ACC issue - 00234 Misadjusted
Hi guys,
my ACC stopped working a week ago. Just stopped working and pulling the following error. Tried to clear the error but still coming on. I did also check the measuring blocks and this is what is recorded. It comes up with Error code on Group 1 ? Address 13: Auto Dist. Reg Labels: None Part No SW: 4E0 910 561 F HW: 4E0 907 561 F Component: ABSTANDSREGELUNGH03 0020 Coding: 0041251 Shop #: WSC 02313 785 00200 VCID: 2517F333A9EB2BBFCDB-8070 1 Fault Found: 00234 - Sensor for Automatic Distance Regulation Misadjusted 000 - - - Intermittent - MIL ON Freeze Frame: Fault Status: 10110000 Fault Priority: 5 Fault Frequency: 7 Reset counter: 90 Mileage: 178716 km Time Indication: 0 Date: 2019.03.30 Time: 13:17:00 Freeze Frame: Temperature: 35.0°C Voltage: 11.39 V Bin. Bits: 00100000 https://cimg4.ibsrv.net/gimg/www.aud...984b14a6a0.png |
This won't help you much right now, but I do want to know if replacing the module (the radar behind the bumper cover) will require component protection removal.
If you do try a replacement radar, let me know how it goes. |
Hi all,
just for all which might have the same issue. It just needed re-calibration which you can do if you have VCDS. Thanks |
Originally Posted by W12BTW
(Post 25299371)
Hi all,
just for all which might have the same issue. It just needed re-calibration which you can do if you have VCDS. Thanks is there any instructions on this recalibration procedure? Thanks |
Acc
(Post 25299371)
Hi all,
