UK: 1.6 tdi, rattling noise at idle, Audi a3 2014
Noise is very prominant at idle when the car is cold the auxillary belt was removed and the noise was still there, the cambelt and water pump where changed but it still remains. Anyone had this problem before or could suspect what it is? Kind of sounds like marbles bouncing around and dissapears when the car is up to temp.
Originally Posted by Brandon27
(Post 25800190)
Video of noise |
Originally Posted by TheRazzerman
(Post 25850147)
Just come across your post mate. Mine has done the exact same noise for around 12months and never got to the bottom of it. Have you managed to figure out what the cause was?
(Post 25850346)
So when I got the car it made the noise and it was on 77k miles but it was definitely not as noticeable, it is now as loud as in the video and the car is on 95k, my mechanic could not find what the noise was and it does still dissapear once warm. Doesnt seem to have affected the car in any way but still no solution, what mileage is your car on?
(Post 25850720)
It was doing it when I bought the car also, but didn't notice until I was home. I'm on pretty much 100k now and runs fine. It does sound like it's in the bottom of the engine itself. I'm thinking maybe something to do with the oil pump thpu's driven by either a belt or chain. Not sure on our model. Either way, it never misses a beat and having a good look around, i found a couple of posts where people have had it for 50k+ miles and nothing has happened. With a bit of luck it's just a trait of the engine
(Post 25800190)
Video of noise And don't run engine without v-ribbed belt which is attached to alternator which charging battery.. You will deplete battery in 5- 10 minutes.. |
(Post 25800190)
Video of noise Hi Brandon, did you solve the problem? I have exactly this sound coming from the engine when cold. |
So from my research around the issue, it does seem to be a trait of the engine and mine has been running healthy, not give me any issues and Im up to 97k now, the noise was there since 77k and as others said there seems to be no fix available. That video I posted was after everything was replaced and the noise is still the same to this day, hasn't affected the car in any way though.
