2.7t no pull?
Hey guys, I just bought my allroad a few weeks ago. Its a 2.7t with the 6 speed. APR stage 2 tune, and a lightweight flywheel. When I first bought it I feel like it pulled HARD, now i feel like its all motor, no turbo pull. I don't know if I'm getting used to the car, or if somethings wrong. The car only has 95k miles.... Any ideas?
Thanks |
VAG COM codes?
Check the obvious first: boost pipes, vacuum lines. |
I know what you mean. At first, it felt like the hand brake was on and then after acceleration, it seems to behave normally. I have an Allroad 2002 2.7L, as well.
if you have enough $$ to buy a audi Q5, why would you buy cheap tires.
it is no safety to buy cheap tires buy real ones from a known tire OEM |
Need to scan for codes. You very well may have a code, causing limp mode (EGT sensor possibility?) or as previously mentioned, possibly a boost leak of sorts. Could be any number of possible causes however a scan would be my starting point.
WTF...…...just saw this thread is ancient!!!
