 Faults Found: 32512 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_LWI] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:54:32 Control Module temperature: 62 °C Voltage terminal 15: 12.178 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 34816 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_SWA_01] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:54:32 Control Module temperature: 62 °C Voltage terminal 15: 12.210 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 35072 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_SWA_OBJLI] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:54:32 Control Module temperature: 62 °C Voltage terminal 15: 12.210 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 35328 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_SWA_OBJMI] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:54:32 Control Module temperature: 62 °C Voltage terminal 15: 12.210 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 35584 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_SWA_OBJRE] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:54:32 Control Module temperature: 62 °C Voltage terminal 15: 12.210 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 38144 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_Airbag_01] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:54:33 Control Module temperature: 62 °C Voltage terminal 15: 12.566 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 38912 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_APS1] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:54:32 Control Module temperature: 62 °C Voltage terminal 15: 12.302 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 38656 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_APS2] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:54:32 Control Module temperature: 62 °C Voltage terminal 15: 12.302 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 21760 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_APSM] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:54:32 Control Module temperature: 62 °C Voltage terminal 15: 12.302 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 27136 - Function Restricted due to Missing Message(s) U1111 00 [008] - - [FAULT_CIM_TIMEOUT_BVS_STATUS] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 214 Mileage: 36551 km Date: 2018.08.17 Time: 15:54:32 Control Module temperature: 62 °C Voltage terminal 15: 12.210 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² ------------------------------------------------------------------------------- Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb Part No SW: 4G0 907 107 E HW: 4H0 907 107 Component: BV-SG H32 0041 Serial number: 005000122602147 Coding: 03C198180111 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_BC7 001001 ROD: EV_BC7.rod VCID: A81C83B1D3506C04CF-80FC No fault code found. ------------------------------------------------------------------------------- Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb Part No SW: 4H0 980 945 B HW: 4H0 980 945 C Component: RGS-VL H13 0080 Coding: 0066E608031F0376070308014240C2010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_L 002004 ROD: EV_RGS_L.rod VCID: B12A6ED5E08A2DCC18-80E4 No fault code found. ------------------------------------------------------------------------------- Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb Part No SW: 4H0 980 946 B HW: 4H0 980 946 C Component: RGS-VR H13 0080 Coding: 0066E608031F0376070308014240C2010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_R 002004 ROD: EV_RGS_R.rod VCID: B22861D9E58C16D461-80E6 No fault code found. End----------(Elapsed Time: 02:41, VBatt start/end: 13.8V/13.5V)----------- |
Hey! Did you ever figure it out? I have the same code on my A7 2012..
