Will fidanza LF from B5 S4 fit our cars? I wonder b/c the tranny fits.
<ul><li><a href="http://www.fidanza.com/ItemDetails.aspx?fid=17">http://www.fidanza.com/ItemDetails.aspx?fid=17</a</li></ul>
JB Racing makes lightweight flywheels for our cars, fits like stock.
isn't the Fidanza like half the price though?
flywheel fitment is usually engine dependent
guy in detroit ran Fidanza with a '00 2.7TT A6 6 spd. trans in a 92 S4
said way better than stock 92 setup
Which clutch? Which Fidanza flywheel.
I doubt it. The B5 S4 tranny uses a spacer when installed. When we use the B5 S4 tranny in our cars
that spacer gets discarded. This would indicate that the flywheel/clutch assembly is longer on a B5 S4.
Fidanza lightweight flywheel with SPEC II clutch on an 01E 6 spd. in 92 S4
all I know
Yes, it does fit with minor modifications.
"I was very impressed with the flywheel/clutch. It was quiet, no rattling, and very smooth. Take up was very smooth so launch was very easy. There was much discussion and fretfulness as I started the project because I didn't know if it would be a bolt-in but it turned out to be easy. It was indeed a bolt-in other than one bolt hole in hte bell housing of the trans which had to be elongated very slightly. The clutch and flywheel was bolt-in though once I got the correct bolts."
Quote-unquote from a man whose done it using a Fidanza LWFW with a Spec I clutch. |
