Electrical problems A3 8p1 2.0TDI BKD 16v
i'm having some funky business in the electrical compartment giving me fake faults everything works but sometimes goes to limp mode going uphill 1 gear pedal to the metal but no bueno it's like it does not hold boost when shifting gears changed the maf sensor cleaned the egr valve changed the vacuum solenoid dismantled the turbo checked bearings cleaned the veins... can it be some relays ? i tried to extract pin code from the dash or ecu to create a spare key with k commander but it does not communicate neither to the dash or ecu only communicates with the engine
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 7D
VIN: WAUZZZ8P44A010062 Mileage: 288580km-179315miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5184
Revision: 12345678 Serial number: AUX7Z0C3FNS0C2
Coding: 0000072
Shop #: WSC 06435 000 00000
VCID: 275D4E9B96ED1DB3A2-8072
3 Faults Found:
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 1323 /min
Torque: 0.0 Nm
Speed: 59.0 km/h
Load: 0.0 %
Duty Cycle: 96.8 %
Bin. Bits: 00000011
Mass Air / Rev.: 305.0 mg/str
Mass Air / Rev.: 765.0 mg/str
18051 - Please check DTC Memory of Electric Load Controller
P1643 - 000 -
Freeze Frame:
RPM: 1533 /min
Torque: 154.0 Nm
Speed: 12.0 km/h
Load: 47.8 %
Voltage: 14.06 V
Bin. Bits: 00000000
Load: 61.2 %
(no units): 1.0
16486 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
Freeze Frame:
RPM: 882 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00000000
Mass Air / Rev.: 270.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 1 1 0 0 0 ------------------------------------------------------------------------------
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0055942
VCID: 3365AACB523561130E-8066
3 Faults Found:
00810 - Sensor 1/2 for Brake Pressure
005 - No or Incorrect Basic Setting / Adaptation
00778 - Steering Angle Sensor (G85)
01423 - Lateral Acceleration Sensor (G200)
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0120
Shop #: WSC 00000 000 00000
VCID: 69D908A34079EBC374-803C
3 Faults Found:
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 22
Reset counter: 222
Mileage: 287960 km
Time Indication: 0
Date: 2021.06.09
Time: 17:17:50
Freeze Frame:
Voltage: 14.30 V
(no units): 255.0
Temperature: -50.0°C
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 123
Mileage: 287941 km
Time Indication: 0
Date: 2021.06.09
Time: 05:37:39
Freeze Frame:
ON
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 192
Mileage: 288197 km
Time Indication: 0
Date: 2021.06.26
Time: 10:46:00
Voltage: 7.40 V
------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000006344751
Coding: 01884F0082141000000000000000000000
Shop #: WSC 99999 666 45725
VCID: 3B7582EB7A65A953D6-806E
Subsystem 1 - Part No: 8P1 955 119 Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0130
Coding: 16711696
Shop #: WSC 99999
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0010602
VCID: 4581E4130CA1EFA3B0-8010
No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 007 0030
Coding: 0000012
VCID: 306FA5C7A3235A0B73-8064
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 C HW: 8P0 920 930 C
Component: KOMBIINSTR. VDO H24 0070
Revision: D03 Serial number: 2243CD03004815
Coding: 0004103
Shop #: WSC 00011 888 96745
VCID: 326BAFCFAD2F681B05-8066
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
Freeze Frame:
Fault Status: 00000011
Fault Priority: 7
Fault Frequency: 56
Reset counter: 191
Mileage: 287582 km
Time Indication: 0
Date: 2021.05.15
Time: 06:34:10
------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H07 0040
Revision: 07 Serial number: 150010341936FF
Coding: 3D0F0B02070100
VCID: 2643439F91E704BB99-8072
No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D03 Serial number: AUX7Z0C3FNS0C2
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H08 0010
Coding: 0000016
VCID: 397998E370599B43C4-806C
No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-143-GEN1.clb
Part No: 1K1 909 143 K
Component: EPS_ZFLS Kl.7 0308
1 Fault Found:
00750 - Warning Lamp
013 - Check DTC Memory - Intermittent
Freeze Frame:
Mileage: 720 km
Temperature: 16.0°C
Voltage: 11.20 V
Voltage: 11.10 V
------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 B
Component: KSG H02 0020
Coding: 008800186D288505484A0160
No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH10 0080
Revision: 00006 Serial number: 10000001008599
VCID: 70EF65C763A31A0B33-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000016
VCID: 3A7B87EF755F905BCD-806E
2 Faults Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00106 - Signal Central Locking SAVE/LOCK Passenger Side
008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 A HW: 1K0 963 235 A
Component: PTC-Element 0303
Revision: 00400000 Serial number:
VCID: 295948A380F92BC3B4-807C
End-------------------------(Elapsed Time: 01:33)-------------------------
Coding: 0000072
3 Faults Found:
Freeze Frame:
RPM: 1323 /min
Torque: 0.0 Nm
Speed: 59.0 km/h
Load: 0.0 %
Duty Cycle: 96.8 %
Bin. Bits: 00000011
P1643 - 000 -
Freeze Frame:
RPM: 1533 /min
Torque: 154.0 Nm
Speed: 12.0 km/h
Load: 47.8 %
Voltage: 14.06 V
Bin. Bits: 00000000
Load: 61.2 %
(no units): 1.0
Freeze Frame:
RPM: 882 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00000000
Coding: 0055942
3 Faults Found:
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 22
Reset counter: 222
Mileage: 287960 km
Time Indication: 0
Date: 2021.06.09
Time: 17:17:50
Freeze Frame:
Voltage: 14.30 V
(no units): 255.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 123
Mileage: 287941 km
Time Indication: 0
Date: 2021.06.09
Time: 05:37:39
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 192
Mileage: 288197 km
Time Indication: 0
Date: 2021.06.26
Time: 10:46:00
Voltage: 7.40 V
Coding: 16711696
Shop #: WSC 99999
1 Fault Found:
Coding: 0010602
Coding: 0000012
Coding: 0004103
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 56
Reset counter: 191
Mileage: 287582 km
Time Indication: 0
Date: 2021.05.15
Time: 06:34:10
1 Fault Found:
01176 - Key
Coding: 0000016
1 Fault Found:
Freeze Frame:
Mileage: 720 km
Temperature: 16.0°C
Voltage: 11.20 V
Voltage: 11.10 V
Coding: 0000016
2 Faults Found:
tmurtaza
07-12-2016 06:26 PM
