Adaptive Cruise Control with Stop&Go
I saw somewhere mentioned that you can get Q7 with Stop&Go functionality. I'm considering hybrid Q5, but does Adaptive Cruise Control have Stop and Go functionality in that?
No adaptive cruise, let alone stop & go on a Hybrid
Would have gotten it if it was available on my 2013 Hybrid, but the Hybrid doesn't have adaptive cruise either standard or optionally. Same for 2014, where the only real change for Hybrids was a few more color choices.
One of the few things missing where you have to get one of the six cylinder models--basically this and Drive Select IIRC. |
Originally Posted by zico
(Post 24474337)
ROW have had stop/start for several years and it was actually introduced to the U.S. with the A6/A7 in 2013 models as a standard feature. It's not directly related to ACC as it appears in those models without that option.
Unlike with previous Euro models, the A6/A7 Stop/start can not only be deactivated at the push of a button but will remember the setting next time the car is started. Which is a good thing for me as I don't care for it. I don't sit in daily traffic so whatever tiny gas mileage or emissions improvement would be gained is minimal. While others find it acceptable, for me it's annoying, particularly if I want to make a fast getaway from a stop - there is an ever so slight delay that I find disconcerting. And there's the extra starter and battery workouts over time consideration. |
As mentioned Start/Stop has been standard on Euro Q5's for some time - and is not related to ACC.
It is related to Hill Hold Assist though... If you come to a stop, and are very light on the brake, the engine will not cut out, if you are heavier/normal in the amount of pressure you applied as you come to a stop it will. Once you lift off the brake the engine will restart - but if HHA is turned on then the car will not move. With this I find it no problem for fast getaways at junctions; If I am going to be stopped for a while at a light, leave my foot on the brake (engine off) If I can see I am only going to stop briefly use light braking to a a stop (engine stays on) If I am going to stop for a while, but at the front of a queue for a junction, normal braking (engine off), lift off the brake all together as I see a gap arriving (engine starts and HHA holds the car still), floor it into the gap... |
I believe zico was asking about the Stop & Go feature of Adaptive Cruise Control, not the Start/Stop System that isn't associated with ACC.
Adaptive Cruise Control w/ Stop & Go allows the vehicle to come to a complete stop when the ACC is enabled. Once the traffic starts moving again, the cruise control resumes to it's programmed speed (or safe speed relative to the distance of the car in front of you) from a stopped position without any user input. Either way the US Q5 doesn't have ACC w/ Stop & Go, just basic ACC - which btw is still a useful feature! :) |
Originally Posted by AlwayzBallin3
(Post 24474560)
Adaptive Cruise Control w/ Stop & Go allows the vehicle to come to a complete stop when the ACC is enabled. Once the traffic starts moving again, the cruise control resumes to it's programmed speed (or safe speed relative to the distance of the car in front of you) from a stopped position without any user input. Either way the US Q5 doesn't have ACC w/ Stop & Go, just basic ACC - which btw is still a useful feature! :) I agree that even in the Q5 form its a very useful feature - I use it on highway and in city driving regardless - you just have to remember to brake when it 'bings' at 10mph! |
