Fuel/Trunk buttons
Can anyone tell me the easiest way to replace the Fuel/Trunk buttons in the door panel? Do I need to remove the door panel? Thanks in advance for your help.
Yep, door panel has to com off, easy enough to do so though.
Yes
Remove door trim I replaced mine A couple of years ago So if any others like window or door buttons need do now is the time |
Yes, panel comes off. For what it's worth though, I found the switch replacement part fairly difficult to do. Panel is easy once you have pulled it once and know the steps. But that specific switch assembly is tightly sandwiched in there with the hinged storage pocket and thus difficult to get at. Window switch block and door lock switch are much easier to do.
These Be the Procs...
5 Attachment(s)
Originally Posted by dbkc397
(Post 24830703)
Quick tip, the door trim clips take a tremendous amount of force to "pop". So much so you'll be convinced you missed a screw or bolt and are about to break something. But persevere and you'll get there. And you will break some clips so make sure to have some spares. They're cheap enough and readily available from dealers or online.
Part no: 6Q0868243 |
Someone needs to create & sell matte black stickers with various icons to cover all the worn buttons. The black is easy enough to remove and there's a nice smooth white surface beneath. I can't believe it hasn't been done.
