Electrical problems A3 8p1 2.0TDI BKD 16v
i'm having some funky business in the electrical compartment giving me fake faults everything works but sometimes goes to limp mode going uphill 1 gear pedal to the metal but no bueno it's like it does not hold boost when shifting gears changed the maf sensor cleaned the egr valve changed the vacuum solenoid dismantled the turbo checked bearings cleaned the veins... can it be some relays ? i tried to extract pin code from the dash or ecu to create a spare key with k commander but it does not communicate neither to the dash or ecu only communicates with the engine
Chassis Type: 8P (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 7D VIN: WAUZZZ8P44A010062 Mileage: 288580km-179315miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 7D-Aux. Heat -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKD.clb Part No SW: 03G 906 016 G HW: 028 101 136 4 Component: R4 2,0L EDC 0000SG 5184 Revision: 12345678 Serial number: AUX7Z0C3FNS0C2 Coding: 0000072 Shop #: WSC 06435 000 00000 VCID: 275D4E9B96ED1DB3A2-8072 3 Faults Found: 16485 - Mass Air Flow Sensor (G70) P0101 - 000 - Implausible Signal - Intermittent Freeze Frame: RPM: 1323 /min Torque: 0.0 Nm Speed: 59.0 km/h Load: 0.0 % Duty Cycle: 96.8 % Bin. Bits: 00000011 Mass Air / Rev.: 305.0 mg/str Mass Air / Rev.: 765.0 mg/str 18051 - Please check DTC Memory of Electric Load Controller P1643 - 000 - Freeze Frame: RPM: 1533 /min Torque: 154.0 Nm Speed: 12.0 km/h Load: 47.8 % Voltage: 14.06 V Bin. Bits: 00000000 Load: 61.2 % (no units): 1.0 16486 - Mass Air Flow Sensor (G70) P0102 - 000 - Signal too Low Freeze Frame: RPM: 882 /min Torque: 46.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.06 V Bin. Bits: 00000000 Mass Air / Rev.: 270.0 mg/str Mass Air / Rev.: 0.0 mg/str Readiness: 1 1 0 0 0 ------------------------------------------------------------------------------ Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No: 1K0 907 379 D Component: ESP FRONT MK60 0102 Coding: 0055942 Shop #: WSC 06435 000 00000 VCID: 3365AACB523561130E-8066 3 Faults Found: 00810 - Sensor 1/2 for Brake Pressure 005 - No or Incorrect Basic Setting / Adaptation 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation 01423 - Lateral Acceleration Sensor (G200) 005 - No or Incorrect Basic Setting / Adaptation ------------------------------------------------------------------------------ Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 HW: 8P0 820 043 Component: KlimavollautomatH11 0120 Shop #: WSC 00000 000 00000 VCID: 69D908A34079EBC374-803C 3 Faults Found: 00601 - Potentiometer On Positioning Motor for Central Flap (G112) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 22 Reset counter: 222 Mileage: 287960 km Time Indication: 0 Date: 2021.06.09 Time: 17:17:50 Freeze Frame: Voltage: 14.30 V (no units): 255.0 Temperature: -50.0°C 01317 - Control Module in Instrument Cluster (J285) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 123 Mileage: 287941 km Time Indication: 0 Date: 2021.06.09 Time: 05:37:39 Freeze Frame: ON 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 192 Mileage: 288197 km Time Indication: 0 Date: 2021.06.26 Time: 10:46:00 Voltage: 7.40 V ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl Part No SW: 8P0 907 279 A HW: 8P0 907 279 A* Component: Bordnetz-SG 1.0 H27 0401 Revision: 00000000 Serial number: 00000006344751 Coding: 01884F0082141000000000000000000000 Shop #: WSC 99999 666 45725 VCID: 3B7582EB7A65A953D6-806E Subsystem 1 - Part No: 8P1 955 119 Labels: 1TX-955-119.CLB Component: Wischer WWS Audi350 0130 Coding: 16711696 Shop #: WSC 99999 1 Fault Found: 01504 - Bulb for License-Plate Light (X) 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8P0-959-655-84.lbl Part No SW: 8P0 959 655 F HW: 8P0 959 655 F Component: Airbag 8.4ED H01 0130 Coding: 0010602 Shop #: WSC 06435 000 00000 VCID: 4581E4130CA1EFA3B0-8010 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 A HW: 1K0 953 549 A Component: Lenksäulenmodul 007 0030 Coding: 0000012 Shop #: WSC 06435 000 00000 VCID: 306FA5C7A3235A0B73-8064 No fault code found. ------------------------------------------------------------------------------ Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 930 C HW: 8P0 920 930 C Component: KOMBIINSTR. VDO H24 0070 Revision: D03 Serial number: 2243CD03004815 Coding: 0004103 Shop #: WSC 00011 888 96745 VCID: 326BAFCFAD2F681B05-8066 1 Fault Found: 00779 - Outside Air Temp Sensor (G17) 010 - Open or Short to Plus Freeze Frame: Fault Status: 00000011 Fault Priority: 7 Fault Frequency: 56 Reset counter: 191 Mileage: 287582 km Time Indication: 0 Date: 2021.05.15 Time: 06:34:10 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb Part No SW: 1K0 907 530 B HW: 1K0 907 951 Component: Gateway H07 0040 Revision: 07 Serial number: 150010341936FF Coding: 3D0F0B02070100 Shop #: WSC 99999 666 45725 VCID: 2643439F91E704BB99-8072 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8P0 920 930 C HW: 8P0 920 930 C Component: KOMBIINSTR. VDO H24 0070 Revision: D03 Serial number: AUX7Z0C3FNS0C2 Shop #: WSC 00011 888 96745 VCID: 326BAFCFAD2F681B05-8066 1 Fault Found: 01176 - Key 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------ Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl Part No: 8P0 959 801 A Component: Tuersteuerger. H08 0010 Coding: 0000016 Shop #: WSC 06435 000 00000 VCID: 397998E370599B43C4-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-143-GEN1.clb Part No: 1K1 909 143 K Component: EPS_ZFLS Kl.7 0308 Shop #: WSC 00000 000 00000 VCID: 326BAFCFAD2F681B05-8066 1 Fault Found: 00750 - Warning Lamp 013 - Check DTC Memory - Intermittent Freeze Frame: Mileage: 720 km Temperature: 16.0°C Voltage: 11.20 V Voltage: 11.10 V ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8P0-959-433.lbl Part No: 8P0 959 433 B Component: KSG H02 0020 Coding: 008800186D288505484A0160 Shop #: WSC 06435 000 00000 VCID: 3B7582EB7A65A953D6-806E No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 8Px-035-382.lbl Part No SW: 8P3 035 382 HW: 8P3 035 382 Component: AB2 SUBWOOFERBOXH10 0080 Revision: 00006 Serial number: 10000001008599 Shop #: WSC 00000 000 00000 VCID: 70EF65C763A31A0B33-8024 No fault code found. ------------------------------------------------------------------------------ Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl Part No: 8P0 959 802 A Component: Tuersteuerger. H08 0010 Coding: 0000016 Shop #: WSC 06435 000 00000 VCID: 3A7B87EF755F905BCD-806E 2 Faults Found: 00929 - Locking Module for Central Locking; Front Passenger Side (F221) 008 - Implausible Signal - Intermittent 00106 - Signal Central Locking SAVE/LOCK Passenger Side 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 A HW: 1K0 963 235 A Component: PTC-Element 0303 Revision: 00400000 Serial number: Shop #: WSC 00000 000 00000 VCID: 295948A380F92BC3B4-807C No fault code found. End-------------------------(Elapsed Time: 01:33)------------------------- |
