25% Discounts! - Revo by Alcon 355 and 380mm Big Brake Packages...
http://europrice.us/media/catalog/pr...revob8bbka.jpg
Revo by Alcon 380x32mm Big Brake Package – $2665.00 set (Retail - $3595.00) Revo by Alcon 355x32mm Big Brake Package – $2665.00 set (Retail - $3595.00) Information:
Revo by Alcon calipers are cast from one piece of aluminum. This single casting design with the cross bridges cast in place creates a very stiff unit and very little compliance during braking. Less compliance means less pedal travel because the brake fluid is only applying force to the pistons, not bending the caliper. This applies the maximum amount of force to the Ferodo performance brake pads. Our brakes use ultra-high-resilience piston seals, with proprietary retraction angle shape, minimising piston travel distance for less dead pedal travel and resulting in better pedal feel in the vehicle. Brake Rotors: Racers have long used floating disc technology, but the discs found on racecars move freely on the floating pin drive connecting the bell to the disc, causing noise. To eliminate the rattling race disc for our street car customers, we have re-engineered the floating system using noise-reducing methodology that eliminates noise but still allows for thermal expansion with expanding floating capabilities to handle higher temperatures.
Ferodo DS2500 Brake Pads offer low and high speed braking efficiency, reduced stopping distances and a consistent brake pedal feel from the start. This new generation of friction material is very low in compressibility ensuring a firm pedal, whilst still providing low wear rates for discs and pads. Combined with low wheel dusting and good noise characteristics, this compound is the brake pad for the driver who demands the ultimate in track day braking performance. Brake Lines: Hosetechnik Stainless Brakeline Kits are manufactured with the finest quality hose, consisting of a PTFE inner and stainless steel braided outer to improve braking performance, eliminate the spongy feel of the original rubber hoses, and provide superior resistance to abrasion and corrosion. These kits not only provide the reliability and safety demanded in a brake system, but offer good looks that improve the appearance of any installation. Brake Fluid: Motul Dot 5.1 brake fluid is a long life 100% synthetic brake fluid suitable for all types of hydraulic actuated-brake and clutch systems that require DOT 5.1, DOT 4 and DOT 3 manufacturers’ brake fluid recommendations. Particularly suitable for use with anti-lock braking systems (ABS).
Wheel templates are available upon request. Please email to receive these if required: contact@europrice.us Delivery: Some kits are ready to ship for your order depending on caliper color and rotor sizing. Delivery estimates can be obtained via PM or email: contact@europrice.us Shipping is via major carrier to all locations, any duty/brokerage fees are the responsibility of the recipient if located outside of the US. Questions, Quotes: If you would like a quote including delivery please add the product to your cart and view the cart to estimate. If you have any questions or needs other than those posted above please don't hesitate to PM or email: contact@europrice.us Thanks! |
