2005 A8 D3 EVAP Emission Control Sys P0441
16825 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent 2005 Audi A8 D3 My car Shuts off after :40 sec and sometimes 1:15sec. I ordered a new EVAP valve put it in. Cleared the code and it still shut off. the first time this happen i checked the engine and i noticed in the front left behind the Fog light. The Secondary Pump Electric Air Pump HOSE WAS OFF. I thought that would do it but didn't. I am the hose has been off for a while and has collected dirt and dust. example should i order a new one??? or could it be my fuel pump? Fault codes: Address 01: Engine Labels: 077-910-560-BFM.clb Part No SW: 4E0 910 560 J HW: 4E0 907 560 Component: 4.2L V8/5V G 0010 Revision: -------- Serial number: AUX3Z0D6745795 Coding: 0007773 Shop #: WSC 02313 785 00200 VCID: 2809F97CCEF82FB7A17-807C 7 Faults Found: 18061 - Please check DTC Memory of ABS Controller P1653 - 008 - - Intermittent 18107 - Powertrain Data Bus P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent 18036 - Powertrain Data Bus P1628 - 008 - Missing Message from Steering Angle Sensor - Intermittent 16825 - EVAP Emission Control Sys P0441 - 002 - Incorrect Flow - Intermittent 18010 - Power Supply Terminal 30 P1602 - 002 - Voltage too Low - Intermittent 18348 - Powertrain Databus P1940 - 008 - Missing Message from Control Module for Battery Monitoring 18613 - Performance Malfunction in Cooling System P2181 - 008 - - MIL ON |
