Accessing the Menu???
I know I read something here about how to access the computer menu. My car has no push and turn knob on the console. All I have is the mirror adjustment knob.
I believe it's actuated on my car by the steering column controls. Specifically the wiper control arm. That is where the reset button is. I can switch the display to show the avg mpg or miles driven but, I can't reset the clock! :-) I'm searching elsewhere online now. The information is very clear in the manual I have that talks about a push and turn knob. I just happen to have one of the cars that doesn't have the same control setup for the instrument display. I'll be checking back throughout the night. TIA! |
pull out the odometer reset button. It should start blinking. Then turn left or right to set it.
Thank you for reminding me to change the clock >
Mine an '01, no control knob down there either.
It is adjusted with the knob that protrudes out of the cluster by the speedo. Pull it once, so the hour is flashing, then turn it to the left to "Fall Back" an hour. Pull a few more time until the date stays steady. Your done. |
correct procedure, wrong knob. there are two similar buttons next to the computer display
pull the one to the left of the computer out to get the clock blinking. set it, pull it again, for minutes, again for date...
the odometer reset os on the right of the computer display |
Re: That was it!
OK, that procedure will set the clock and date.
ok I found that out on my own but
when I pushed it read how long till service
then did some other stuff what was that? can I set a chime to go off is it for time driving or for a max speed? thx |
oops, thanks for the clarification.
