2005 A8 D3 EVAP Emission Control Sys P0441
16825 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
2005 Audi A8 D3
My car Shuts off after :40 sec and sometimes 1:15sec. I ordered a new EVAP valve put it in. Cleared the code and it still shut off.
the first time this happen i checked the engine and i noticed in the front left behind the Fog light. The Secondary Pump Electric Air Pump HOSE WAS OFF.
I thought that would do it but didn't. I am the hose has been off for a while and has collected dirt and dust. example
should i order a new one??? or could it be my fuel pump?
Fault codes:
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: -------- Serial number: AUX3Z0D6745795
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2809F97CCEF82FB7A17-807C
7 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
18036 - Powertrain Data Bus
P1628 - 008 - Missing Message from Steering Angle Sensor - Intermittent
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
18348 - Powertrain Databus
P1940 - 008 - Missing Message from Control Module for Battery Monitoring
18613 - Performance Malfunction in Cooling System
P2181 - 008 - - MIL ON
2005 Audi A8 D3
Fault codes:
Coding: 0007773
7 Faults Found:
rellascout
06-16-2019 04:53 AM
