Suspension Control Level Surpassed
Recently had new (used) engine put in my AR. It was in the garage 4 weeks for various reasons and when I got it back the amber suspension warning light on the dash was on. Did not get the garage to look into this because I knew I had a small (intermittent) air leak on one of the rear air springs so thought the 'warning' was due to that.
Fitted my new Arnott air spring ok but 'warning' light still on. Useing my Ross Tech (full version) program I intended to tweek up the levels useing the 402 adaption method but found I could not do this because I had the message "Control Limil Surpassed" so new levels could not be entered. I think that maybe because of the battery being disconnected of ages at the garage and possibly clumsy jacking the controller has reverted to some 'impossible' hieght setting. At the moment the front is permenently high (maybe level 3 or 4) and the rear is down on end stop I think. Since I cannot reprogam the levels useing 'adaption' is there any way to reset to 'factory' setting or tricking the controller out of 'limit suppressed' mode. Any help os advice would be much appreciated. |
Possible Solution
Check the front height sensors
Originally Posted by paulouk
(Post 24469297)
Fitted my new Arnott air spring ok but 'warning' light still on. Useing my Ross Tech (full version) program I intended to tweek up the levels useing the 402 adaption method but found I could not do this because I had the message "Control Limil Surpassed" so new levels could not be entered. I think that maybe because of the battery being disconnected of ages at the garage and possibly clumsy jacking the controller has reverted to some 'impossible' hieght setting. At the moment the front is permenently high (maybe level 3 or 4) and the rear is down on end stop I think. Since I cannot reprogam the levels useing 'adaption' is there any way to reset to 'factory' setting or tricking the controller out of 'limit suppressed' mode. Any help os advice would be much appreciated. no other fault codes?? regards Andy |
Originally Posted by bagpipingandy
(Post 24469517)
I would check the level sensors especially the wheels the garage were working on, there is a procedure somewhere but don't have it too hand
Hi Paul, the level not learned code, had you previously tried to calibrate it? If you did with a weak compressor or leak this may be the issue. If you start the calibration the car tries to get to level 2 if it can't do this this fault can occur,
let me know if we are on the right lines regards andy |
Hi Andy, UPDATE! I was just about to buy a used Suspension Controller on Ebay hoping that it may still have it's default height setting, when I thought I'd try just one last time to get the '402 adaption' prog to complete. To my surprise it came up with 'value' instead of 'error' so I lowered the front by 5mm and raised the rear 5mm and the amber dash light went out once I'd saved the new settings.
Since then I have been able to access the 'adaption' every time presumably because I am now within acceptable limits and not in 'control limits surpassed' mode. Have now made adjustments front and rear, 10mm at a time, and my AR is sitting pretty at 402ish. Gave it along run yesterday and all functions seem to be working normally at last. Thanks for your ionterest and to Amiram Paul. |
Like the others have said the allroad is a heavy pig with squishy air suspension. With the money you would have to put into the allroad to make it track tolerable you could get something much more capable. You could find a nice BMW E39 or MB wagon over there for about what you could sell the allroad for not even taking into acount shipping a car over there from the US.
Originally Posted by abeeha
(Post 24471022)
I see no reason to leave Audi and certainly would not touch a BMW or a US vehicle with a barge-pole. If you hate Allroad so much I wonder why you bothered to join the AR forum!! |
(Post 24471034)
Thank you for your comment 'abeeha', but your comment seems to be ill founded. My Allroad corners like it is on rails on 'level 1 and 2' at speed and on 'levels 3 and 4' it goes over rocks, rubble and mud on my unmade track leading to my house high on Dartmoor, Devon, UK. And with the leather and wallnut interier it does it in style and comfort.
jacketsvision http://www.jacketsvision.com/ Testking 220-701 Testking 220-701 Testking 220-702 Testking 220-702 Testking VCP-410 Testking VCP-410 Testking 640-816 Testking 640-816 |
