2012 3.0tdi power steering problem
Hi, I have started to have intermittent problem with the power steering cutting out, normally at low speed and with little/no throttle. It has been scanned and no fault codes and also no hydrolic leaks and the fluid is at the correct level. Could a faulty battery cause this? The reason I ask is that it had a new alternator a few months ago and although I have not had any warnings or problems starting I have noticed that the stop/start isn't working either? Many thanks |
Power steering pumps are known to die on 3.0 TDI. I had to change mine in my Q7 TDI. It was just faulty. I bought mine from europaparts for like $300. When it comes to stop/start I would say check FOB battery. If FOB battery is new get someone with Ross tech and make sure your comfort setting is enabled for start/stop. Also, car battery needs to be programmed into the car for proper operation.
Originally Posted by NotoriousGLU
(Post 25152456)
What I mean by FOB is key fob. Sorry. Do you mean start stop as auto start stop not engine start stop?
(Post 25152487)
I would scan it with VCDS and see what is going on with that system. Was the battery properly installed in the car? Battery Replacement - Ross-Tech Wiki
(Post 25152497)
Originally Posted by Chris Brookes
(Post 25152501)
I have owned the car for about 20 months and not had to replace the battery so I'm assuming it was installed correctly when I purchased it, I'm thinking maybe it is just past it's best? The car is about 6 1/2 years old and has about 190k on it. |
Originally Posted by Twglasgow
(Post 25153595)
if the battery is 6 years old replace it. +1 on that. For me after 3-4 years, any time a battery then shows signs of weakness, I replace. 6-½ years is pretty decent already. |
