Air Suspension lights on. VCDS Scan results included
UPDATE: I replaced the 40A fuse under the dash. I took the car for a 10 minute ride and so far no lights have returned. 🤞 I'd still welcome input on the other fault codes.
Hey guys. Both air suspension lights came on today. It's been nearly 3 years since I replaced the compressor and my theory is that the one I installed from Rebuild Master Tech has died. I'm in NC and I'm guessing that the 95 deg weather hasn't helped. A couple of days ago I thought I heard the compressor struggling for a moment, but never heard the issue after that one time. The vehicle hasn't sagged and is still at normal height which I would assume won't be for long. I ran a VCDS scan and here are the results shortened to only the fault codes. Although I would like to focus on the air suspension I wouldn't mind input on the other items on the list. Keep in mind the dates on some of these as many happened a while ago. Monday,08,July,2019,16:24:20:61930 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 19.6.1.0 (x64) Data version: 20190529 DS308.0 www.Ross-Tech.com VIN: WAUML44E06N018741 License Plate: Mileage: 215800km-134091mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 65 67 72 76 77 VIN: WAUML44E06N018741 Mileage: 215800km-134091miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Malfunction 0010 0F-Digital Radio -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 4E0 910 560 P HW: 4E0 907 560 Component: 4.2L V8/5V G 0010 Revision: --H01--- Serial number: AUX3Z0F0783549 Coding: 0007773 Shop #: WSC 02313 785 00200 VCID: 2E536E7AB9E6AF3F3B-807A 2 Faults Found: 17985 - Right Engine Mount Solenoid Valve (N145) P1577 - 004 - Open Circuit Freeze Frame: Fault Status: 01100100 Fault Priority: 0 Fault Frequency: 40 Reset counter: 255 Mileage: 207931 km Time Indication: 0 Freeze Frame: RPM: 623 /min Load: 46.6 % Speed: 5.0 km/h Temperature: 93.0°C Temperature: 28.0°C Absolute Pres.: 0.0 mbar Voltage: 13.716 V 17981 - Left Engine Mount Solenoid Valve (N144) P1573 - 004 - Open Circuit Freeze Frame: Fault Status: 01100100 Fault Priority: 0 Fault Frequency: 112 Reset counter: 255 Mileage: 211336 km Time Indication: 0 Freeze Frame: RPM: 758 /min Load: 67.4 % Speed: 0.0 km/h Temperature: 78.0°C Temperature: 69.0°C Absolute Pres.: 0.0 mbar Voltage: 11.303 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.clb Part No SW: 4E0 910 732 S HW: 4E0 035 729 Component: Interfacebox H43 4610 Revision: 00000000 Serial number: 346HQ037505391 Coding: 0000003 Shop #: WSC 00000 000 00000 VCID: 326B7A0AADDE8BDF5F-8066 Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH03 0040 Subsystem 2 - Serial number: 00000000011670 Subsystem 3 - Serial number: 0113.06.060000000100010096˙ Subsystem 4 - Serial number: 010096˙ 1 Fault Found: 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 105 Mileage: 185775 km Time Indication: 0 Date: 2016.08.08 Time: 01:41:32 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.clb Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 67916 260 51396 VCID: 285F98629B02F10FF1-807C 2 Faults Found: 01770 - Temperature Sensor for Level Control Pump/Compressor (G290) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 4 Fault Frequency: 59 Reset counter: 180 Mileage: 211118 km Time Indication: 0 Date: 2018.11.21 Time: 16:34:01 00668 - Supply Voltage Terminal 30 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 168 Mileage: 215809 km Time Indication: 0 Date: 2019.07.08 Time: 16:24:04 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 B HW: 4E0 907 289 Component: Komfortgeraet H05 0010 Revision: 00100005 Serial number: W040601150033 Coding: 0048702 Shop #: WSC 02313 785 00200 VCID: 285F98629B02F10FF1-807C Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P27H08 0090 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H04 0020 3 Faults Found: 01134 - Alarm Horn (H12) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 147 Reset counter: 144 Mileage: 213033 km Time Indication: 0 Date: 2019.05.03 Time: 09:06:07 01134 - Alarm Horn (H12) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 147 Reset counter: 144 Mileage: 213033 km Time Indication: 0 Date: 2019.05.03 Time: 09:06:07 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 147 Reset counter: 144 Mileage: 213033 km Time Indication: 0 Date: 2019.05.03 Time: 09:06:07 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 802 B Component: Türsteuer.BF BRM003 0100 Coding: 0032364 Shop #: WSC 02311 785 00200 VCID: 204F8042F332094FB9-8074 1 Fault Found: 02116 - Mirror Adjusting Motor 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 3 Fault Frequency: 0 Reset counter: 162 Mileage: 215408 km Time Indication: 0 Date: 2019.06.14 Time: 09:21:62 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000532 Shop #: WSC 08902 444 56823 VCID: 204F8042F332094FB9-8074 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 44 Time Indication: 0 Freeze Frame: Voltage: 5.07 V Count: 61 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 E HW: 4F0 907 357 E Component: AFS 1 H01 0010 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 02313 785 00200 VCID: 285F98629B02F10FF1-807C Subsystem 1 - Part No: 4F0 941 329 B Component: AFS-Modul links H02 0020 Subsystem 2 - Part No: 4F0 941 329 B Component: AFS-Modul rechtsH02 0020 1 Fault Found: 02628 - Sensor for Swivel Module Position; Right 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 40 Mileage: 212936 km Time Indication: 0 Date: 2019.04.29 Time: 18:47:18 ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000010248 Shop #: WSC 08316 444 57454 VCID: 204F8042F332094FB9-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 1601140343 Coding: 344530393135313035412056413031363031313430333433 Shop #: WSC 00000 128 00289 5 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 28 Reset counter: 255 Mileage: 205837 km Time Indication: 0 Date: 2018.03.09 Time: 08:43:35 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 8 Reset counter: 255 Mileage: 207809 km Time Indication: 0 Date: 2018.09.18 Time: 02:28:41 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 8 Reset counter: 255 Mileage: 207809 km Time Indication: 0 Date: 2018.09.18 Time: 06:05:03 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 8 Reset counter: 255 Mileage: 207809 km Time Indication: 0 Date: 2018.09.18 Time: 06:05:13 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 8 Reset counter: 255 Mileage: 207809 km Time Indication: 0 Date: 2018.09.18 Time: 06:05:23 ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 J HW: 4E0 035 753 A Component: SDS 3501 US H45 0600 Revision: 00000000 Serial number: 00000512200212 Shop #: WSC 12336 024 394758 VCID: 2D516976B4E0D42702-8078 1 Fault Found: 01043 - Control Module; Incorrect Software Version 000 - - Freeze Frame: Fault Status: 01110000 Fault Priority: 5 Fault Frequency: 254 Reset counter: 144 Mileage: 185775 km Time Indication: 0 Date: 2016.08.08 Time: 01:37:59 ------------------------------------------------------------------------------- |
I had the same headlight issue. I had to take out the light and since it was already dead, I used a multi vibrating tool and cut a square out of the bottom of the headlight. This was to repair the broken and frayed wiring to the sensor. I used heat shrink and liquid tape and some soldering to fix the wires. They all looked cracked from age and heat. To seal it back up I used a big hot glue gun and a combination of hot glue and super glue with an activator to seal it up. It works and you can't tell unless you remove the headlight. Its better than 1500$ from the dealer!
