g60 question
I'm doing g60's spaced out with 90q sport rotors to tide me over while I save for willwoods. I have a 1990 90q 7a vin 0345somthing. have calpiers/carriers, G60 master c, rotors, pads, all I need is stainless lines. do I want the 4-hose set or the 6-hose set? I'm confused on that one.
it depends...the only real way to tell is to look inside your front wheel well...
if you have a 2 hose front flex line, then you want the 6 hose stainless, if you have a 1 hose front line, then you want the 4.
Jake |
look at your strut tube...if there is a metal hard line attached to it with brake lines
running to and fro, then you need a 6 hose set (4 front, 2 rear) if there's one hose running from the body of the car (solid line) to the caliper, then a 4 line set (2 front, 2 rear) is in order. i have a 90 cq that has the 4-piece front lines and a 91 90q20v with only singular front lines, if that's of any help... i believe the 20v sedan got the 2-line front brake set-up, not the 4, across the board.
I have 1 thats all rubber but somthing else that looks like a hardline or possibly abs sensor?
I'll have to look tomorrow when its light out.
If you only have one rubber line...
from the body to the brake, then you need the 4 line kit. Call Blauparts, they will help get it right. I ordered the 4 line kit based on my VIN, then when I went to install it, I found out that I needed the 6 line kit and had to send it back for a new one.
Jake |
Great, thanks all for the help.
