whoopie!
Front brake setup
<img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00019.jpg" border="0" alt="Photobucket"> Mance swaybar links <img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00020.jpg" border="0" alt="Photobucket"> Subframe bushings (lots of rustiness :\) <img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00021.jpg"> Subframe bushings (2) <img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00022.jpg" border="0" alt="Photobucket"> Engine shot <img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00023.jpg" border="0" alt="Photobucket"> Engine shot (2) <img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00024.jpg" border="0" alt="Photobucket"> <img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00026.jpg" border="0" alt="Photobucket"> <img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00027.jpg" border="0" alt="Photobucket"> <img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00028.jpg" border="0" alt="Photobucket"> Boost me <img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00030.jpg" border="0" alt="Photobucket"> Some dirt and stuff <img src="http://i260.photobucket.com/albums/ii11/minipitt1/DSC00031.jpg" border="0" alt="Photobucket"> |
Nice work..
What discs are you running? I'm trying to decide between the 312's or 323's
Want to make me some rear caliper brackets? |
jealous.
323 on the front
-I'm not sure if this is a common issue or what, but I had to grind about a millimeter off both of the front ball joint castings so the rotors wouldn't rub. Seems fine, but I've never heard anyone mention this before so I thought it was a bit odd..
I had brackets machined for the rear that allow me to use 288mm A6 rotors. -$50 ea. at FLAPS, and they fit absolutely perfectly :)-b |
Couple questions
What length of line did you use for the fronts? and where did you get it?
Anychance you could have a set of those rear brackets made for me, if so how much? Thanks, |
looks great
Awesome work Marty
Looks great! Now get it done and moving fast...
take good notes. I'm following in these footsteps.
Are you in MI as well?
just noticed your Red Wings logo :D-b.
