Accessing the Menu???
Old Nov 3, 2008 | 07:30 PM
SmileyOr's Avatar
Default Accessing the Menu???
I know I read something here about how to access the computer menu. My car has no push and turn **** on the console. All I have is the mirror adjustment ****.
I believe it's actuated on my car by the steering column controls. Specifically the wiper control arm. That is where the reset button is. I can switch the display to show the avg mpg or miles driven but, I can't reset the clock! :-)
I'm searching elsewhere online now. The information is very clear in the manual I have that talks about a push and turn ****. I just happen to have one of the cars that doesn't have the same control setup for the instrument display.
I'll be checking back throughout the night.
TIA!
Old Nov 3, 2008 | 07:45 PM
K2audi's Avatar
pull out the odometer reset button. It should start blinking. Then turn left or right to set it.
Old Nov 3, 2008 | 07:49 PM
ar-Rings's Avatar
Default Thank you for reminding me to change the clock >
Mine an '01, no control **** down there either.
It is adjusted with the **** that protrudes out of the cluster by the speedo. Pull it once, so the hour is flashing, then turn it to the left to "Fall Back" an hour. Pull a few more time until the date stays steady.
Your done.
Old Nov 3, 2008 | 07:57 PM
gragravar's Avatar
Default correct procedure, wrong ****. there are two similar buttons next to the computer display
pull the one to the left of the computer out to get the clock blinking. set it, pull it again, for minutes, again for date...
the odometer reset os on the right of the computer display
Old Nov 3, 2008 | 08:06 PM
SmileyOr's Avatar
Default Re: That was it!
OK, that procedure will set the clock and date.
Old Nov 3, 2008 | 08:08 PM
Mx-3GSR's Avatar
Default ok I found that out on my own but
when I pushed it read how long till service
then did some other stuff what was that?
can I set a chime to go off
is it for time driving or for a max speed?
thx
Old Nov 3, 2008 | 09:06 PM
K2audi's Avatar
oops, thanks for the clarification.
EricNCSU1204
Q7 MKII Discussion
22
Mar 27, 2025 09:46 PM
pyoung007
Q5/SQ5 MKI (8R) Discussion
Dec 5, 2022 04:02 AM
Alain Vu
A6 (C7 Platform) Discussion
25
Dec 19, 2012 02:25 PM
rickspix
Audi allroad
Dec 10, 2001 07:27 PM
mrsteve
Apr 11, 2000 03:18 PM
