Replaced front shock, now having lifting issues
My front left shock went bad. When starting the car the compressor would turn on and raise the front to ride height however out had an extreme leak and would be back on the ground 20 minutes later. I replaced the shock and all seemed fine until the test drive she is now randomly raising to an alarming height and then shortly after bleeding off back to ride height. Day 2 and still having the issue intermittently. Any thoughts
Is the suspension in automatic mode? I would try playing around with the ride height settings.
Is there a yellow light warning on your dash? If you have software, clear all the codes.
Originally Posted by Faaz.Baig
(Post 25289555)
Originally Posted by SeanA8L757
(Post 25289863)
for some reason i don't have that option im only able to adjust exterior lighting and lock settings no option for ride height adjustments
Someone turned the option off when the car was broken.
Go to a shop that has a VCDS to turn it back on |
Originally Posted by ltooz_a6_a8_q7
(Post 25289935)
I didn't say the mechanic turned it off, someone might do it to hide the failures. Did you have the function before replacing the shock?
(Post 25289943)
