Will fidanza LF from B5 S4 fit our cars? I wonder b/c the tranny fits.
<ul><li><a href="http://www.fidanza.com/ItemDetails.aspx?fid=17">http://www.fidanza.com/ItemDetails.aspx?fid=17</a</li></ul>
I doubt it. The B5 S4 tranny uses a spacer when installed. When we use the B5 S4 tranny in our cars
that spacer gets discarded. This would indicate that the flywheel/clutch assembly is longer on a B5 S4.
Yes, it does fit with minor modifications.
"I was very impressed with the flywheel/clutch. It was quiet, no rattling, and very smooth. Take up was very smooth so launch was very easy. There was much discussion and fretfulness as I started the project because I didn't know if it would be a bolt-in but it turned out to be easy. It was indeed a bolt-in other than one bolt hole in hte bell housing of the trans which had to be elongated very slightly. The clutch and flywheel was bolt-in though once I got the correct bolts."
Quote-unquote from a man whose done it using a Fidanza LWFW with a Spec I clutch.
ECS Tuning-Audi
03-24-2015 06:34 AM
thewatcher101
06-07-2007 08:27 PM
gtivr6turbo
Audi Original "S" Cars
01-21-2007 12:28 AM
tozoM8
15
03-30-2006 08:12 PM
