obdeleven
fired it up today for the first time in few months. was looking to turn on the scandinavian drl's for my rear tail lights since I just had the clear blackline version installed. noticed that there are a lot more apps in the S5 section. even one for turning off the amber indicators which makes no sense since in the US they remain amber anyway. also added the RS5 g meter to the display as an option. it does display but doesnt do anything. I doubt that the S5 has a g meter in it but in case it does is there a way to turn it on? very pleasantly surprised that they added so many apps. even have the gear display available in drive or in sport mode now and it works.
Originally Posted by OneOfOne
(Post 25163180)
(Post 25163180)
Originally Posted by rccoleman
(Post 25163184)
I made the same change manually a while ago and got the same result. There was a post from someone saying that the S4/S5 don't have the accelerometer hardware.
Originally Posted by CtheW0rld
(Post 25163484)
There are g-meter apps for your phone https://play.google.com/store/apps/d...rfree&hl=en_US
(Post 25163180)
Since I will be receiving my OBDeleven soon, what are some of the most popular changes (that work) people are making on their A5 S5 vehicles?
(Post 25163659)
Sure, but my goal with these coding changes is often "what cool stuff can I add to my car?" and not "how can I solve this problem?" :). Enabling a g-meter is very much in the former category for me.
Originally Posted by Tb5
(Post 25163671)
(Post 25163671)
-------------------------------------- >>To mute the Soundaktuator A9 Structure Borne Sound Adaptation 10 At Channel drop down choose "Volume of structure borne noise actuator" (only choice) Enter a value in the proper box (0% = mute ) -------------------------------------- >>show gear in D and S 02 - Transmission Adaptation “Single gear display” Set new value to “D on/S on” -------------------------------------- >>Increase Range of Comfort Window Open/Close with Key 46 - Central Module Comfort System Long Coding “comfort_operation_range_limitation” Change from “active” to “not active” Press and hold green check mark to accept -------------------------------------- >>Confort Blink Cycle 46 - Central Module Comfort System Adaption Turn signal control-freeway flashing: flashing cycles Old value is 3 (for 3 blinks) ----------------------------------------- Disable Seat Belt Chime Go to module 17 “Dash Board” Long Coding -> “Seat Belt Warning” Default is “Version 2”. Version 1” displays the logo without chime. “Off” turns off the logo and chime Green check mark to accept. |
