g60 question
g60 question
I'm doing g60's spaced out with 90q sport rotors to tide me over while I save for willwoods. I have a 1990 90q 7a vin 0345somthing. have calpiers/carriers, G60 master c, rotors, pads, all I need is stainless lines. do I want the 4-hose set or the 6-hose set? I'm confused on that one.
it depends...the only real way to tell is to look inside your front wheel well...
if you have a 2 hose front flex line, then you want the 6 hose stainless, if you have a 1 hose front line, then you want the 4.
Jake
Jake
look at your strut tube...if there is a metal hard line attached to it with brake lines
running to and fro, then you need a 6 hose set (4 front, 2 rear) if there's one hose running from the body of the car (solid line) to the caliper, then a 4 line set (2 front, 2 rear) is in order. i have a 90 cq that has the 4-piece front lines and a 91 90q20v with only singular front lines, if that's of any help... i believe the 20v sedan got the 2-line front brake set-up, not the 4, across the board.
If you only have one rubber line...
from the body to the brake, then you need the 4 line kit. Call Blauparts, they will help get it right. I ordered the 4 line kit based on my VIN, then when I went to install it, I found out that I needed the 6 line kit and had to send it back for a new one.
Jake
Jake
BSK
Audi 100 / A6 (C4 Platform)
08-13-2003 09:13 AM
Sean1
03-17-2003 06:34 PM
